Turkeylord Posted April 13, 2015 Author Share Posted April 13, 2015 Good call. Haven't fitted the intercooler yet. I'll do that this week some time. Link to comment Share on other sites More sharing options...
Turkeylord Posted April 15, 2015 Author Share Posted April 15, 2015 Definitely a good call. I even wound up clocking the turbo a little. http://i.imgur.com/6sd3hYk.jpg Link to comment Share on other sites More sharing options...
heiche Posted April 15, 2015 Share Posted April 15, 2015 you guys that pre-mount your turbo and tmic have any issues getting the engine in the car? i needed to remove my tmic to get to the rear attachment hook for the hoist. then i tried to leave the turbo attached to the engine, but it interfered with the bellhousing when i tried to get the engine in place. had to remove the turbo too, then it all fell into place. my turbo is a bnr16g though, don't know if that matters. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Turkeylord Posted April 15, 2015 Author Share Posted April 15, 2015 Yeah, TMIC will be coming back off before I drop the engine in, the idea is to avoid having to futz with the turbo placement/clocking once the things in the car. Should be able to drop the intercooler on now that it's all set up. I don't recall having any issues with the turbo though. Mine's a BNR too. Link to comment Share on other sites More sharing options...
SBT Posted April 15, 2015 Share Posted April 15, 2015 I'm leaving my turbo loose on the UP, so I can get the transmission by it on the reinstall. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
heiche Posted April 15, 2015 Share Posted April 15, 2015 I'm leaving my turbo loose on the UP, so I can get the transmission by it on the reinstall. Nice - that's the perfect compromise BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
SBT Posted April 16, 2015 Share Posted April 16, 2015 I'm hoping that I can install the GS TMIC bracketry before I reinstall the engine. Haven't looked at it since the delivery inspection, so don't recall how/where things bolt-up. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Turkeylord Posted April 18, 2015 Author Share Posted April 18, 2015 Let me make the mistakes so you don't have to... 1. Drop the engine in the bay, and then remember you needed to check the spark plugs and push the TOB and fork back. 2. Jack the tranny up so high that one of the CV axles comes apart. 3. Finally mate the engine and transmission, then wonder why the whole works is about an inch too far forward. Disconnect pitch stop. Nothing big though, and the end result was progress. http://i.imgur.com/dbn5pD5.jpg Link to comment Share on other sites More sharing options...
AMileHighLGT Posted April 20, 2015 Share Posted April 20, 2015 Good job, cant wait to see you start it up. Been subscribed for the entirety. Link to comment Share on other sites More sharing options...
Turkeylord Posted April 20, 2015 Author Share Posted April 20, 2015 Thanks! I suppose I could update the thread here... I did finish up on Saturday! Everything went pretty well, but there are a couple things I want to follow up on. The spare midpipe I bought fits like crap. The flanges are off like 10 degrees, and leak like crazy. When I did finally get it bolted together, the downpipe isn't hanging on the hanger right. I need to weld the crack in my old one and put that back in. P/S pump leaks, I suspect the o-ring and already have a replacement. Primed the oil with my Underdog Oil System Priming Tank™. Cranked it over a bunch without fuel just to be sure I had oil everywhere. Pulled the turbo banjo bolt just to be extra extra sure. Turned the power back on for the fuel pump and cycled the key a bunch to prime the fuel and it fired right up after a couple cranks. No CELs, BUT, it's a little noisier than I expected. had 95# of oil pressure when it started, but settled down to ~22# at idle after I took it around the block. Is that a little low? I think I'm going to have some mechanic buddies come have a listen before I do anything else, but I'm guessing maybe I need to re-lash the valves? We'll see. So not 100% good news, but not bad overall. *note - mileage was 94539 Link to comment Share on other sites More sharing options...
MrTris Posted April 20, 2015 Share Posted April 20, 2015 Hooray! You did it! Wanna move your thread to the Builds SF? Link to comment Share on other sites More sharing options...
AMileHighLGT Posted April 20, 2015 Share Posted April 20, 2015 22 at idle is ok Link to comment Share on other sites More sharing options...
Turkeylord Posted April 20, 2015 Author Share Posted April 20, 2015 Hooray! You did it! Wanna move your thread to the Builds SF?Yes please. 22 at idle is okOk, good to know, thanks. Link to comment Share on other sites More sharing options...
