bomberlegacy Posted November 10, 2012 Author Share Posted November 10, 2012 well she has a full tank of e85 and is running. I drove around the block very slowly and its pretty smooth and whiney 2am so only working with a flashlight, but my intercooler has one small fitting leak, my boost gauge reads ambient at all times, my cel is on and cruise is flashing. smoking a lil out of the exhaust too but I expected that. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 11, 2012 Author Share Posted November 11, 2012 Cel was for it running rich. Good deal I'm babying it, it doesn't like to idle coming back down from higher rpm.. When coming coming to a stoplight, etc.. Bogs down a bit during acceleration some but it's still way quicker than before oh the exhaust smells like beer haha '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
CasopoliS Posted November 11, 2012 Share Posted November 11, 2012 I have concerns with the MAF location, at least with the stock MAF... but I could be wrong. What do you have controlling the water pump? Does it run all the time? Do you have a water filler port at the top of your lines, or are you using a reservoir? Just make sure you bleed the air out. Props for taking on a brave project. Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 11, 2012 Author Share Posted November 11, 2012 What issues would I have with the MAF location? The pump runs when the key is on, but I plan on installing a switch in the future. I don't have a filler cap right now, I filled it with a long hose using gravity to help. Not perfect I know but it's the best I can do until I find a tank I like. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 12, 2012 Author Share Posted November 12, 2012 I just noticed.. I've gone 94 miles on 1/2 a tank and I've been babying it. Hah the rich CELs make sense '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
Haight 05LGT Posted November 12, 2012 Share Posted November 12, 2012 I just noticed.. I've gone 94 miles on 1/2 a tank and I've been babying it. Hah the rich CELs make sense Holy hell. Thats approx. 11mpg....ouch Link to comment Share on other sites More sharing options...
That Guy 2-1 Posted November 12, 2012 Share Posted November 12, 2012 Holy hell. Thats approx. 11mpg....ouch that's about how much my built Camaro used to do on a good day, lol Link to comment Share on other sites More sharing options...
That Guy 2-1 Posted November 12, 2012 Share Posted November 12, 2012 nice progress, awaiting some numbers! Link to comment Share on other sites More sharing options...
m_dogg Posted November 12, 2012 Share Posted November 12, 2012 I just noticed.. I've gone 94 miles on 1/2 a tank and I've been babying it. Hah the rich CELs make senseSounds about right. I was getting 200 miles MAX out of 17gal tank in my Regal on e85. Link to comment Share on other sites More sharing options...
bigjweb Posted November 12, 2012 Share Posted November 12, 2012 You just driving it around with no tune? Do you plan on going stand alone? I don't see how an N/A ecu could ever account for what a turbo ecu can. Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 12, 2012 Author Share Posted November 12, 2012 No I got my base tune. It needs work but it's running pretty decent '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
CasopoliS Posted November 12, 2012 Share Posted November 12, 2012 What issues would I have with the MAF location? It was not designed for a blow-through setup. Potentially non-consistent turbulence post SC which might be hard to tune around. You could see some hesitations or non-smooth acceleration? I have no clue, every setup is different, and this one is certainly unique. Just my first thought when I saw it. Regarding the water pump, I'm not sure anything is wrong about running the pump all the time if you hooked it up to ignition 12v. The best is to run it off delta IAT, the true indicator of your intercooler performance. But, that requires custom gadgetry and smarts. And its overkill probably. Link to comment Share on other sites More sharing options...
ripemeat Posted November 12, 2012 Share Posted November 12, 2012 MAF's aren't designed to take positive pressure, that's why speed density uses a map sensor in the charge tubes. Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 12, 2012 Author Share Posted November 12, 2012 Good points, they make sense.. I've just been going along with the Raptor kit instructions. I guess we will see how it goes when I go in for my dyno tune. The intercooler seems to do quite well, I drove around for a while last night and my under hood temps were roughly 125 according to my trans temp sensor that is just zip tied under there.. And the intercooler is ice cold to the touch. The pump doesn't get hot either. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
dgoodhue Posted November 12, 2012 Share Posted November 12, 2012 I had an aftermarket supercharged corvette that had the MAF sensor between the SC and intake manifold. I do however notice most MAF are pre turbo or SC. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted November 12, 2012 Share Posted November 12, 2012 How long till your pro tune?? Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 12, 2012 Author Share Posted November 12, 2012 I stopped by the exhaust shop today and had new 2.5" pipe welded in place of the oem pipe. They wouldn't remove the 2nd cat but the larger pipe and open y-pipe gave me some more boxer rumble *edit* it sounds more raspy in this video than in person, for some reason. its just deep and rumbly(is that a word??) in person. [ame=http://www.youtube.com/watch?v=Nr8pc2OZNVQ&]new exhaust[/ame] '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 12, 2012 Author Share Posted November 12, 2012 How long till your pro tune?? I hope to get it done early December.. I have a few things left to complete before I head down there. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 12, 2012 Author Share Posted November 12, 2012 I previously just had the oem pipe with Magnaflow mufflers and Vibrant resonator. The shop did a terrible job lining the tips up in the cutouts, so I had all new pipe done today and it looks/sounds much better. http://i1289.photobucket.com/albums/b514/sclegacy08/rps20121112_162725_zps84f07471.jpg http://i1289.photobucket.com/albums/b514/sclegacy08/rps20121112_162747_zps9ce7b1da.jpg New photos of the gauges. I think I got a bad sender for the boost gauge. I have verified the wiring and the vacuum plumbing and it all seems fine, but the gauge stays pegged at 30"Hg http://i1289.photobucket.com/albums/b514/sclegacy08/rps20121112_162807_zps2e303769.jpg http://i1289.photobucket.com/albums/b514/sclegacy08/rps20121112_162836_zpsb9ec0d7c.jpg Lights on http://i1289.photobucket.com/albums/b514/sclegacy08/rps20121112_162854_zpsf2a5225c.jpg '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
modernfuse Posted November 15, 2012 Share Posted November 15, 2012 Looking good man, now you just need that leather steering wheel upgrade Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 15, 2012 Author Share Posted November 15, 2012 Haha and an auto dimming mirror. Maybe after I recover from this project '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
schado Posted November 15, 2012 Share Posted November 15, 2012 Haha and an auto dimming mirror. Maybe after I recover from this project Ha, that shouldn't take long. 08 NBP Legacy GT BNR16G E85 13 WRB WRX. TBE & Tune 07 FXT Sports. Stock Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 16, 2012 Author Share Posted November 16, 2012 Lol, overtime! '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 16, 2012 Author Share Posted November 16, 2012 Boost gauge works now. I rewired both gauges to the cigarette lighter below the stereo, and guy at Prosport said the clock harness voltage varies too much for two gauges to work. Now my temp reading flashes '97 but the bottom of the 7 is cut off. Odd '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 16, 2012 Author Share Posted November 16, 2012 Some how blew my turn signal fuse. Fixt. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
