jmorris6689 Posted August 14, 2013 Author Share Posted August 14, 2013 It flew out in Arkansas because they have yet to figure out how to pave roads there. I hit a bunch of dips and pot holes and I guess when it came down one time the tire caught the liner and ripped it out and spit part of it onto the interstate. Also the front drivers cv axle is spraying grease. But I have a spare axle so ill put that in soon as my stuff arrives in knoxville. Link to comment Share on other sites More sharing options...
jmorris6689 Posted August 15, 2013 Author Share Posted August 15, 2013 http://i499.photobucket.com/albums/rr353/jmorris6689/null-58.jpg Link to comment Share on other sites More sharing options...
Z0rr0 Posted August 15, 2013 Share Posted August 15, 2013 Lookin' good. Keep me posted on how the car is doing.. either via text or here.. should be a fun ride Link to comment Share on other sites More sharing options...
jmorris6689 Posted August 19, 2013 Author Share Posted August 19, 2013 Started my job today, upgrades will be on the way soon... Link to comment Share on other sites More sharing options...
compression Posted August 21, 2013 Share Posted August 21, 2013 I remember when I graduated college, I had to save for a couple weeks just to afford to fill my car up with gas....kids these days..... Good read. Glad you are sticking with it. Super motivated for sure. I would have said F-it. Throw a stock short block in it and sell the thing and start over with a Supra to run 10's without breaking a sweat. ha haha.. good luck! Link to comment Share on other sites More sharing options...
jmorris6689 Posted August 28, 2013 Author Share Posted August 28, 2013 I'm gonna get it retuned hopefully next weeks to start to make some real power on this 20g. Soon as I can afford it I'm going to look at getting a new turbo one that is bigger than my arm cxr550. Link to comment Share on other sites More sharing options...
jmorris6689 Posted December 3, 2013 Author Share Posted December 3, 2013 Long over due for an update. The car is doing well, the motor has over 7000 miles on it. Been working a lot so I haven't had it tuned past the break in map. But since I've been working so much I have started to save and purchase parts for the upgrades I'm about to start on over the next few months. I'm getting a bloush 5.0xtr turbo, new up pipe and external waste gate, id1000 top feed injectors, new tgvs, top feed fuel rails, new larger solid turbo inlet, new larger intake and maf, new catback, and depending on power output possibly a new dual disc clutch and drive shaft. So that being said I'll have some parts for sale soon... Since I've gotten the car back I've redone the brakes and bought some nice sticky tires. Come next fall I'm hopfully going to finally make a sub 11sec pass... Link to comment Share on other sites More sharing options...
Th3Franz Posted December 4, 2013 Share Posted December 4, 2013 5.0 xt-r? Isn't that too big for a stock location turbo? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
jmorris6689 Posted December 4, 2013 Author Share Posted December 4, 2013 That's what I was told when I put in te cxr550 but it fit just fine. I might have to do a little grinding Link to comment Share on other sites More sharing options...
thisisthenewsic Posted December 5, 2013 Share Posted December 5, 2013 Why not switch to a rotated setup? Since you are already replacing the uppipe Ect. Also no e85? Link to comment Share on other sites More sharing options...
jmorris6689 Posted December 5, 2013 Author Share Posted December 5, 2013 It would be a good deal more expensive Link to comment Share on other sites More sharing options...
thisisthenewsic Posted December 6, 2013 Share Posted December 6, 2013 The 5.0xtr is a 2000$ turbo. You could easier put together a rotated uppipe precision turbo and downpipe for that price. Or even a single scroll borgwarner turbo setup Link to comment Share on other sites More sharing options...
jmorris6689 Posted December 6, 2013 Author Share Posted December 6, 2013 True, but I'm not paying $2000 for it. Link to comment Share on other sites More sharing options...
TeriyakiBBS Posted December 20, 2013 Share Posted December 20, 2013 did you upgrade your FPR to aftermarket or 04-07 STi? or just running the stock FPR? Thanks Link to comment Share on other sites More sharing options...
derp Posted December 20, 2013 Share Posted December 20, 2013 Just read this thread from page 1 to here. Quite the journey you've had, your persistance is near crazy person level Good to see it ended well. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
jmorris6689 Posted December 20, 2013 Author Share Posted December 20, 2013 I'm running an areomotive fuel pressure regulator. It's adjustable and it also rises on a 1:1 ratio of lbs of boost to lbs of fuel. Link to comment Share on other sites More sharing options...
wuuusaa Posted December 22, 2013 Share Posted December 22, 2013 Just read this thread from page 1 to here. Quite the journey you've had, your persistance is near crazy person level Good to see it ended well. Truth right there Link to comment Share on other sites More sharing options...
jenzos Posted February 18, 2014 Share Posted February 18, 2014 Great thread read. I'll be coming for you next year. Link to comment Share on other sites More sharing options...
jmorris6689 Posted April 11, 2014 Author Share Posted April 11, 2014 Update just ordered top feed id1000 injectors and fuel rails, bigger turbo is going on the car soon... Link to comment Share on other sites More sharing options...
jmorris6689 Posted May 19, 2014 Author Share Posted May 19, 2014 Finally got the car tuned. It was tuned on the 850cc injectors and the 20g that was used to break the engine in. Car made 350whp on 17psi and 365ftlbs. The 1000cc top feeds, fuel rails, larger lines, and regulator are here but I'm going t wait until I get a bigger turbo than my amr550 to install it all. Going to try and push past 500whp. Then it's off to the drag strip for the hopeful sub 11 second pass Link to comment Share on other sites More sharing options...
Th3Franz Posted May 21, 2014 Share Posted May 21, 2014 Which 20G is it? Those numbers seem optimistic for only 17 PSI. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
1055 Posted May 25, 2014 Share Posted May 25, 2014 If you cant crack 11 seconds with 500whp.... Link to comment Share on other sites More sharing options...
1055 Posted May 25, 2014 Share Posted May 25, 2014 Sounds like dynojet numbers Link to comment Share on other sites More sharing options...
jmorris6689 Posted May 27, 2014 Author Share Posted May 27, 2014 It is a dyno dynamics dyno. I'll post a dyno pic when I get home. Honestly I do t remember which 20g this is. I got it cheap from a shop in az when motor 4 let go and my amr was full of engine bearing material. This turbo was purchased to break in the motor Link to comment Share on other sites More sharing options...
BoyceWare Posted June 3, 2014 Share Posted June 3, 2014 awesome thread. Subbed, looking forward to an update. Link to comment Share on other sites More sharing options...
