Kamjohnson253 Posted August 23, 2019 Share Posted August 23, 2019 Installed the invidia q300 catback today. What a pain in the butt the mufflers were to actually fit inside the bumper and exhaust hangers. My original exhaust sounded like garbage due to the gaskets disintegrating so this is definitely an upgrade Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted August 23, 2019 Share Posted August 23, 2019 Installed the invidia q300 catback today. What a pain in the butt the mufflers were to actually fit inside the bumper and exhaust hangers. My original exhaust sounded like garbage due to the gaskets disintegrating so this is definitely an upgrade Sent from my SM-G965U using Tapatalk Love my q300, mated with invidia catted downpipe too 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Scottydunno Posted August 23, 2019 Share Posted August 23, 2019 I got nuttin,, so.... Happy Friday, all. j.Ditto.. just usual PM to do at some point soon. Too dang hot out... Scotty Link to comment Share on other sites More sharing options...
solidxsnake Posted August 24, 2019 Share Posted August 24, 2019 Got some small progress on the motor. Reacquainted myself with my garage (). Got the coolant crossover pipe installed with new o-rings. Pulled the cam sprockets to see that the shop didn't install any cam seals . Wasn't happy to see that, as I don't have any sockets the correct size to easily tap them in. Made due with using a smaller socket and carefully tapping it in evenly point-by-point along the edges. Got the rear timing covers installed, and the cam sprockets installed and torqued down. Also installed a new water pump (Aisin TKF-008 kit). 3-4 of the 6 bolts seemed like the holes are stripped, probably from PO or previous shop over-torquing the bolts. I stopped tightening before they started spinning free, but I have no idea if they're good enough to hold. I guess I'll find out Bugs came out and light was disappearing, so I finished the night by installing the set of KSTech air-pump block-off plates. Early tomorrow morning, I plan on making as much progress as I can before my night plans. Timing belt, timing covers, exhaust manifold, intake manifold, turbo, flywheel/clutch. That should be it before I'm ready to drop it back in the car! Hopefully, anyway. Link to comment Share on other sites More sharing options...
seanyb505 Posted August 24, 2019 Share Posted August 24, 2019 Yikes on the cam seals. I'd go back to the shop and have a talking with them. My cam seals gave me a lot of problems with leaks on my rebuild-like geyser level. Imagine if you hadn't noticed that? Can you helicoil the aluminum block? I feel like deep down inside if you feel the bolts are getting closer to spinning instead of closer to the factory torque value, they might not be torqued properly. Building up the long block on the stand with all the peripherals was one of my favorite parts of my build. Everything so clean... Link to comment Share on other sites More sharing options...
SBT Posted August 24, 2019 Share Posted August 24, 2019 Also installed a new water pump (Aisin TKF-008 kit). 3-4 of the 6 bolts seemed like the holes are stripped, probably from PO or previous shop over-torquing the bolts. I stopped tightening before they started spinning free, but I have no idea if they're good enough to hold. I guess I'll find out Bugs came out and light was disappearing, so I finished the night by installing the set of KSTech air-pump block-off plates. Heli-coil with some thread paste. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted August 24, 2019 Share Posted August 24, 2019 Vaca-ing, so Subewagen patiently rests for the moment. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
tocinoman25 Posted August 24, 2019 Share Posted August 24, 2019 While doing some logging on e85 the boost gauge hose manage to come off the nipple. Double zip tied it, definitely not coming off anytime soon. Sent from my SM-G960U using Tapatalk Follow me on IG @chefodiycarguy and @chefo.soriano Link to comment Share on other sites More sharing options...
