SATSFYD Posted January 1, 2014 Share Posted January 1, 2014 I would also think the outside temps would make a big difference in the tyranny oil temp too. **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
mwm5094 Posted January 3, 2014 Share Posted January 3, 2014 ^agreed. I forgot to update this thread the other day but I got the thermostat in a took a 3 hour round trip to the casino. Temps stayed steady at 150 in about 30 degree weather. It rose quickly if I stepped into the throttle but quickly fell back down once I let off. When I pulled off the highway, temps were around 157-175 depending on if I was accelerating or not. No I guess the thermostat never opened and it was doing its job. Time will tell if anything changes in higher temps. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 27, 2014 Share Posted February 27, 2014 I keep having customers over-cooling their ATF because they plumbed their coolers wrong. You can hardly tell with a stock valve body, but with a modified valve body it can make the transmission unhappy. In either case, it's not good. Enjoy: http://legacygt.com/forums/showthread.php/properly-plumb-your-5eat-transmission-cooler-221643.html?p=4743891#post4743891 [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
SATSFYD Posted February 27, 2014 Share Posted February 27, 2014 Now I am not expert but... on the Hayden website: http://www.haydenauto.com/Installation-FAQs/Content.aspx it states this: Q. Should the cooler be installed before or after the radiator? A. Hayden recommends installing the auxiliary cooler after the radiator to return the coolest fluid directly to the transmission. Installing the cooler before the radiator will still provide additional cooling and may be necessary in some difficult access applications. Q. Can you over cool the transmission fluid? A. Transmissions are not highly sensitive to cool operating temperatures. However, in sub-zero (20-30° F) weather conditions transmission fluid can actually gel up in an external cooler and cease to flow, causing damage. Use of the radiator cooler actually helps warm the fluid under these conditions. It is critical in extreme cold conditions to use the original equipment cooler in series with the auxiliary cooler and allow the vehicle to warm up before driving. So this statement makes me ask this: What damage does a over cooled transmission beget? **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
MrTris Posted July 21, 2014 Share Posted July 21, 2014 Bump for an answer to the above. If the only downside to overcooled ATF is harder shifting, then what's so bad about it? Also, does this mean that in colder temps, one must drive faster/harder to overcome overcooled ATF symptoms? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 21, 2014 Moderators Share Posted July 21, 2014 Bump for an answer to the above. If the only downside to overcooled ATF is harder shifting, then what's so bad about it? Also, does this mean that in colder temps, one must drive faster/harder to overcome overcooled ATF symptoms? It might *feel* like harder shifts at times with cold fluid, but I believe the reality is that the clutch packs are more likely to slip with cold fluid, and that's what causes damage. You could drive harder, but you are best to have a setup that takes care of itself, I.e the proper sequence of a transmission cooler and a fluid thermostat. I'm on my phone so can't really search, but I think climberd has a thread on that as well. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
meinestrasse Posted March 13, 2015 Share Posted March 13, 2015 If anyone is following the directions in the Transcool.pdf file, there is a BIG mistake in Step 8. The hose and line towards the FRONT of the car is the transmission return line (not towards the rear). I swiped the images below from another forum. Link to comment Share on other sites More sharing options...
aziankingz Posted July 14, 2015 Share Posted July 14, 2015 anyone confirm this? is the return line the line towards the rear or the front of the car? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 14, 2015 Moderators Share Posted July 14, 2015 I just want to confirm the flow of ATF through the system. I'm installing a fluid thermostat to prevent overcooling the fluid and I have to be 100% sure of the direction so I finally bit the bullet--unhooked the lines and started the car. With 100% certainty, the line towards the rear of the car (without the inline filter) is the return line. From what I gather, this means that the stock system goes from transmission, through the filter, into the radiator, out of the radiator, back to the transmission. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 14, 2015 Moderators Share Posted July 14, 2015 Mine install was on an '05 LGT wagon if anyone cares. But the quote above is from my own install and the actual car in question pumping fluid out of the hose when started. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
aziankingz Posted July 14, 2015 Share Posted July 14, 2015 Cool thanks BMB! Link to comment Share on other sites More sharing options...
