Racer X (itsme) FMIC install
itsme
  • Replies 1.2k
  • Created
  • Last Reply
  • Mega Users
The stock airbox fits fine. I ran it the entire time I had my RacerX.
Mine did not fit fine. I had the same issues that Chris had where the intake thing that runs to the front of the car was crooked. It bugged me to much, so I power slammed the airbox to try to get it to straighten out and it broke
"Remember Danny - Two wrongs don't make a right but three rights make a left."
  • Mega Users
Oh so you hicksta'd your airbox
precisely. I'm gonna buy a new one this week from another subaru human in CT. Round 2
  • Mega Users
I greased these t clamps that connect to the core.
This car sees a lot of salt. and after only 1 winter, there was a lot of corrosion. I'm hoping some all weather grease will prevent it from getting out of hand. The clamps/couplers on each end are also covered by a copper pipe covers, similar to the material that they make for pool toys (aka noodles).
  • Mega Users
yeah, i tried to switch back to stock for a OTS and no go
there is a trick to it. its frustrating as hell but it will work. PM me if you need help. ill guide you thru it.
I got 20k on my RacerX FMIC. I was checking the "rub spots" why'll I had the car in the air. Plugging a hole in the PS front tire. Pics. of what I found.
A flat spot starting to wear from the peace of hose I put on the tow loop.
http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/th_0519122209.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/th_0925112218.jpg
So I change it around & put the hose on both IC pipes.
http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/th_0519122223a.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/th_0519122223.jpg
I know others have done the something with their tow loops. Just thought I give you a head up & check your pipes.
Mike
Mileage:331487 Retired/Sold
  • 2 weeks later...
Bryan, can you pm me a price for the fmic kit with black piping and black core please. Looking to do asap cause i have my tune in a week. Thanks
PM sent
Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com
  • 2 weeks later...
Ok, I have the new revised kit. I shortened the throttle body pipe to make more clearance for people that get the master cylinder brace.
Just a update. A '11 WRX owner I sponsored ran 11.8 sec in the 1/4 mi with a stock VF52, my FMIC and bolt ons. http://forums.nasioc.com/forums/showthread.php?t=2343897
And also on the '10+ Legacy GT side. It turns out that they have alot more potential then we thought. One of our members (Rutchard) running my new '10+ LGT TMIC and TBE made 310+WHP and 380 w torque with the stock turbo on pump gas and 337whp and 406wtq on e68 and ran the 1/4 mi @ 12.5 sec. You can follow this link for more info. Bryan http://legacygt.com/forums/showthread.php/turning-corn-into-torque-181962.html
FMIC kits and TMICs are in stock and ready to ship. Bryan
Hey itsme what is the best way to get some of these new pipes? I purchased the first version and would like to get the new pipes on the cold side all the way from the core to the tb. Can one just buy certain pipes from you?
Thinking the same thing. I only need the shortened the throttle body pipe. PM the price if you like.
Same
"Striving to better, oft we mar what's well." - Bill Shakespeare - car modder
Normally when I revise the kit I buy extra pipe in case people with the older kits want to buy the updates. For stuff like that just PM me. I'm alway pretty fast on answering my PM. Bryan
  • 2 weeks later...
Installed new TB pipe for the RacerX FMIC. Shortened throttle body pipe to make more clearance for the fuel regulator bracket & the master cylinder. For people that gets the MC brace.
http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0622122347.jpg
http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0622122345a.jpg
http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0622122345.jpg
With 3 washer in the front & 2 in the rear. I raised the fuel regulator bracket. Now the new TB pipe fit under all 3 fuel lines. See pic. above.
http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Untitled-2.jpg
Had to mod the DS valve cover breather hose & relocate the alternator wire harness.
http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0620122135.jpg
http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0622122001a.jpg
http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0622122001.jpg
Remove wire harness clip. Move wire harness to inside of fill tube.
http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0620122146.jpghttp://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0620122156.jpg
Mike
You didn't read the above post, did you:rolleyes::spin::lol:
  • 3 weeks later...
Now the WRX got a 2.5xt-r turbo and is putting out 439whp on a stock block and e85. here is a link and post from EFI logic
http://forums.nasioc.com/forums/showthread.php?t=2380488
http://i167.photobucket.com/albums/u156/itsmebryan/photo-2.png
Has anyone installed the shorter TB J pipe on an 07+? I tried on my 08 and couldn't get it around the oil cap. It just wanted to go straight through.
I am running the GS AOS which is slightly larger than the OEM cap, but the fit wasn't even close. I'm also running TXS fuel rails/lines, so the OEM lines aren't in the way. I can get pics if necessary, but I'd rather see pics of those who have done it so I can see what I'm going wrong.
I'm doing an install on a '11 wrx when I get home. It should be about the same as your. I can post pictures when I get done. Bryan