FJuan Posted April 20, 2015 Share Posted April 20, 2015 Oil PSI is perfect. What pistons were you using again? Does the sound quiet down after it's fully warmed up? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Turkeylord Posted April 20, 2015 Author Share Posted April 20, 2015 CP pistons. I went and started it over lunch and it sounded quieter. I took a very brief video (phone is constantly full ) that I'll upload. I didn't let it run that long. I just picked up a gallon of distilled water over lunch so I can finish filling the cooling system. I do have a question though - when I went to shut it off after running maybe 3 minutes, the temp gauge was pegged. So I checked the coolant temp with the AccessPort and it said 88 degrees. Link to comment Share on other sites More sharing options...
FJuan Posted April 20, 2015 Share Posted April 20, 2015 Piston slap? I have CP pistons too and on cold mornings it sounds like a diesel truck. After it's fully warmed up the pistons have expanded and the sound goes away. Check the coolant sensor, I read another member had the same issue after he installed his motor. I'll try to search for that thread. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
heiche Posted April 20, 2015 Share Posted April 20, 2015 could also be an air pocket - maybe top off the coolant and try again? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Turkeylord Posted April 20, 2015 Author Share Posted April 20, 2015 ^Probably true, I'll add the water when I get back up there. Here's the brief video. It's kinda hard to hear the engine over the exhaust leak. [ame=http://www.youtube.com/watch?v=gLnUzu0Xcis]Running - YouTube[/ame] Link to comment Share on other sites More sharing options...
Underdog Posted April 20, 2015 Share Posted April 20, 2015 The vid doesn't sound particularly worrisome. A new engine usually sounds a little "off" on the maiden warm-up. Pegged hot and 88 deg definitely sounds like an air pocket. Fill the rad and cap it. Fill the turbo res and squeeze the upper rad hose to help burp the system. Start the car, let it warm up until the upper res starts to overflow and cap it. Make sure the overflow tank is filled to the full line, and let the car cool down. It will draw coolant back in as the system cools. If the overflow tank runs dry then the system may draw in air. My start-up procedure is generally as follows: Prime system with Joe Gibbs BR30 break-in oil and OEM filter. 20 minute warm up with direct oil and fuel pressure monitoring, and watching vitals via RR on my laptop. Cool down - oil and filter change. Cut open filter and inspect for debris. Inspect engine bay for leaks. Replace with JG BR30 and OEM filter. If oil and fuel pressures were good then the mechanical gauges are removed. 10 minute warm up and test drive (~10 miles). Inspect engine bay, install undertray, A/C belt, engine cover, etc. Drive 100 miles before dumping the break-in oil for conventional 5W-30. Cut open second filter and inspect. Replace with OEM or Tokyo Roki. Next oil change at 1k miles with pre-tune check-up. Switch to synthetic (if desired) at 4k or 7k miles. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Turkeylord Posted April 20, 2015 Author Share Posted April 20, 2015 That sounds like a good plan. Local performance shop has a filter cutter, I think I'll pick that up. Link to comment Share on other sites More sharing options...
Turkeylord Posted April 21, 2015 Author Share Posted April 21, 2015 Adding water and squeezing the top rad hose took care of the goofy temp issue. I drove it a couple more miles and changed the oil. I cut open the filter and there seems to be quite a bit of stuff in there. I'll get a pic later. Link to comment Share on other sites More sharing options...
Turkeylord Posted April 21, 2015 Author Share Posted April 21, 2015 http://i.imgur.com/drcyrJa.jpg http://i.imgur.com/y9p1Nc7.jpg http://i.imgur.com/gu49qoJ.jpg That can't be normal. Link to comment Share on other sites More sharing options...
MrTris Posted April 21, 2015 Share Posted April 21, 2015 Eh, on first startup, I think that's pretty normal. Hard to see what's in the pan, though. Fingers crossed for you, though! Link to comment Share on other sites More sharing options...
FJuan Posted April 21, 2015 Share Posted April 21, 2015 Silver flakes like that should be ok, as long as they are not bronze. Change the oil at the 100 mile mark and see how it's doing. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Turkeylord Posted April 21, 2015 Author Share Posted April 21, 2015 Ok, we'll see how it goes. This thing makes me as nervous as a chihuahua. Link to comment Share on other sites More sharing options...
