nossy Posted April 9, 2015 Share Posted April 9, 2015 Do we know if the '15 WRX "downpipe" fits? Link to comment Share on other sites More sharing options...
GTEASER Posted April 9, 2015 Share Posted April 9, 2015 I seem to remember someone (like grimmspeed or nameless) saying that the 2015 WRX downpipe (j-pipe) is different from our enough that they are not interchangeable. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
s2baru Posted April 9, 2015 Share Posted April 9, 2015 Theyre considerably different. Helped a friend install his exhaust on his 15wrx just to compare things and iirc is shorter and also a bit tighter of a bend. Link to comment Share on other sites More sharing options...
nossy Posted April 9, 2015 Share Posted April 9, 2015 Thanks gentleman. I assumed that was the case but didn't see anything explicitly stated in any of my searching here/NASIOC. Link to comment Share on other sites More sharing options...
GTEASER Posted April 9, 2015 Share Posted April 9, 2015 Thanks gentleman. I assumed that was the case but didn't see anything explicitly stated in any of my searching here/NASIOC. You may be interested in participating in a group buy here. Check out the thread. http://legacygt.com/forums/showthread.php/tuner-review-nameless-tbe-236586p7.html?highlight=nameless+tuner GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Zakster87 Posted April 9, 2015 Share Posted April 9, 2015 Beat me to it GTeaser. Link to comment Share on other sites More sharing options...
nossy Posted April 9, 2015 Share Posted April 9, 2015 I've seen the thread, just more than I can probably swing right now. Car is currently at Infamous getting the motor rebuilt which is setting me back 6k, so my curiosity is more aimed at opening up my options for used parts. Link to comment Share on other sites More sharing options...
brandon.mol Posted April 10, 2015 Share Posted April 10, 2015 I've seen the thread, just more than I can probably swing right now. Car is currently at Infamous getting the motor rebuilt which is setting me back 6k, so my curiosity is more aimed at opening up my options for used parts.   http://legacygt.com/forums/showthread.php?t=239055 Link to comment Share on other sites More sharing options...
Boosted balls Posted April 21, 2015 Share Posted April 21, 2015 I'm about to pull the trigger on a set of 2012 WRX struts to upgrade my saggy, floppy 120k mile struts on my 2011 Legacy. It appears that I can use 2008 on up struts but I want confirmation before buying a set of struts that I will have to resell. Thanks!!! Link to comment Share on other sites More sharing options...
Zee199969 Posted April 21, 2015 Share Posted April 21, 2015 The rears should swap out plug and play style. Not sure if the front housings are exactly the same though My "Build" Link to comment Share on other sites More sharing options...
GTEASER Posted April 21, 2015 Share Posted April 21, 2015 I'm about to pull the trigger on a set of 2012 WRX struts to upgrade my saggy, floppy 120k mile struts on my 2011 Legacy. It appears that I can use 2008 on up struts but I want confirmation before buying a set of struts that I will have to resell. Thanks!!! Rears are directly swappable.  Fronts are NOT a direct fit. The spring perch on the 2008+ WRX front struts is welded onto the front strut tube 1/2" lower than the Legacy struts. You will have tire clearance issues between the tire and perch (WRX uses smaller diameter tire) and your car will be dropped 1/2" in the front. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Boosted balls Posted April 21, 2015 Share Posted April 21, 2015 Ok, so the rears will go right in. Perfect, most of the sloppiness is in the rear. As far as the fronts, can I relocate the mounts or will the heat generated from welding toast the seals inside?  If I go with the WRX rears, what would be the best struts for the front to match?  There is also a ton of roll in the corners. I understand that an STi rear sway bar will fit but will that tighten up the rear too much? Would a regular WRX sway bar be better? I have to do something because the rear is almost out if control on some bouncy corners. Link to comment Share on other sites More sharing options...
