Jdemod Posted June 23, 2015 Share Posted June 23, 2015 Im using designspark currently. Link to comment Share on other sites More sharing options...
Streetlegal Posted June 23, 2015 Share Posted June 23, 2015 Im using designspark currently. what kind of file do you need to have to be able to open parts in? Link to comment Share on other sites More sharing options...
Jdemod Posted June 24, 2015 Share Posted June 24, 2015 Well, designspark uses rsdoc. I think I can do obj and sketch up as well as stl too. Link to comment Share on other sites More sharing options...
compsurge Posted June 24, 2015 Share Posted June 24, 2015 I think DesignSpark will allow you to import Sketchup and STEP. Link to comment Share on other sites More sharing options...
Streetlegal Posted June 24, 2015 Share Posted June 24, 2015 I'm using CATIA. I can save as: catia file obviously, .stl, .igs, .model, .3dxml, .cgr, .hcg, .wrl, and .stp Which works best? You want me to just simplify the model to just have the mounting holes and the basic geometry of the hole? Link to comment Share on other sites More sharing options...
compsurge Posted June 24, 2015 Share Posted June 24, 2015 mspaint. Link to comment Share on other sites More sharing options...
Jdemod Posted June 25, 2015 Share Posted June 25, 2015 Just the basics would probably be best. stl file should be fine. Link to comment Share on other sites More sharing options...
Streetlegal Posted June 25, 2015 Share Posted June 25, 2015 (edited) mspaint. http://cdn.meme.am/instances/59449267.jpg Just the basics would probably be best. stl file should be fine. Sounds good. I'll simplify it up. Once I have it done I'll let you know. Edited June 25, 2015 by Streetlegal Link to comment Share on other sites More sharing options...
KevinA Posted June 25, 2015 Share Posted June 25, 2015 Hey, i just stumbled on this page. It's awesome. I had an idea. How about an insert that replaces the ash tray with an arm that can hold a phone? it would be really nice if you could take it out, so when you are not using it the door still closed. Link to comment Share on other sites More sharing options...
CasopoliS Posted June 25, 2015 Share Posted June 25, 2015 Good work on all the designs in here. Pretty cool ideas! Link to comment Share on other sites More sharing options...
Jdemod Posted July 6, 2015 Share Posted July 6, 2015 So, I was looking at the si switch a little more closely and don't see a great way to mount a cage on top of it. It looks like you would have to recreate the entire structure and take the switch apart in order to retain the mounting points that it uses. I could easily create a cage that sits on top but it would require some other mounting. Double sided tape in a recessed portion of the cage? Any ideas? Link to comment Share on other sites More sharing options...
BoyceWare Posted July 6, 2015 Share Posted July 6, 2015 Hate to throw this one out there but you could always reach out to a etuner like cryo and ask him how much it would cost to overwrite intelligent mode profile with sport or sportsharp. Link to comment Share on other sites More sharing options...
Streetlegal Posted July 6, 2015 Share Posted July 6, 2015 So, I was looking at the si switch a little more closely and don't see a great way to mount a cage on top of it. It looks like you would have to recreate the entire structure and take the switch apart in order to retain the mounting points that it uses. I could easily create a cage that sits on top but it would require some other mounting. Double sided tape in a recessed portion of the cage? Any ideas? What I'm doing with the switch panel is just recreating the switch into it but making it considerably smaller so that there is room for the switches around it. Link to comment Share on other sites More sharing options...
Jdemod Posted July 7, 2015 Share Posted July 7, 2015 What I'm doing with the switch panel is just recreating the switch into it but making it considerably smaller so that there is room for the switches around it. Ah, you're transferring the circuits on the bottom huh? Link to comment Share on other sites More sharing options...
Streetlegal Posted July 7, 2015 Share Posted July 7, 2015 Ah, you're transferring the circuits on the bottom huh? I pulled apart the switch and figured out how it works. Going to build a new board that does the same thing but in a more compact way Link to comment Share on other sites More sharing options...
