derkahn Posted November 12, 2010 Share Posted November 12, 2010 lossol--- since your not busy at all ha ha any plans on doing something like this next?.. no really I would love to have something like this in a oem looking vent install and I am sure other people would too...http://www.ecliptech.com.au/index.php?option=com_content&view=article&id=47&Itemid=97 just a thought good work your stuff looks awesome!!! Link to comment Share on other sites More sharing options...
tangcla Posted November 15, 2010 Share Posted November 15, 2010 I just wanted to say, I've finally received my RHD beta unit, looking forward to fitting this although it probably won't happen until Sunday Andy, was wondering though, is it possible to get a clear glossy plastic cover over the device so it has a uniform look and feel like the info display clock? This will probably mean the capacitative buttons need to be re-designed, but it's just a thought... Link to comment Share on other sites More sharing options...
LegacyDan Posted November 15, 2010 Share Posted November 15, 2010 got mine last week delivered to work, but only back from California today. Will hopefully get it insstalled during the week Link to comment Share on other sites More sharing options...
tangcla Posted November 15, 2010 Share Posted November 15, 2010 I've been excited last night and got it fitted to the air vent. I wrapped the ribbon cable around the air vent and double-sided-taped the module to the underside of the air vent tube, as I figured this was the best way to prevent accidental damage from removing the air vent in future. Mine just reaches around the 1.5 wraps, if the cable is folded in the right way Now I'm just waiting for two fuse-taps to arrive from eBay... before I fit the gauge up Link to comment Share on other sites More sharing options...
lossol Posted November 16, 2010 Author Share Posted November 16, 2010 I recently updated the manual, added some more information about where to tap power, where to hookup the vac/boost lines, additional info about OLED displays and stuff. You can find that here: Manual I also added more information about how the illumination line should be hooked up and it's functionality. Thanks for the questions JP. lossol--- since your not busy at all ha ha any plans on doing something like this next?.. no really I would love to have something like this in a oem looking vent install and I am sure other people would too...http://www.ecliptech.com.au/index.ph...d=47&Itemid=97 just a thought good work your stuff looks awesome!!! I hate to disappoint...I probably won't make something like this, but I appreciate the suggestion. I'm not sure what my next project will be...Maybe a 2010 VBG1...I dunno. I also like the idea of interfacing the CAN bus and grabbing info. I just wanted to say, I've finally received my RHD beta unit, looking forward to fitting this although it probably won't happen until Sunday Andy, was wondering though, is it possible to get a clear glossy plastic cover over the device so it has a uniform look and feel like the info display clock? This will probably mean the capacitative buttons need to be re-designed, but it's just a thought... Yeah I have to admit, I would of loved it to be a flat surface, instead of nearly flat surface. For those of you who haven't seen it in person, the OLED Screens are directly exposed because the graphic overlay is die cut around their perimeter. I tried a prototype overlay which covers the screen with a clear lexan polycarbonate - however I noticed that because the screens top layer is a anti-reflective polarizer, I was getting much better direct sunlight viewing without the clear cover. I might play around with new overlays in the future, however they are expensive to prototype with. However ideas always welcome. got mine last week delivered to work, but only back from California today. Will hopefully get it insstalled during the week Sweet! I've been excited last night and got it fitted to the air vent. So it fits?!? Alright! looking forward to the final hookup and pictures for the RHD version. Thanks for being a beta tester tangcla. VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
tangcla Posted November 16, 2010 Share Posted November 16, 2010 So it fits?!? Alright! looking forward to the final hookup and pictures for the RHD version. Thanks for being a beta tester tangcla. The shoe fits Link to comment Share on other sites More sharing options...
