Leonardo Posted March 22, 2008 Share Posted March 22, 2008 Bah, I got the 676 and a 677 as it was too late to cancel the 676 order(diferent vendors). I will put on sale the 676 when I get it. Link to comment Share on other sites More sharing options...
fishbone Posted April 7, 2008 Share Posted April 7, 2008 Well, I've decided to go with the Tru Cool 4452 but I am undecided now about something else. I am going Stage 2 but before I do that I want to add the cooler first. I had the tranny flushed at 35K miles and refilled with Subaru OEM fluid and also replaced the filter. Should I reflush now at 55k miles and do the BG flush, or just add the BG additive along with the cooler? What do you guys think? I don't drive the car hard and I don't torque brake but after I do all this I might just occasionally do a shy "gentle" one at most 2k rpm. Hopefully once I get my catless Autospeed UP in I won't have to. Link to comment Share on other sites More sharing options...
Leonardo Posted April 7, 2008 Share Posted April 7, 2008 Have a NIB 676 just in case anyone needs one. Link to comment Share on other sites More sharing options...
fishbone Posted April 8, 2008 Share Posted April 8, 2008 This might actually come off as a stupid question but there are absolutely no issues with installing a TruCool 4452 vertically, right? I tried google, didn't help. What's the official website for these guys, I might wanna ask them directly. Link to comment Share on other sites More sharing options...
jim1969 Posted April 8, 2008 Share Posted April 8, 2008 no problem whatsoever mounting it vertically. I have the 4454 which is larger and had no issues. The are the same size lengthwise so if you mounted it vertically there would be no difference. The 4454 is larger heightwise so if you mounted it vertically, it would take up more space L-R in front of the radiator. Link to comment Share on other sites More sharing options...
jim1969 Posted April 8, 2008 Share Posted April 8, 2008 Well, I've decided to go with the Tru Cool 4452 but I am undecided now about something else. I am going Stage 2 but before I do that I want to add the cooler first. I had the tranny flushed at 35K miles and refilled with Subaru OEM fluid and also replaced the filter. Should I reflush now at 55k miles and do the BG flush, or just add the BG additive along with the cooler? What do you guys think? I don't drive the car hard and I don't torque brake but after I do all this I might just occasionally do a shy "gentle" one at most 2k rpm. Hopefully once I get my catless Autospeed UP in I won't have to. I have had my tranny fluid flushed at 15K and 30K. I added the BG additive. Link to comment Share on other sites More sharing options...
91bulldog Posted April 21, 2008 Share Posted April 21, 2008 hey, i have a question. I just bought the 4451. Do you think the 4553 is a big difference? i';m kind of thinking twice about installing the 4451 and pickup the 4553. But regardless having a tranny cooler is better then not having one right? Do you think the 4451 is enough for stage 2? Sorry for all the questions. Link to comment Share on other sites More sharing options...
fishbone Posted April 21, 2008 Share Posted April 21, 2008 You know, I'm with you on this one. I thought the 4451 would be kinda small so I went with the 4452 and I'm STILL thinking I should have gone a bit bigger, this thing is smaller than I expected. But I think the fact that a 4452 or 4453 is positioned top-down to begin with will ensure better airflow than the 4451. Link to comment Share on other sites More sharing options...
korpsepatrol Posted April 21, 2008 Share Posted April 21, 2008 I ended up going with the 4454. So far so good. However in the beginning i was getting a leak but that was due to not tightening the o clamp or atleast i believe thats why. I saw my fluid is a little on the low side but that could be since its also running a bit cooler and the added area of the tranny cooler. I will fill it a bit more tomorrow and see. 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
2furious Posted April 21, 2008 Share Posted April 21, 2008 I ended up going with the 4454. So far so good. However in the beginning i was getting a leak but that was due to not tightening the o clamp or atleast i believe thats why. I saw my fluid is a little on the low side but that could be since its also running a bit cooler and the added area of the tranny cooler. I will fill it a bit more tomorrow and see. Did you instal in vertical or parallel? From Desert to Rocky to SLC !!! Link to comment Share on other sites More sharing options...
2furious Posted April 27, 2008 Share Posted April 27, 2008 I just my 4454 installed today and it was not so smooth but okay... I installed mine as Jim_KT did and I just used what they provided. The connector was little bigger and I managed to do it. The one thing interesting is I added about 1/3 qt of fluid to get the fluid level barely higher than Low_Hot line, actually a hole.... I use 10ml pipet to add and it was PITA. Somebody said no addition and somebody said a little... I'm not sure my case is normal.. I checked the leak several times only to find nothing... I touched the cooler and I think it's pretty hot as someone already said, as hot as metal surface on a hot day. From Desert to Rocky to SLC !!! Link to comment Share on other sites More sharing options...
