freaksavior Posted January 29, 2022 Share Posted January 29, 2022 Just wondering whatever happened with this? Was there ever a file shared for this gauge pod? We made a few and sold them. HMU if you’re interested in getting one though. Unfortunately, this file was not released to the public and there are no plans to release it either. sorry man. Link to comment Share on other sites More sharing options...
AlexShu Posted February 8, 2022 Share Posted February 8, 2022 Just wondering whatever happened with this? Was there ever a file shared for this gauge pod?It should be pretty easy to design a pod that bolts to the original vent in some manner, unfortunately I dont have any gauges nor any dimensions Sent from my POCOPHONE F1 using Tapatalk Link to comment Share on other sites More sharing options...
cheeseenlo Posted February 15, 2022 Share Posted February 15, 2022 AlexShu - I just PM'd you for a potential part development. If anyone else can help, I have a not so pretty bracket that supports my FPR which is mounted to the intake manifold. It's basic bracket using two pieces of bent aluminum that's been drilled and riveted. I'd like to explore printing a piece that allows a bit of adjustment and ease of removal. See photos for reference on location. I don't have a photo of the bracket itself but I can send takeoffs of dimensions needed if I get some help designing and printing the part. Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted February 16, 2022 Share Posted February 16, 2022 It should be pretty easy to design a pod that bolts to the original vent in some manner, unfortunately I dont have any gauges nor any dimensions Sent from my POCOPHONE F1 using Tapatalk The material around the vent is pretty slim. I wouldn’t trust the weight of a gauge+pod on the outer rim. You could do one but it wouldn’t look good at all IMO. On the one I’m working on I’m at max 2 due to weight. If you look at the ones made by LAM (Legace additive manufacturing) the base pod is in the center with two on the outer edge. He’s got sizeable attachments on either side to help hold in place and support it. His base is completely different though, which I’m not a fan of. That’s just me. AlexShu - I just PM'd you for a potential part development. If anyone else can help, I have a not so pretty bracket that supports my FPR which is mounted to the intake manifold. It's basic bracket using two pieces of bent aluminum that's been drilled and riveted. I'd like to explore printing a piece that allows a bit of adjustment and ease of removal. See photos for reference on location. I don't have a photo of the bracket itself but I can send takeoffs of dimensions needed if I get some help designing and printing the part. I’d you’re going to make a 3D model to print, why not just make an anodized aluminum bracket instead? I get that printing would be cheaper and I’m sure under hood temps on that side probably wouldn’t be enough to deform ABS (as long as there’s enough material in/on it so it’s not flimsy) but if it were me I’d rather have metal under the hood. My $0.02. Link to comment Share on other sites More sharing options...
cheeseenlo Posted February 16, 2022 Share Posted February 16, 2022 I’d you’re going to make a 3D model to print, why not just make an anodized aluminum bracket instead? I get that printing would be cheaper and I’m sure under hood temps on that side probably wouldn’t be enough to deform ABS (as long as there’s enough material in/on it so it’s not flimsy) but if it were me I’d rather have metal under the hood. My $0.02. The intent is to develop a printed part before moving to an aluminum bracket. I figure the cost to print one is much less than to use aluminum plate stock (which I already have). I'm accounting for revisions too before finalizing and getting the part made with aluminum to survive inside the engine bay. So you're right, I agree with you. You're just a few steps ahead of me. Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted February 17, 2022 Share Posted February 17, 2022 Ahhhh gotcha. Smart move. I made an GNX style instrument cluster for my Buick doing that. Only problem was it was too large to print, had to split it up. If my printer was working I’d offer to help…. Link to comment Share on other sites More sharing options...
CircusSub Posted March 6, 2023 Share Posted March 6, 2023 Bringing this topic into 2023. I'm in need of a dual gauge pod for the cubby on my 06. I have found a couple options on eBay but they are from over seas and just not worth the money. I have access to a 3D printer and plan to design my own. Before I spend the time and resources to do so, can anyone point me to a download link of one that is still current? If not, I will be making my design available for download. Also if anyone wants one shipped, I will be happy to do that. Link to comment Share on other sites More sharing options...
CircusSub Posted March 9, 2023 Share Posted March 9, 2023 For those interested. Below is the link to the .STL for a dual 52mm gauge pod mount. https://www.thingiverse.com/thing:5901116 Link to comment Share on other sites More sharing options...
shralp Posted March 9, 2023 Share Posted March 9, 2023 Casopolis was our go to back in the day. I see his site is still up but yes, your fitment is listed as out of stock. Might be worth contacting him tho to confirm. I've had his dual gauge 52mm in my '05 for years. https://casopolis.wixsite.com/cubbypods/subaru Link to comment Share on other sites More sharing options...