LegacyDan Posted November 16, 2010 Share Posted November 16, 2010 just read the manual there so, for the 12v accessory power, im presume you mean 12v switched which is when the ignition is set to on? or does it need to be connected to a 12v constant Andy? Thanks Dan Link to comment Share on other sites More sharing options...
lossol Posted November 17, 2010 Author Share Posted November 17, 2010 (edited) 12V switched is correct. The manual recommends to tap the IG2 circuit. "Power should be sourced to the VBG1 before engine start, for most model years IGNITION power provides proper power sequencing. Some model years (07+) have some ignition lines that power off briefly at engine start. The atmospheric sampling sequence depends on proper power sequencing. Please be sure that the proper power sequencing is provided to the gauge." "The sending unit requires a minimum of power and ground to be hooked up in order to operate the VBG1 as a boost/vac gauge. The VBG1 Power wire (RED) wire should be attached to the IG2 circuit. The easiest place to tap this circuit is at the fuse box using a fuse tap." ... so glad that RHD gauge fits! Edited November 17, 2010 by lossol VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
LegacyDan Posted November 17, 2010 Share Posted November 17, 2010 12V switched is correct. The manual recommends to tap the IG2 circuit. "Power should be sourced to the VBG1 before engine start, for most model years IGNITION power provides proper power sequencing. Some model years (07+) have some ignition lines that power off briefly at engine start. The atmospheric sampling sequence depends on proper power sequencing. Please be sure that the proper power sequencing is provided to the gauge." "The sending unit requires a minimum of power and ground to be hooked up in order to operate the VBG1 as a boost/vac gauge. The VBG1 Power wire (RED) wire should be attached to the IG2 circuit. The easiest place to tap this circuit is at the fuse box using a fuse tap." ... so glad that RHD gauge fits! Yep all wired up and back in the car now, i will start testing things out on the way home for work in an hour or two. How accurate in terms of psi should the gauge be? Also what so i need to buy to get the AFR aspect working on the gauge? Thanks Dan Link to comment Share on other sites More sharing options...
LegacyDan Posted November 17, 2010 Share Posted November 17, 2010 quick drive home seems like gauge is working, however my peak boost is 1.51 bar which i thought was a bit high for mine. Is the BAR function working properly or do i need to leave it on PSI? Do you want me to post beta issues here or PM Andy? Link to comment Share on other sites More sharing options...
lossol Posted November 18, 2010 Author Share Posted November 18, 2010 1.51 bar = 21.9006984 pounds per square inch - seems high for stock. How does the vac look. Should be pulling up to 22inhg at idle around 18ish warm I think you have the power hooked to the wrong circuit. From the manual: link "Power should be sourced to the VBG1 before engine start, for most model years IGNITION power provides proper power sequencing. Some model years (07+) have some ignition lines that power off briefly at engine start. The atmospheric sampling sequence depends on proper power sequencing. Please be sure that the proper power sequencing is provided to the gauge." "The VBG1 Power wire (RED) wire should be attached to the IG2 circuit. The easiest place to tap this circuit is at the fuse box using a fuse tap" Hope this helps. VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
tangcla Posted November 18, 2010 Share Posted November 18, 2010 Your stock boost should read about 1 bar. Link to comment Share on other sites More sharing options...
LegacyDan Posted November 18, 2010 Share Posted November 18, 2010 (edited) Your stock boost should read about 1 bar. I have ecutek map on mine so should be a bit higher. mechanical gauge before was reading about 1.3. ill check the power again but as far as i know i hooked it up to 12v switched, like it only comes on when i turn ignition to "on" position ill try connect to the IG2 circuit and see does that make a difference, just need to get one of those fancy fuse connectors! Edited November 18, 2010 by LegacyDan Link to comment Share on other sites More sharing options...
tangcla Posted November 18, 2010 Share Posted November 18, 2010 Fitted mine tonight Link to comment Share on other sites More sharing options...
LegacyDan Posted November 18, 2010 Share Posted November 18, 2010 Fitted mine tonight did you connect it to IG2 fuse or another source of switched power? Mine was only boosting at 1.05 bar max this morning on the way to work(weird) Must check all connections again at lunch Link to comment Share on other sites More sharing options...
tangcla Posted November 18, 2010 Share Posted November 18, 2010 Bottom right fuse dunno which one it is, I don't have my fuse panel sticker... Link to comment Share on other sites More sharing options...
