3D Printing Development Thread
I think it makes more sense to run it on the left side. Even if it was on the right, you're going to save what, 4" of wire, or tubing?
I mainly say the left because the fuse box is right there, and I know most people poke through the firewall under the TMIC or go through the door by the wheel well.
My $0.02
  • Replies 1.1k
  • Created
  • Last Reply
Top Posters In This Topic
My $0.02
I say have it on the left side as well for the reasons mentioned above.
Ok I just wasn't sure. It's just more tube in there blocking the vent. I mean I could just have it go down and back out the bottom then you can make a hole wherever you want. I am just trying to make the "tube" so that you don't see the wires in the vent itself. Trying to keep it clean :)
There are a few (proven?) models on thingiverse you could probably use.
Hmm I did not know about that site. I will look into it a bit thanks.
Poking around on other repositories also yielded zero results. Seems odd no one's made a file for the v3 yet.
I'll keep my eyes open in case one turns up.
Sounds good. I found one for the V2 and made up a model for it. Made a few modifications since it's going on the vent though.
I appreciate the hard work and dedication. I should be home in the Milwaukee area around June if you need to have anything test fit at that point.
I cad'ed up a bracket for retrofitting our cars with the new Mini H1 7.0 projectors. TRS doesn't sell one yet, and a lot of people are having success with 3D printed ones over on HID Planet.
Use 4mm/#8 screws to mount the projectors using this bracket. You might want to also print with a 100% infill for added strength.
Change the attached file from a PDF to .stl
http://www.thingiverse.com/thing:1471991/zip
Legacy_MiniH1_7_V0_change_to_stl.pdf
PDF and link don't work :confused:
It's not a pdf :lol:, you hace to change the extension to .stl
Just made thinkverse account so I have to wait 24hr before the file is public there apparently :mad:
Thinkverse or thingiverse?
sounds good ha. They will probably be done by then. Should only be a few more days before I get my prototypes :)
The part works when you change the extension just checked :)
Thingverse
Bracket is available now, check TRS.
So I received my first print (the one that was 100% filled) and I am very disappointed. I ordered this from makexyz. com
I ordered a .1mm (~.004") build layer and as you can see it clearly is not that. Other than that the overall quality is very poor so I am rather unhappy about spending the money on this as it is pretty much a waste. I emailed them and I will see what they say if they respond. However, the other one that I ordered from Shapeways is done and on its way to me so I will have an update on that soon.
Anyways here's the pics of the one I just got. Last few pics are comparing it to the one I printed here with a .007" build layer.
http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_094035521_zpsgkuawbk6.jpg
http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_094018679_zpsy7imduf6.jpg
http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_094007922_zpsxsfa9kmf.jpg
http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_125224587_zpsggzsmkz3.jpg
http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_124149653_zps95cz9yxr.jpg
http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_124817496_zpsstnueo8k.jpg
http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_124807489_zps9ioehgg7.jpg
doesn't look that bad. it's not like it's structural for guages, but may need to be for an AP mount version. i usually do a light sanding and paint all my parts regardless, and they look great after some TLC. yours does look better straight from the machine.
* Build Thread * 26.53 MPG - 12 month Average *
Streetlegal, I'd be willing to upgrade my printer to a dual extrusion setup and do these with a dissolvable support structure. Don't want any profit from it, but it'd be great if the toolhead cost would be offset from sales. If you PM me the internal volume of the model, I can get you per piece materials cost.
I'm even set up to Livestream so everyone could watch live as they print.
Live.EmergentPrinting.com
Edited by discojon
Does anyone on this thread have the resonator bottle from their air intake sitting around?
I bought an Outback that had the resonator removed and I want to print a cap to plug the hole on the underside of the intake box. But it's a PITA to remove the air box and a bigger PITA to access it from below to take measurements. And my LGT's stock airbox went into the trash years ago.
So I was hoping someone could measure the diameter and depth of the part that fits into the stock airbox. In return I'll put a model of the plug/cap on thingiverse for free.
Thanks!