SBT Posted August 24, 2019 Share Posted August 24, 2019 While doing some logging on e85 the boost gauge hose manage to come off the nipple. Double zip tied it, definitely not coming off anytime soon. Spray some hair spray on the nipple and in the hose end, then stuff the hose on and zip tie it. Not only will it not blow/work off, but the HS will seal it as well. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
solidxsnake Posted August 24, 2019 Share Posted August 24, 2019 Yikes on the cam seals. I'd go back to the shop and have a talking with them. My cam seals gave me a lot of problems with leaks on my rebuild-like geyser level. Imagine if you hadn't noticed that? Can you helicoil the aluminum block? I feel like deep down inside if you feel the bolts are getting closer to spinning instead of closer to the factory torque value, they might not be torqued properly. Building up the long block on the stand with all the peripherals was one of my favorite parts of my build. Everything so clean... Heli-coil with some thread paste. Spent probably an hour+ this morning looking for a local shop that has an M6x1.25 helicoil kit to no avail. Even McMaster doesn't stock it. Only online search I could find was for Grainger for a 500pk for $380 For now, I just re-installed all 6 bolts with Loctite 242 (blue). I think it should be fine, but if it does become a problem, at least it doesn't involve pulling the motor. Got the timing belt done, manifolds installed, turbo installed, and flywheel/clutch installed. A WIP shot after doing the timing belt (which was WAY easier with the Aisin kit, as the Mitsuboshi belt is pre-marked to line up with the crank/cam marks, unlike the Gates belt). Those with experience will know what's wrong with this picture. http://i.imgur.com/s9R9MzHl.jpg Turns out the Aisin TKF-008 kit doesn't include the small idler (between the tensioner and the left-side head). Had to reuse the one I saved from before. Interestingly enough, all the stock photos of this kit online show it with that small idler, but not the sprocket idler that goes next to the water pump (which my TKF-008 kit came with...). Besides that, I had a couple other minor hiccups along the way, just from doing stupid things, forgetting one thing needing me to undo work (e.g. forgot one of the brackets that braces the up-pipe to the block, etc.). Just the nature of coming back to a project a long time after it was started. Have to call it a day for now, but it's looking like I'll have the motor back in the car tomorrow! Still gotta torque down the crank bolt, waiting till it's in the car so I can use the drivetrain to keep the crank from spinning. Don't foresee any roadblocks, so I'm expecting smooth sailing tomorrow. But we all know how it never works that way Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2019 Share Posted August 24, 2019 Haven't done much to either car lately just continuing to enjoy driving them. Will say with the great weather we're having here in CT, the wagon feels like it has 20 more whp lately. The tires are getting a little old, but they seem to break loose when I go to WOT in 1st gear and break loose again on the shift into 2nd. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SBT Posted August 24, 2019 Share Posted August 24, 2019 Will say with the great weather we're having here in CT, the wagon feels like it has 20 more whp lately.. 68F in the UpState and here on the Gulf Coast it's 96F in the shade with RF of 103F The tires are getting a little old, but they seem to break loose when I go to WOT in 1st gear and break loose again on the shift into 2nd. You say that like it's a bad thing. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
awfulwaffle Posted August 25, 2019 Share Posted August 25, 2019 Spare motor spun a rod bearing, at idle, during shakedown run. Oil crystal clear, no signs of impending doom until it just let go. Guess it's YNANSB stacked on top of a YNANSB. Rats. Link to comment Share on other sites More sharing options...
awfulwaffle Posted August 26, 2019 Share Posted August 26, 2019 RA shortblock on its way, heads that came off of my old motor going to the machine shop tomorrow. Here we go -.- Maybe now I'll do that build thread Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted August 26, 2019 Share Posted August 26, 2019 Today I removed my rear zero sports sway bar to put the stock one back on. This will suck for a few weeks until I get it on the spec b. It's sad putting this car back to stock to put it up for sale. I put well over 100,000 kms on it and it's been an absolutely amazing experience. I hope the spec b will do the same once I get it on the road. 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
solidxsnake Posted August 26, 2019 Share Posted August 26, 2019 (edited) All things considered, reasonably smooth sailing. Some stupid mistakes. Highlights include that I installed the motor mounts backwards, but didn't notice until I already had the motor mated with the transmission. So I reversed them under the car while fighting for space with a hoist and a floor jack. Then once everything was about buttoned up and I was adding coolant, noticed a small leak near the turbo. Turns out I mangled the coolant line running from the RH head to the turbo. Managed to get a pick in there to undo the clamp on the head, and used a spare hose I had sitting. Car fired right up! Took it for a spin and the first WOT pull totally reminded me of what I was missing. Unfortunately that didn't last long. Right around 16psi I was greeted with a loud POP and violent deceleration. Can't say it's the first time I've popped the TB-IC hose with the GS intercooler. Pulled over, finagled it back together, then brought it back home to re-tighten it. Later, decided to take the car out for my trip to my parents' place for dinner. On-ramp to the highway, another spirited pull, and another POP. This time, the clamp was nowhere to be found . Drove it to work today, need to drop by a hardware store to pick up a new clamp and hopefully do it right this time. Then I can start working on the tune Other problems: I replaced the power steering pump inlet o-ring, since I know I've been having PS leaks near the pump. Time will tell if that was the source of the leak, but I suspect not. But even worse, the power steering fluid burning/smoking is still there, and I think it's the rack, judging by the PS fluid on the right-side . I guess that's an excuse to look into upgrading to the '15+ STi rack, and to figure out the related VDC issues. Edited August 26, 2019 by solidxsnake Link to comment Share on other sites More sharing options...