LegacyDan Posted November 18, 2010 Share Posted November 18, 2010 Bottom right fuse dunno which one it is, I don't have my fuse panel sticker... did you just solder onto the fuse or use connector pictured in the manual? If so what are they called? it would make my google searches easier. rather than trying " mini blade fuse connector thingy" Link to comment Share on other sites More sharing options...
tangcla Posted November 18, 2010 Share Posted November 18, 2010 Oh, sorry, misread your question. I got two of these, one for the illumination and one for the powerhttp://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=300486062024&ssPageName=STRK:MEWNX:IT: Link to comment Share on other sites More sharing options...
LegacyDan Posted November 18, 2010 Share Posted November 18, 2010 Oh, sorry, misread your question. I got two of these, one for the illumination and one for the powerhttp://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=300486062024&ssPageName=STRK:MEWNX:IT: cool thanks, now i know what they are called. Cheers Link to comment Share on other sites More sharing options...
tangcla Posted November 18, 2010 Share Posted November 18, 2010 (edited) So I fitted it last night and was spending way too much time looking at it while driving to work here are some quick camera phone photos. Andy: A thought, maybe it would be good if the LED bar (and also the graph) could show vacuum and boost at the same time? i.e. the point at which MAP=0 would be partway up the graph. 000000|00000000000000000000 http://img201.imageshack.us/img201/9297/photo1vt.jpg http://img508.imageshack.us/img508/5274/photo2hzf.jpg http://img87.imageshack.us/img87/9846/photo3mx.jpg Edited November 18, 2010 by tangcla Link to comment Share on other sites More sharing options...
mainelydanks Posted November 19, 2010 Share Posted November 19, 2010 i got my 30K service done this week at a Subaru dealership close by. When i was dropping the car off the check-in dude was looking the car over and noticed the gauge.... "is that Subaru?" Good job Lossol! It looks so good it fools Subaru employees.... Link to comment Share on other sites More sharing options...
Squiden Posted November 21, 2010 Share Posted November 21, 2010 WooHoo! Finally got mine ordered. Can't wait to get it installed. Link to comment Share on other sites More sharing options...
never summer Posted November 21, 2010 Share Posted November 21, 2010 Where did you order from? I read 15 pages and then started skimming.... Link to comment Share on other sites More sharing options...
Squiden Posted November 22, 2010 Share Posted November 22, 2010 Then you missed page 1. ;-) Just go to gtboostgauge.com, and select the VBG1. I was even glad to see that lossol has the vaccuum tubing and T-fitting for the boost guage. Link to comment Share on other sites More sharing options...
Misfire Posted November 22, 2010 Share Posted November 22, 2010 (edited) So, I ordered my VBG1 a few weeks ago, received it last Thursday, and installed it Friday the 19th. The install went well, with no major complications. Upon initial power up, the right hand OLED screen was inverted. I powered the unit off then back on and it was back to normal. The unit then ran perfect for three days. Last night I was going to show the unit off to some friends (figures it happened this way...). When I powered up, the left hand OLED screen was displaying garbled pixels. So I powered on and off numerous times, the left screen stayed garbled, both screens would randomly invert, and the right screen would sometimes display stretched out text and blackout. Frustrated I drove home. While doing so I got into some boost and the garbled pixels went away, but both screens were still inverted. When I got home I cycled it about 20 times and every time it came online without garble and in the proper orientation, but two times the right screen blacked out after a few seconds and when I pressed the top button the screen would come back online but inverted. Not sure if anyone has ever had issues like this before, I've read this thread in its entirety and don't recall anything more severe than the occasional misplaced power wire. I also know that no production line is perfect, there are bound to be faults at some point. It just sucks when you're the person that gets them. Hopefully it’s nothing major, and/or can be easily fixed. I will try and catch some pictures of the garbled pixels, and will post a crappy cell phone picture of the right screen inverted when I get home from work. TLDR: VBG1 random garbled pixels/inverted screens. http://i188.photobucket.com/albums/z198/Qautre-/1122100925.jpg Edited November 22, 2010 by Misfire Link to comment Share on other sites More sharing options...
