pjcampbell Posted November 20, 2017 Share Posted November 20, 2017 Hi Wes, Do you think if I ran 100 octane I could run your 51mm pulley? Actually thinking of 93 octane + 1 can of Torco per tank which should put me right at 100 octane - which I guess would be pretty similar to E85 in terms of octane rating. Any idea what that 51mm pulley will peak for boost at around 6000-6200 rpm? 10... 11 psi? I think that is about the limit of the Raptor? Link to comment Share on other sites More sharing options...
bomberlegacy Posted December 16, 2017 Author Share Posted December 16, 2017 Hi Wes, Do you think if I ran 100 octane I could run your 51mm pulley? Actually thinking of 93 octane + 1 can of Torco per tank which should put me right at 100 octane - which I guess would be pretty similar to E85 in terms of octane rating. Any idea what that 51mm pulley will peak for boost at around 6000-6200 rpm? 10... 11 psi? I think that is about the limit of the Raptor? Sorry I didn’t see this! We chatted thru email but I totally missed this. My bad '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