Spoonwacker Posted June 2, 2008 Share Posted June 2, 2008 I did my install over the weekend, and it was surprisingly painless. The hardest part was getting the hose off of the return line - that little guy took a good 20-30 minutes of pulling before he decided to come off. I lost a little fluid, but the dipstick is showing on the high side of the gauge, so I let it be. The 4454 is a tight fit, but t0ad's pictures a few pages back show how I put it in. I thought about mounting it in the center, but decided I didn't want to risk having to go get more tubing. sorry...this forum practically blows goat nuts so im not always on here.Team Pony Express POSTED FROM MY COMPUTER USING A WEB BROWSER Link to comment Share on other sites More sharing options...
vkchu Posted June 2, 2008 Share Posted June 2, 2008 had my 4454 installed by the dealer a few weeks ago, along w/ a drain/refill + bg atc+. was told the trans filter is a 'lifetime' part so they didnt swap that out despite my suggestion they do. anyways, car is shifting nicely; noticeable improvement. Link to comment Share on other sites More sharing options...
Leonardo Posted June 4, 2008 Share Posted June 4, 2008 I have a NIB 676 if anyone needs one. Link to comment Share on other sites More sharing options...
fishbone Posted June 25, 2008 Share Posted June 25, 2008 Can't find a better place to post this and don't want to start a new thread ... Tips on installing a temp gauge and what temp gauge to go with? Link to comment Share on other sites More sharing options...
hadvw Posted June 29, 2008 Share Posted June 29, 2008 Can't find a better place to post this and don't want to start a new thread ... Tips on installing a temp gauge and what temp gauge to go with? Good question! Now that I'm off for a few days, I'm thinking of doing the transmission cooler.. Might as well put a gauge in there too.. Anyone? HV Link to comment Share on other sites More sharing options...
fishbone Posted July 24, 2008 Share Posted July 24, 2008 To answer the question I posted, I went with Prosport gauges. I got to thinking today ... If the operating temperature of the coolant is higher, sitting at around 186 and sometimes going up to 200-210, wouldn't that bring up the temperature in the tranny cooler too, since it sits flush against it? Is my logic flawed? Link to comment Share on other sites More sharing options...
iahtnoob Posted August 2, 2008 Share Posted August 2, 2008 got the tru cool 4452. lots of stuff in the bag that it comes with. all i will be using is the 4 padding squares, 4 clamps, 4 zip ties, and the 4 zip tie insert things. do i need to use any of the splices or screws, nuts and washers that come in the bag? Link to comment Share on other sites More sharing options...
srgdrum Posted August 2, 2008 Share Posted August 2, 2008 That's all I used. The rest of the hardware os for alternate mounting options. Link to comment Share on other sites More sharing options...
VTGT Posted August 2, 2008 Share Posted August 2, 2008 To answer the question I posted, I went with Prosport gauges. I got to thinking today ... If the operating temperature of the coolant is higher, sitting at around 186 and sometimes going up to 200-210, wouldn't that bring up the temperature in the tranny cooler too, since it sits flush against it? Is my logic flawed? Good question. I don't think 200-210 is terrible. I think even up to 250 is ok. But once the tranny fluid goes 250-300 it is not good from what I have heard. Link to comment Share on other sites More sharing options...
nismoz Posted August 26, 2008 Share Posted August 26, 2008 The original PDF link is dead Opie.. Link to comment Share on other sites More sharing options...
nismoz Posted August 29, 2008 Share Posted August 29, 2008 Anyone? I need to do this quick! Link to comment Share on other sites More sharing options...
TRS Posted August 29, 2008 Share Posted August 29, 2008 I think this is the same pdf... http://lesbaru.com/stuff/Transcool.pdf Link to comment Share on other sites More sharing options...
Leonardo Posted August 29, 2008 Share Posted August 29, 2008 Yep, same one rehosted! Link to comment Share on other sites More sharing options...
nismoz Posted August 31, 2008 Share Posted August 31, 2008 I just did the install today but the brass part where you connect the return line from radiator and the top of the cooler was leaking really bad. Do you guys know if auto parts stores carry the brass connection for 3/8 hoses? Link to comment Share on other sites More sharing options...
