Moderators BarManBean Posted August 16, 2014 Moderators Share Posted August 16, 2014 Great data, right there^ "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
fahr_side Posted August 21, 2014 Share Posted August 21, 2014 That trans was designed to handle the torque of the Subaru 2.0TD so it's pretty stout, internally, despite it still being a split-case setup. Shift mechanism sits on top of the transmission so shifter and clearance may be an issue. Driveshaft may also be an issue - The 4.444 FDR is designed to best work with the very large Outback tires. Smaller "GT" tires would change the ratio dramatically. Yes, but it's basically the old 5MT with six gears squeezed in there. Remember how that idea worked out on the old Evo MR? Add to that the issue that the little 6MT is cable-shifted (ugh). I know for sure the old rod-style 6MT shift linkage does not fit a BR/BM chassis, so no way this cable-shift (ugh) mechanism will plug and play in a 4th gen. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
SBT Posted August 21, 2014 Share Posted August 21, 2014 Yeah - the cable shifting was one thing I could not get used to, despite there being a nice turbo at the header solution up front. No amount of "improved" power delivery could make up for the fact that the transmission was pure crapola. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
sjxbrd Posted August 28, 2014 Share Posted August 28, 2014 Finally, I'm in the club! Used recipe B: 2012 STI 6 speed STI R180 rear diff LGT front axles spec B rear axles LGT 4EAT drive shaft Everything was a straight forward bolt-on, except the rear differential's input yoke had to be swapped. I'm loving the new setup, the differentials make a big difference. Now I need to figure out how to wire up the mapdccd controller. Link to comment Share on other sites More sharing options...
SBT Posted August 28, 2014 Share Posted August 28, 2014 Did you also swap out the neutral safety switch? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
MiniStiGuy Posted August 28, 2014 Share Posted August 28, 2014 man I wish I could find a good deal on this setup. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted August 28, 2014 Share Posted August 28, 2014 I ended up with a low-mileage '10 STi 6MT... and shortly after the install, two Spec.B boxes came up for grabs, and cheap. Meh. Tits mcgee Link to comment Share on other sites More sharing options...
MiniStiGuy Posted August 29, 2014 Share Posted August 29, 2014 where are you guys looking to find these? OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
sjxbrd Posted August 29, 2014 Share Posted August 29, 2014 Did you also swap out the neutral safety switch? I did swap out the nss and clutch slave cylinder.I found my swap parts at a local junk yard. They came off a 2012 sti with only 26000km. I paid 3300cad for transmission (complete with slave cylinder, clutch assembly, shift linkage, and mount), differential, and legacy 4eat drive shaft. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 29, 2014 Moderators Share Posted August 29, 2014 where are you guys looking to find these? Sending you a pm. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Soarer Posted September 12, 2014 Share Posted September 12, 2014 (edited) I found a new and easy recipe for those looking to use a 2004 or older 6sp trans with male axle stubs coming out of the transmission. If you dismantle the LGT front axles and swap the inboard male CV joint with one from a 2002 WRX front CV axle, you now have a hybrid axle with the female inboard cup you need to connect to your pre-2005 STi 6sp. You have to take the entire inboard CV cup setup though including cup, star & bearings. If you remove the c-clip retainer, the 3-pointed star slides right off and the splining is identical to the LGT. I discovered this the hard way tonight when I got half way through getting my MY2000 V7 STi 6sp ready to put into my 2005 LGT Ltd Wagon. I had swapped over the NSS and the reverse switch and the O2 sensor extension. Then I started working on the sundials and oil seals expecting to use my LGT front axles. I installed the new sundial with new oil seal and moved over to the right side only to find that the sundial on the right side of my V7 6sp is about an inch and a half smaller in diameter than the left one. I guess on the newer 6sp's both the left and right are identical.... not on a V7. :-( After hitting this roadblock, I looked for alternative solutions and came up with the hybrid CV axle and to my amazement, it worked! So, now I'm going to put my male axle stub back in the left side of my V7 6sp and put the old sundial back on and just run the hybrid axles. If anyone needs conversion parts, let me know. I now have a set of sundials with new oil seals up for sale! Edited September 12, 2014 by Soarer Link to comment Share on other sites More sharing options...
frank_ster Posted September 12, 2014 Share Posted September 12, 2014 ^ but you could of used your stock axles ! just pull the stub out and change the oil seal. its been talked about. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Soarer Posted September 12, 2014 Share Posted September 12, 2014 ^ yeah, but then you have to buy about $150 in parts from Subaru (sundials & oil seals) and you have to relash your front diff because you removed the sundials which is a PITA. Building hybrid cv axles is easier and cheaper. A set of used wrx axles can be easily found for $50. I haven't seen anyone else write about this option in this thread. Link to comment Share on other sites More sharing options...
