Shooting for 10's on my daily driver
Well i too have been all over the place but just not for as long as you. But work has been super busy, hence why I can afford to buy all this stuff for it. But no it has not hit the dyno yet, I'm waiting on powder coating and the new accessport to come in to get it tuned. Hopefully I'll have the car this weekend if not it will be sometime next week. So soon as I have it back I guarantee you I'll be at a meet to finally pop my hood with pride. So I hope to see you out there soon, until then take it easy and don't work too many hours
  • 2 weeks later...
Updates, so the car is still at the shop for the tuning, but the fab work is all done and it looks amazing. I have also gotten a few new items to take care of some issues the legacy has had for years. I finally got my coilovers in, I got a set of bc br coilovers with the swift springs 10k front 8k rear. That should help with all the squating my car does when it accelerates, that and my rear struts have been blown for a very long time. I also picked up a set of wilwood 4 pot brakes and 14" rotors for the front of the car, should help slow it down a little more then before. The car is supposed to be finished up with the tuning on Tuesday. So soon as it's back I'll toss the rest of my new stuff on it.
http://i499.photobucket.com/albums/rr353/jmorris6689/AC38D510-C193-431E-8F9A-C092EA43624A.jpg
http://i499.photobucket.com/albums/rr353/jmorris6689/037A38D6-3DBE-41E4-9D84-15C282D290D9.jpg
Also here is the latest mod list
2006 Subaru Legacy gt limited sedan
Engine:
Ej255 case halves
Manly h beam rods
JE pistons
2013 STi crank
King main and rod bearings
Killer bee oil pick up
B25 ported and polished heads
Gsp 272 cams single avcs
Gsp springs
Gsp titanium retainers
Stock valves
Slight combustion chamber porting
Tgv deletes
Grimmspeed spacers
Grimmspeed ebcs
Grimmspeed aos
STi intake manifold
STi 11mm oil pump with shims
Gates Kevlar timing belt
Ngk 1 step colder spark plugs
Perrin pitch stop
Fueling:
Aeromotive fuel rails
Upgraded fuel lines between the rails
Fuel lab adjustable fpr
Injector dynamics 1000cc top feed injectors
Walbro 460 in tank pump
Turbo and cooling:
Avo fmic
Custom rotated piping powder coated white
Borg Warner 300sx e 8776
Misimoto racing radiator
Mishimoto radiator hoses
Mishimoto 180* t stat
Avo radiator shroud
Tial bov
Ptp t3/t4 turbo blanket
Drivetrain and brakes
05 STi 6 speed
Act 6 puck extreme duty un-sprung clutch
2010 STi shifter linkage
2005 legacy 4eat drive shaft
07-09 spec b rear axles
Stock front axles
Dba 4000 rear rotors
Hawk hp + rear pads
Atf brake fluid
Wilwood 4 pot calipers
Wilwood front braided stainless steel lines
Wilwood 14" front rotors
Wilwood racing front pads
Suspension
Bc br coilovers
Swift springs 10k front 8k rear
Cusco front strut tower bar
Moog endlinks
Exhaust and intake:
Tomei uel header
Custom rotated up pipe
Custom rotated downpipe
Magnaflow 3" cbe
4" inlet
k&n 6" filter
Tial 44mm wastegate
Ecu and tuning:
Cobb accessport v3
4bar omni map sensor
Iat sensor
Tuned on Cobb speed density
Fasttech dyno tuned
Other:
Hella horns
Custom painted headlights
Tinted tail lights
Enki rpf1 18X8.5 +35 wheels
Hankook Ventus v12 tires 255/35/18
Innovate lm2 wide band
Prosport oil pressure gauge
Lamco factory STi boost gauge
93 for now, I'm waiting on Cobb for the e85 switch. Also I'm busting my ass trying to get as much side work knocked out as I can so that later this year I can go with a new block, probably going to go with a IAG closed deck stage 4x and also get some new heads while I'm at it
  • 2 weeks later...
So I got the car back on Friday and it is pretty rowdy. Car made 380whp on 17lbs 440whp on 22lbs and 477whp on 24lbs. All on 93oct of course. The injectors are maxed out. So soon I'll start working on the new fuel setup. Also got the front coilovers installed on Saturday but ran into a super tight bolt in the rear so ill have to grab one of my impacts from work today and try and get it finished up tonight. I'll post some pics of the dyno sheets
Yeah I tried a few different penetrating oils and a torch with no luck. But all I had with me was some wrenches and a ratchet with a metric socket set. So I'll bring home my impacts tonight and hopefully get it wrapped up and re aligned that way I can mark this task off the list. Then I suppose it's time to install my new to me bbk
  • 3 weeks later...
  • 4 months later...
update: car is still running strong, a few months back I quit my job in Tennessee, and moved back to charlotte nc and got a new job doing the same thing I used to do but for a different company. I enjoy my new company much more and the pay increase is nice as well. That being said my wife and I are trying to buy a house this year and that means no big spending sprees until the house is purchased, so no new block until the house is purchased. A few months ago the tomei uel header let go and I replaced it with a tomei el header, not sure if I made any real power gains since it has not been put on a dyno but the car pulls nice and smooth all the way to 8k. I still have not installed the wildwood bbk that I bought last year so when I get some down time Ill have to install them. Im still in search of a shop here in charlotte that can help me reach my goals of 1000whp legacy. But hopefully later this year I can re focus on the car and start making some waves once again. Until then Im re doing the fueling system to be ready for e85 and some minor exterior mods.
