freaksavior Posted April 5, 2016 Share Posted April 5, 2016 I think it makes more sense to run it on the left side. Even if it was on the right, you're going to save what, 4" of wire, or tubing? I mainly say the left because the fuse box is right there, and I know most people poke through the firewall under the TMIC or go through the door by the wheel well. My $0.02 Link to comment Share on other sites More sharing options...
Nowzor Posted April 5, 2016 Share Posted April 5, 2016 I say have it on the left side as well for the reasons mentioned above. Link to comment Share on other sites More sharing options...
StkmltS Posted April 6, 2016 Share Posted April 6, 2016 I had someone inquire about a AP V3 mount along with a single gauge also. I can do that also, however, I do not have a V3 or V2 nor do I have a model of one to go off of. There are a few (proven?) models on thingiverse you could probably use. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
Streetlegal Posted April 6, 2016 Share Posted April 6, 2016 I think it makes more sense to run it on the left side. Even if it was on the right, you're going to save what, 4" of wire, or tubing? I mainly say the left because the fuse box is right there, and I know most people poke through the firewall under the TMIC or go through the door by the wheel well. My $0.02 I say have it on the left side as well for the reasons mentioned above. Ok I just wasn't sure. It's just more tube in there blocking the vent. I mean I could just have it go down and back out the bottom then you can make a hole wherever you want. I am just trying to make the "tube" so that you don't see the wires in the vent itself. Trying to keep it clean There are a few (proven?) models on thingiverse you could probably use. Hmm I did not know about that site. I will look into it a bit thanks. Link to comment Share on other sites More sharing options...
Streetlegal Posted April 6, 2016 Share Posted April 6, 2016 There are a few (proven?) models on thingiverse you could probably use. If you find a V3 one could you pm me the link or something? I can't seem to find a V3 one. Found some V2 ones though. Link to comment Share on other sites More sharing options...
StkmltS Posted April 6, 2016 Share Posted April 6, 2016 If you find a V3 one could you pm me the link or something? I can't seem to find a V3 one. Found some V2 ones though. Poking around on other repositories also yielded zero results. Seems odd no one's made a file for the v3 yet. I'll keep my eyes open in case one turns up. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
Streetlegal Posted April 6, 2016 Share Posted April 6, 2016 Poking around on other repositories also yielded zero results. Seems odd no one's made a file for the v3 yet. I'll keep my eyes open in case one turns up. Sounds good. I found one for the V2 and made up a model for it. Made a few modifications since it's going on the vent though. Link to comment Share on other sites More sharing options...
Nowzor Posted April 6, 2016 Share Posted April 6, 2016 Ok I just wasn't sure. It's just more tube in there blocking the vent. I mean I could just have it go down and back out the bottom then you can make a hole wherever you want. I am just trying to make the "tube" so that you don't see the wires in the vent itself. Trying to keep it clean I appreciate the hard work and dedication. I should be home in the Milwaukee area around June if you need to have anything test fit at that point. Link to comment Share on other sites More sharing options...
utc_pyro Posted April 7, 2016 Share Posted April 7, 2016 I cad'ed up a bracket for retrofitting our cars with the new Mini H1 7.0 projectors. TRS doesn't sell one yet, and a lot of people are having success with 3D printed ones over on HID Planet. Use 4mm/#8 screws to mount the projectors using this bracket. You might want to also print with a 100% infill for added strength. Change the attached file from a PDF to .stl http://www.thingiverse.com/thing:1471991/zipLegacy_MiniH1_7_V0_change_to_stl.pdf Link to comment Share on other sites More sharing options...
StkmltS Posted April 7, 2016 Share Posted April 7, 2016 I cad'ed up a bracket for retrofitting our cars with the new Mini H1 7.0 projectors. TRS doesn't sell one yet, and a lot of people are having success with 3D printed ones over on HID Planet. Use 4mm/#8 screws to mount the projectors using this bracket. You might want to also print with a 100% infill for added strength. Change the attached file from a PDF to .stl http://www.thingiverse.com/thing:1471991/zip PDF and link don't work My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
utc_pyro Posted April 7, 2016 Share Posted April 7, 2016 It's not a pdf , you hace to change the extension to .stl Just made thinkverse account so I have to wait 24hr before the file is public there apparently Link to comment Share on other sites More sharing options...
ripstik Posted April 7, 2016 Share Posted April 7, 2016 It's not a pdf , you hace to change the extension to .stl Just made thinkverse account so I have to wait 24hr before the file is public there apparently Thinkverse or thingiverse? Link to comment Share on other sites More sharing options...
Streetlegal Posted April 7, 2016 Share Posted April 7, 2016 I appreciate the hard work and dedication. I should be home in the Milwaukee area around June if you need to have anything test fit at that point. sounds good ha. They will probably be done by then. Should only be a few more days before I get my prototypes It's not a pdf , you hace to change the extension to .stl Just made thinkverse account so I have to wait 24hr before the file is public there apparently The part works when you change the extension just checked Thinkverse or thingiverse? Thingverse Link to comment Share on other sites More sharing options...