KevinA Posted July 10, 2015 Share Posted July 10, 2015 I know it's not sexy, but what about replacement backcaps for the foglights, with instead of the pass-threw, a whole for a grommet, so when you install HID fogs, you can get your wires out. Link to comment Share on other sites More sharing options...
compsurge Posted July 10, 2015 Share Posted July 10, 2015 Can you do the same with a drill and the OEM part? the OEM parts are too cheap to justify 3D printing. Link to comment Share on other sites More sharing options...
Streetlegal Posted July 10, 2015 Share Posted July 10, 2015 I know it's not sexy, but what about replacement backcaps for the foglights, with instead of the pass-threw, a whole for a grommet, so when you install HID fogs, you can get your wires out. Can't you just drill a hole in the cover and put a grommet in it? That's what I did for my headlights. Link to comment Share on other sites More sharing options...
Streetlegal Posted July 10, 2015 Share Posted July 10, 2015 I think I have the vent model finalized so I stared messing around with some pod designs. Figured I'd throw a few up on here This is a offset twin 52mm gauge setup. The pad on the bottom connects right to the top of the vent. I just have it hidden to make it easier to work with right now. I do not have the bottom pad cut out as it will be to maintain a majority of the flow area of the defroster. Once I finalize the pod design it will be made modular so that I can add as many pods where ever I would like Shouldn't be too hard to mirror and make one for those LHD guys either. http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/Pods1_zpsn2v9xkwf.jpg http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/Pods2_zpsxhpbxe9l.jpg Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted July 10, 2015 I Donated Share Posted July 10, 2015 I think I have the vent model finalized so I stared messing around with some pod designs. Figured I'd throw a few up on here This is a offset twin 52mm gauge setup. The pad on the bottom connects right to the top of the vent. I just have it hidden to make it easier to work with right now. I do not have the bottom pad cut out as it will be to maintain a majority of the flow area of the defroster. Once I finalize the pod design it will be made modular so that I can add as many pods where ever I would like Shouldn't be too hard to mirror and make one for those LHD guys either. http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/Pods1_zpsn2v9xkwf.jpg http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/Pods2_zpsxhpbxe9l.jpg There's already a guy who makes these, block8head on facebook. they're quite well built. Link to comment Share on other sites More sharing options...
Streetlegal Posted July 10, 2015 Share Posted July 10, 2015 There's already a guy who makes these, block8head on facebook. they're quite well built. I know he makes them and they do look nice. These will be set up a little different. Plus it will give people more options this way too since I can change and put whatever I want onto the vent and print it. Link to comment Share on other sites More sharing options...
quick4dr Posted July 10, 2015 Share Posted July 10, 2015 How about a vent based COBB v3 holder Link to comment Share on other sites More sharing options...
baconbits Posted July 10, 2015 Share Posted July 10, 2015 Hopefully cheaper on the pods too... $130 or whatever they go for is steep. Link to comment Share on other sites More sharing options...
Streetlegal Posted July 10, 2015 Share Posted July 10, 2015 How about a vent based COBB v3 holder That wouldn't be hard to do. I just don't have a v3 to model it from. When I finish any models I'll be sending them to discojon for him to print and whatnot. Seeing as I offered to help him I don't want to basically take this from him. I'm not sure if I am saying that the right way but basically I don't want to be a dick that's all Link to comment Share on other sites More sharing options...
Streetlegal Posted July 10, 2015 Share Posted July 10, 2015 Mine also doesn't sit in the same location as block8head's pods. His are off to the right of the pod built up. Mine sit like this for now. Might change the angle of them some more once I have the actual pod finalized. Need to add some channels in to make sure the air gets directed properly and also to separate the air channels from the wire channels that I will be incorporating. http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/Pods3_zpso1yggi5v.jpg Link to comment Share on other sites More sharing options...