BierSnob Posted July 20, 2015 Share Posted July 20, 2015 Any pics of the fluid thermostat install? I have been running a standalone cooler and Radiator for about 3 years now . No thermostat but my temps don't usually go below 15-20 degrees F. I have seen somewhere in this thread a statement about lock-up not taking place until 160*F so i assume there is slipping? any input? Does any one know where the info is? i looked but could not find it. it really matters to me with an 05 wagon that makes 350 whp. Any help would be appreciated. Thanks and apologies for the redundancies in advance. Link to comment Share on other sites More sharing options...
quick4dr Posted July 20, 2015 Share Posted July 20, 2015 mounted mine inside the front bumper Link to comment Share on other sites More sharing options...
HellShadow70 Posted July 21, 2015 Share Posted July 21, 2015 Any pics of the fluid thermostat install? I have been running a standalone cooler and Radiator for about 3 years now . No thermostat but my temps don't usually go below 15-20 degrees F. I have seen somewhere in this thread a statement about lock-up not taking place until 160*F so i assume there is slipping? any input? Does any one know where the info is? i looked but could not find it. it really matters to me with an 05 wagon that makes 350 whp. Any help would be appreciated. Thanks and apologies for the redundancies in advance. Go to page 28 on this thread. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 23, 2015 Share Posted August 23, 2015 Finished up my trans cooler. http://images.tapatalk-cdn.com/15/08/23/b865f1add788a74224ac80aec3e52e56.jpg http://images.tapatalk-cdn.com/15/08/23/16cefa8efafda8b16ba309c4ed283580.jpg http://images.tapatalk-cdn.com/15/08/23/3f6263fbc2029c4526c146ffea46d500.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
07wrxstage2 Posted August 24, 2015 Share Posted August 24, 2015 Can anyone tell me for sure if I can mount the 4452 if I have hellas in the front with subimods bracket? I looked through here and saw one person went with the 4451 because he was worried about fitment with hellas but I didn't see any definite answer. From the pics I see of some installs it appears it could fit snug. Im aware you have to install the 4452 and 4454 vertically. Thanks for any help. Edit: Nvm I just looked at some pics I had with my grille off and it doesn't look like it will fit with the tc needing to be mounted vertically. I'll have to go with the 4451 I guess. Alex D. JDM Prestige Motors alex@jdmprestigemotors.com Link to comment Share on other sites More sharing options...
HellShadow70 Posted August 24, 2015 Share Posted August 24, 2015 Can anyone tell me for sure if I can mount the 4452 if I have hellas in the front with subimods bracket? I looked through here and saw one person went with the 4451 because he was worried about fitment with hellas but I didn't see any definite answer. From the pics I see of some installs it appears it could fit snug. Im aware you have to install the 4452 and 4454 vertically. Thanks for any help. Edit: Nvm I just looked at some pics I had with my grille off and it doesn't look like it will fit with the tc needing to be mounted vertically. I'll have to go with the 4451 I guess. I have a 4454 mounted with Hellas and subimods bracket. Link to comment Share on other sites More sharing options...
07wrxstage2 Posted August 25, 2015 Share Posted August 25, 2015 I have a 4454 mounted with Hellas and subimods bracket. Really? That's great news. Got any pics? Would like to see exactly where you mounted it and how it looks. Thanks. Alex D. JDM Prestige Motors alex@jdmprestigemotors.com Link to comment Share on other sites More sharing options...
HellShadow70 Posted August 25, 2015 Share Posted August 25, 2015 Really? That's great news. Got any pics? Would like to see exactly where you mounted it and how it looks. Thanks. Here you go. http://images.tapatalk-cdn.com/15/08/25/ceb14540cca85f5c9061b06a5402c34e.jpghttp://images.tapatalk-cdn.com/15/08/25/1d3f0707eb80115fe1b0387baecdd2c2.jpghttp://images.tapatalk-cdn.com/15/08/25/c32f11efda4dd8989522225dbd655e29.jpghttp://images.tapatalk-cdn.com/15/08/25/8f0e248f894dc647abc65ac8c74af9ac.jpg Link to comment Share on other sites More sharing options...
07wrxstage2 Posted August 25, 2015 Share Posted August 25, 2015 Here you go. Thank you very much! Alex D. JDM Prestige Motors alex@jdmprestigemotors.com Link to comment Share on other sites More sharing options...
HellShadow70 Posted August 25, 2015 Share Posted August 25, 2015 Thank you very much! Your very welcome. Had to lay down on the ground to take those but i was in uniform so it didn't mater, all in a days work. you can also see some more pics, Go to page 28 post 406 and 407 on this thread. Link to comment Share on other sites More sharing options...