Stirfry_LGT Posted April 7, 2016 Share Posted April 7, 2016 I cad'ed up a bracket for retrofitting our cars with the new Mini H1 7.0 projectors. TRS doesn't sell one yet, and a lot of people are having success with 3D printed ones over on HID Planet. Use 4mm/#8 screws to mount the projectors using this bracket. You might want to also print with a 100% infill for added strength. Change the attached file from a PDF to .stl http://www.thingiverse.com/thing:1471991/zip Bracket is available now, check TRS. Link to comment Share on other sites More sharing options...
utc_pyro Posted April 7, 2016 Share Posted April 7, 2016 Bracket is available now, check TRS. Looks like they still only offer the 6.0 bracket. Link to comment Share on other sites More sharing options...
Streetlegal Posted April 11, 2016 Share Posted April 11, 2016 So I received my first print (the one that was 100% filled) and I am very disappointed. I ordered this from makexyz. com I ordered a .1mm (~.004") build layer and as you can see it clearly is not that. Other than that the overall quality is very poor so I am rather unhappy about spending the money on this as it is pretty much a waste. I emailed them and I will see what they say if they respond. However, the other one that I ordered from Shapeways is done and on its way to me so I will have an update on that soon. Anyways here's the pics of the one I just got. Last few pics are comparing it to the one I printed here with a .007" build layer. http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_094035521_zpsgkuawbk6.jpg http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_094018679_zpsy7imduf6.jpg http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_094007922_zpsxsfa9kmf.jpg http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_125224587_zpsggzsmkz3.jpg http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_124149653_zps95cz9yxr.jpg http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_124817496_zpsstnueo8k.jpg http://i855.photobucket.com/albums/ab114/gearhead_18/Vent%20pod/IMG_20160408_124807489_zps9ioehgg7.jpg Link to comment Share on other sites More sharing options...
Flinkly Posted April 11, 2016 Share Posted April 11, 2016 doesn't look that bad. it's not like it's structural for guages, but may need to be for an AP mount version. i usually do a light sanding and paint all my parts regardless, and they look great after some TLC. yours does look better straight from the machine. * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
freaksavior Posted April 11, 2016 Share Posted April 11, 2016 ^^ Agreed. There's clearly a quality difference, but some fill primer, and paint could probably get the makexyz model looking as good. Link to comment Share on other sites More sharing options...
dzehner2 Posted April 13, 2016 Share Posted April 13, 2016 Has anyone tried ordering or printing one of these on a Formlabs printer? I bet they would look awesome! Link to comment Share on other sites More sharing options...
discojon Posted April 13, 2016 Author Share Posted April 13, 2016 (edited) Streetlegal, I'd be willing to upgrade my printer to a dual extrusion setup and do these with a dissolvable support structure. Don't want any profit from it, but it'd be great if the toolhead cost would be offset from sales. If you PM me the internal volume of the model, I can get you per piece materials cost. I'm even set up to Livestream so everyone could watch live as they print. Live.EmergentPrinting.com Edited April 13, 2016 by discojon Link to comment Share on other sites More sharing options...
discojon Posted April 13, 2016 Author Share Posted April 13, 2016 Has anyone tried ordering or printing one of these on a Formlabs printer? I bet they would look awesome! I think SLA would be the choice for these, but cost will likely be prohibitive. Link to comment Share on other sites More sharing options...
NSFW Posted April 14, 2016 Share Posted April 14, 2016 Does anyone on this thread have the resonator bottle from their air intake sitting around? I bought an Outback that had the resonator removed and I want to print a cap to plug the hole on the underside of the intake box. But it's a PITA to remove the air box and a bigger PITA to access it from below to take measurements. And my LGT's stock airbox went into the trash years ago. So I was hoping someone could measure the diameter and depth of the part that fits into the stock airbox. In return I'll put a model of the plug/cap on thingiverse for free. Thanks! Link to comment Share on other sites More sharing options...
wesleyCrowbar Posted April 14, 2016 Share Posted April 14, 2016 2.875" total depth 2.5" diameter. The smaller top section is 0.375" from the very top and 2.375" across http://uploads.tapatalk-cdn.com/20160414/4c644cac0d155102c897ac498da434a3.jpg Link to comment Share on other sites More sharing options...
NSFW Posted April 14, 2016 Share Posted April 14, 2016 Thanks! I'm pretty sure the larger-diameter section is what's important. Will print one and see. Link to comment Share on other sites More sharing options...
NSFW Posted April 14, 2016 Share Posted April 14, 2016 How far is that mounting hole from the side of the cylinder? I can clone that part too, to hold it in place... Link to comment Share on other sites More sharing options...