frank_ster Posted September 12, 2014 Share Posted September 12, 2014 oh i didn't know u needed to change the sundials Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Sgt.Gator Posted September 12, 2014 Share Posted September 12, 2014 And the club grows: I have a 05-06 JDM Forester STI 6 speed otw! Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
TeriyakiBBS Posted September 13, 2014 Share Posted September 13, 2014 I am about to pick up a 06 STi Tranny but here is my issues. The center diff is toast and I'll have to get a replacement. I don't care about DCCD so I am looking at getting a Spec B viscous center LSD. How much do those run? Also I am wanting to keep it easy with an R160 rear and source a WRX 3.54 FD Dif and keep my rear axels. Will getting a Spec B center diff affect this and what are my driveshaft options? Is there anything else I would need to complete the swap? I understand I'm going to get a 6speed clutch and flywheel. Thanks guys Link to comment Share on other sites More sharing options...
SBT Posted September 14, 2014 Share Posted September 14, 2014 Have you priced-out the expense of sourcing the Spec B center diff, and installing it, vs. just buying a good STI box. $400.00 for a new Spec B center differential plus labor and materials. FD on your STI box is 3.9 - same as with the Spec B. So, all else equal, the 2006 STi Tranny has a 1.1:1 Center Dif, meaning the front differential final drive is 3.90 - Same as the Spec B - so the WRX rear 3.54:1 R160 differential should match-up "ratio-wise" with the STI box using the Spec B Center Diff. FWIW, the 06 STI box's DCCD uses a revised mechanical limited slip DCCD for the first 30% of lockup, and the electrical clutch assumes the remaining 70%. This is supposed to make better use of the new CD's torque-vectoring capability. But it also costs $2500.00 - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
TeriyakiBBS Posted September 14, 2014 Share Posted September 14, 2014 Have you priced-out the expense of sourcing the Spec B center diff, and installing it, vs. just buying a good STI box. $400.00 for a new Spec B center differential plus labor and materials. FD on your STI box is 3.9 - same as with the Spec B. So, all else equal, the 2006 STi Tranny has a 1.1:1 Center Dif, meaning the front differential final drive is 3.90 - Same as the Spec B - so the WRX rear 3.54:1 R160 differential should match-up "ratio-wise" with the STI box using the Spec B Center Diff. FWIW, the 06 STI box's DCCD uses a revised mechanical limited slip DCCD for the first 30% of lockup, and the electrical clutch assumes the remaining 70%. This is supposed to make better use of the new CD's torque-vectoring capability. But it also costs $2500.00 Good info and thanks for Help, idea for the driveshaft I can use? Sedan 5eat? Link to comment Share on other sites More sharing options...
SBT Posted September 14, 2014 Share Posted September 14, 2014 4EAT Auto driveshaft...and bonus, you won't have to change the flange on your R160 differential. Wagon or sedan should work. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
TeriyakiBBS Posted September 14, 2014 Share Posted September 14, 2014 Will I need to get the Spec B specific shift linkage or will 08+ STi linkage work? Link to comment Share on other sites More sharing options...
SBT Posted September 15, 2014 Share Posted September 15, 2014 P/N for the 07+ STI 6MT and 07+ LGT Spec B 6MT shifter stay, which is where the primary difference is, is the same. 35031AG020. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted September 15, 2014 Share Posted September 15, 2014 Complete gear shift lever P/N is 35011FG000 for the STI and 35011AG050 for the Spec B. The two look different in these two drawings: STI - Item # 19 http://static.opposedforces.com/epc_img/371495035002.png Spec B - Item # 11 http://static.opposedforces.com/epc_img/366495135002.png Cable Assembly - Shift P/N is 35060FG000 for the STI and 35060AG010 for the Spec B. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted September 15, 2014 Share Posted September 15, 2014 IIRC, the shift lever is only different because of the way the boot connects (part #19). They're mechanically interchangeable. I have an email from Cobb somewhere on that. I have a 2010 STI 6MT and a Cobb STS, but I kept my LGT surround & boot. I had to rig the boot connection to mate up with the shifter. Tits mcgee Link to comment Share on other sites More sharing options...
Soarer Posted December 9, 2014 Share Posted December 9, 2014 If anyone is looking for Sundials and seals to swap their 6sp to use stock LGT male axles, I just posted a set here: http://legacygt.com/forums/showthread.php/ct-6sp-sundials-seals-v8-early-6sp-swappers-234641.html?p=5006563 Link to comment Share on other sites More sharing options...
Strizzy Posted December 18, 2014 Share Posted December 18, 2014 What are all of your thoughts on rear axles with no HP limit and a lifetime no questions asked warranty, for around $1k? If you do manage to break it, a stronger replacement will be made for you. My bad luck build Link to comment Share on other sites More sharing options...