GTEASER Posted April 21, 2015 Share Posted April 21, 2015 Ok, so the rears will go right in. Perfect, most of the sloppiness is in the rear. As far as the fronts, can I relocate the mounts or will the heat generated from welding toast the seals inside?  If I go with the WRX rears, what would be the best struts for the front to match?  There is also a ton of roll in the corners. I understand that an STi rear sway bar will fit but will that tighten up the rear too much? Would a regular WRX sway bar be better? I have to do something because the rear is almost out if control on some bouncy corners. Don't relocate the spring perches!! Just get 2013+ Legacy OEM replacements all around, they are a little stiffer than your originals. And skip the WRX shock thoughts. You can go with a 22mm Whiteline RSB and it will improve things greatly and not be too "tight". It you want a real improvement in shocks, go with Koni's. Please do some research by using the search function. All of this has been covered on this forum. Also, this thread is meant for info, not discussion.  Try this thread for a start, and read. http://legacygt.com/forums/showthread.php/5th-gen-legacy-suspension-mods-203293.html GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Boosted balls Posted April 21, 2015 Share Posted April 21, 2015 I've done a ton of reasearch (including that link) and I was just looking for clarification and direction. I am not trying to spend a fortune on a DD. I am very pleased with the STI setup that I installed on my 91 turbo legacy, and I was hoping for a similar option for my 2011- Great and cheap solution. Thanks for advice on the Konis. I'll now research which Konis, inserts or complete package, spring options, etc. Link to comment Share on other sites More sharing options...
GTEASER Posted April 21, 2015 Share Posted April 21, 2015 WRX '08+ Koni's fit our cars. And get a Whiteline BSR49XZ 22mm RSB, you won't regret it. 8610-1453S Front inserts 8010-1055S Rear shocks Hey...you have a '91 SS? . . . << Look! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Boosted balls Posted April 21, 2015 Share Posted April 21, 2015 Perfect! Thanks! I'll order those. Yes, I have a 91 SS running vf39, equal length stainless header, 3" stainless turbo back. Custom wta intercooler, 100hp nitrous, eim management, sti struts and springs, GT sway bars, gt wheels. This thing is a ton of fun on the dirt roads on the hills where I live. Link to comment Share on other sites More sharing options...
raguilera510 Posted May 11, 2015 Share Posted May 11, 2015 I am looking to get the "Boxer Rumble" on my 2010 legacy na... I have seen posts mentioning that the 08-10 WRX cat back will bolt right into my car is that true??? I dont wanna go and buy that and come to find out I have to modify a lot.... I recently removed the stock muffler and left the straight pipe, it sounds nice, but I know a dual exhaust set up with muffler would be more efficient and probably sound better... Any one else on this 5th gen na boat with me? I would love to see what ideas you have to mod these babies! Link to comment Share on other sites More sharing options...
Sarang Posted May 11, 2015 Share Posted May 11, 2015 Any one else on this 5th gen na boat with me? I would love to see what ideas you have to mod these babies! http://legacygt.com/forums/showthread.php/5th-gen-exhaust-236990.html Link to comment Share on other sites More sharing options...
GTEASER Posted May 11, 2015 Share Posted May 11, 2015 A stock WRX catback is not gonna give you "boxer rumble". That comes from the unequal length (UEL) headers that most Subaru turbo motors have. Subaru NA cars have equal length (EL) headers. I believe there is one company that makes UEL headers for the 5th Gen. PM reeg420, I think he has them on his car. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
fahr_side Posted May 12, 2015 Share Posted May 12, 2015 A stock WRX catback is not gonna give you "boxer rumble". That comes from the unequal length (UEL) headers that most Subaru turbo motors have.  The sound of inefficiency. Why not unplug one of your injectors if you want to replicate that blub blub noise? Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
JoeBlackGT Posted May 12, 2015 Share Posted May 12, 2015 Might be the wrong place to ask, but my searching has got nowhere. I was told today my LGT has a VF38 turbo. The guys on the 4th Gen forum were very surprised at this. Can anyone clear this up? It's a Auto NZ LGT. Link to comment Share on other sites More sharing options...
jackal8788 Posted May 12, 2015 Share Posted May 12, 2015 Might be the wrong place to ask, but my searching has got nowhere. I was told today my LGT has a VF38 turbo. The guys on the 4th Gen forum were very surprised at this. Can anyone clear this up? It's a Auto NZ LGT. I believe the twin sroll VF38 was used on previous gens of the Liberty/Legacy (non USDM) with a 2.0 liter engine. You've got a 2.5 liter with the single scroll VF54 turbo. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
JoeBlackGT Posted May 12, 2015 Share Posted May 12, 2015 Thanks jackal8788. Â Â Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
marcin93 Posted June 1, 2015 Share Posted June 1, 2015 Im getting a lot of questions asking if my tein lowering springs from my 5th gen will fit a 4th gen (05). I just wanted to make sure that these do NOT fit for my state of mind. Thanks. Link to comment Share on other sites More sharing options...
GTEASER Posted June 1, 2015 Share Posted June 1, 2015 ^^ They do not. Completely different rear suspension designs. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