seanyb505 Posted August 26, 2019 Share Posted August 26, 2019 Ps fluid burning/smoking would be fluid dripping down to the exhaust from the pump area. Could be continued leak, or just what's left. I had it for maybe a week before the smell completely went away. Link to comment Share on other sites More sharing options...
Notorious Posted August 26, 2019 Share Posted August 26, 2019 Met up with my friend a few days ago and got some detail shots of the STI genome exhaust. Mates up with a 3inch catless down pipe and 3 inch midpipe, it sounds amazing. I feel that it is throaty and low but not overbearing because it does taper after the midpipe to the stock pipe width of 2.5 or 2.25, whatever it is. One of my favorite things I’ve installed on the car so far. Link to comment Share on other sites More sharing options...
solidxsnake Posted August 26, 2019 Share Posted August 26, 2019 Ps fluid burning/smoking would be fluid dripping down to the exhaust from the pump area. Could be continued leak, or just what's left. I had it for maybe a week before the smell completely went away. This PS leak/burning has been around for quite a while now, and yeah, definitely a leak near the pump. When I got to putting the motor back in, when I moved the PS pump to the side of the bay, there was a good amount of PS fluid pooled in the crevices of the pump/bracket that spilled out. I'll be keeping an eye on it, hoping the inlet o-ring fixed it, but hopes are low for that. I have had those days, glad it is back up and running. I was considering doing the +15 rack what are the issues you speak of due to having VDC? From my reading, the '07+ LGTs with VDC will throw all sorts of issues when swapping to a 15+ STi rack due to the difference in steering ratio to the measured steering angle. I don't remember if a fix was ever found, and if it was, if it was a physical solution (modify the steering angle sensor to output the correct values for the new rack), or a software/ECU solution (i.e. reprogram the new steering ratio into the OEM software to fix the discrepancy). Link to comment Share on other sites More sharing options...
gkinslow Posted August 26, 2019 Share Posted August 26, 2019 I think my random idling issues are due to a faulty TPS. It looks like the throttle body will come out WITHOUT removing the intake manifold. Just have to remove the slave cylinder. Can anyone confirm or dispute this? Link to comment Share on other sites More sharing options...
Infosecdad Posted August 26, 2019 Share Posted August 26, 2019 I haven't had to do it before, but looks like it's pretty straight forward in the FSM. Link to comment Share on other sites More sharing options...
gkinslow Posted August 26, 2019 Share Posted August 26, 2019 According to that I don't even have to move the slave. That would be nice. Thanks for that illustration. Anyone have a good throttle body they'd like to part with? Link to comment Share on other sites More sharing options...
Infosecdad Posted August 26, 2019 Share Posted August 26, 2019 I was going to say yes I have a spare from an 05 OBXT, but according to parts.subaru.com there is some difference between the 2005-06 throttle bodies and the 2007-2010 throttle bodies. Not sure what, but they have different part numbers. Link to comment Share on other sites More sharing options...
gkinslow Posted August 26, 2019 Share Posted August 26, 2019 I was seeing that as well. The 05-06 looks like you can just replace the TPS but the 07-09 it is all one unit. Link to comment Share on other sites More sharing options...
Sparkey Posted August 26, 2019 Share Posted August 26, 2019 Tried to find someone to replace my lower control arm bushings if the arm was removed. After finally finding someone who would (two shops said no) I was quoted 200-300 for two arms - i need 4 done. Thats a bit higher then I was expecting and is more then enough to warrant buying a press and the Avo tools - or should I leave it to someone who's done it before? They made it seem like its super difficult - one set of arms is brand new (but is aluminum), one set is 9 years old but rust free. Considering I would be using the correct sized press sockets shouldnt this be a fairly easy job? 05' LGT, ZFD Built 5MT, Stage 2 Cryotune 91/E85, 170,000mi running BRotella T6 and Ecoguard S4615 filters. Link to comment Share on other sites More sharing options...
