scoobydrew Posted June 26, 2007 Share Posted June 26, 2007 where is your car drew? I had to swap my car out with my mother's Honda CR-V to drive it to NY for her. Last year I drove my car on vacation to NE and it was such a great ride. This mod would have made the trip even better. ProTUNED by RaminiSports Link to comment Share on other sites More sharing options...
2006Specb122 Posted June 26, 2007 Share Posted June 26, 2007 I couldn't believe how easy it was...and it worked!!!! If only I had made the wire long enough the first time.... I also had nothing in the way of electrical tools and I am not a skilled elecrician. Even I was able to make it work. Link to comment Share on other sites More sharing options...
Kargurra Posted June 26, 2007 Share Posted June 26, 2007 Can't wait to try this! Thanks a lot!!! When Chuck Norris was born, the only person who cried was the doctor. Never slap Chuck Norris. - E.J.S. Link to comment Share on other sites More sharing options...
iMouseGT Posted June 27, 2007 Share Posted June 27, 2007 Is there something different on later models? I can watch videos off my AVOX and my Zune on my 06 with no problem. Damn, that sucks. I was hoping that the video in motion hack would work. I guess the software of the screen uses the speed sensor to lock you out. I would test cutting that line, but I'm not sure if items such as maintenance monitor will break. Hopefully this Sunday I have some free time. I want to gut the nav screen out and analyze it. See if that touch panel is easy to take apart to look at the internals. Link to comment Share on other sites More sharing options...
stewartg Posted June 28, 2007 Share Posted June 28, 2007 With the parking brake off? Link to comment Share on other sites More sharing options...
2006Specb122 Posted June 28, 2007 Share Posted June 28, 2007 imouse.... I know I can search all night...but give me a quick idea of how you are getting video on your nav screen and what you are doing.... obviously the DVD player that the nav uses does not play DVDs so what's the trick.... there are lots of ways but I wish there was an easy way... do the 07 or 08 models allow you to play regular dvds? what are you doing? thanks Link to comment Share on other sites More sharing options...
iMouseGT Posted June 28, 2007 Share Posted June 28, 2007 I got the heads up that you can run video straight off the screen from this thread: http://www.legacygt.com/forums/showthread.php?t=52355 Then I stepped it up by using an AVOX: http://www.legacygt.com/forums/showthread.php?t=55014 I just remembered, there is a 1 wire on the screen harness you ground to have it work during motion. Link to comment Share on other sites More sharing options...
Kargurra Posted July 1, 2007 Share Posted July 1, 2007 Nice! It took me a few tries: On the '08 nav (with V.2.0 DVD) there's no PKB. in the Vehicle signals screen. I thought it wasn't connected well. I had to go into the hidden diagnostics screen to see the sensor signal. I jumpered pin 5 to Pin 2. So you don't have to use the search button... Hidden Diag Screen: Press "Menu" touch top center of screen for 10 seconds. Type in 014220. When Chuck Norris was born, the only person who cried was the doctor. Never slap Chuck Norris. - E.J.S. Link to comment Share on other sites More sharing options...
dr_sharp Posted July 1, 2007 Share Posted July 1, 2007 Stickybump thanks for the info Kargurra... I assume its the same for 07s??? lol Link to comment Share on other sites More sharing options...
stewartg Posted July 1, 2007 Share Posted July 1, 2007 According to jon's diagram I would assume yes. At first I was going to go the same route but I couldn't find my wiretaps. Link to comment Share on other sites More sharing options...
Kargurra Posted July 1, 2007 Share Posted July 1, 2007 The OP has an '07, and it shows "PKB. : On" That field is blank on my screen. I assume it's a function of the Version 2.0 DVD, since the nav unit otherwise is the same. (Main diagnostics screen reports Kenwood 3100.) Pin 2 is ground according to the schematic. This should be the same on all units, but verify which NAV hardware you have first. (The schematic I have is for both the Kenwood 3100 and 3200.) When Chuck Norris was born, the only person who cried was the doctor. Never slap Chuck Norris. - E.J.S. Link to comment Share on other sites More sharing options...
ama0787 Posted July 15, 2007 Share Posted July 15, 2007 great mod thanks a lot! I just stripped both ends of the wire jammed one end in the connector and used liquid masking tape (hopefully it will hold) and stripped the other end and put it under the Phillips screw on the top right corner of the unit. Working great si far to bad I still have to cut and ground the wire on back of the nav screen to get it to play the video input when rolling. I hate taking the nav bezel off! You would think this fix would take care of the other too after all each one is grounded to make the car think the parking brake is up. I just don't understand having to do both?!? Anyway thanks again for this tip. Anthony EDIT: This needs to be stickied in this area and in the basic modification walk through area! There are plenty of pics and it should be abundantly clear to any moron how to get this job done right with all the info that has been posted in this thread. Sticky it save everyone the trouble of telling newbies to search; when they ask how to use their navigation system while rolling. STICKY THIS THREAD!! Link to comment Share on other sites More sharing options...
Kargurra Posted July 17, 2007 Share Posted July 17, 2007 If they don't know how to search, I'm not sure I want them paying attention to the NAV while trying to drive! When Chuck Norris was born, the only person who cried was the doctor. Never slap Chuck Norris. - E.J.S. Link to comment Share on other sites More sharing options...
rallysquirrel Posted July 19, 2007 Share Posted July 19, 2007 I've got V2.0 DVD so I guess I'll have to try this again. I couldn't get the PKB to show up so I gave up after an hour. I'll try again another day. Link to comment Share on other sites More sharing options...
Kargurra Posted July 20, 2007 Share Posted July 20, 2007 I've got V2.0 DVD so I guess I'll have to try this again. I couldn't get the PKB to show up so I gave up after an hour. I'll try again another day. You won't see it on the 2.0 DVD. You have to go into the hidden diagnostics menu (I mentioned how to find that menu earlier in this thread.) I've noticed that before the mod, it used to automatically select a route if you didn't confirm within about 30 seconds or so when there were multiples. Now, it now no longer does that. It's a small price to pay, though. When Chuck Norris was born, the only person who cried was the doctor. Never slap Chuck Norris. - E.J.S. Link to comment Share on other sites More sharing options...
VtspecB Posted July 20, 2007 Share Posted July 20, 2007 Gorgeous gorgousity! Kudos to XiiiXiii my vBGarage Link to comment Share on other sites More sharing options...
Vimy101 Posted July 20, 2007 Share Posted July 20, 2007 You won't see it on the 2.0 DVD. You have to go into the hidden diagnostics menu (I mentioned how to find that menu earlier in this thread.) I've noticed that before the mod, it used to automatically select a route if you didn't confirm within about 30 seconds or so when there were multiples. Now, it now no longer does that. It's a small price to pay, though. Yes. I noticed that as well but, as you say, a very small price to pay for such a great hack. Link to comment Share on other sites More sharing options...
natoli4 Posted July 21, 2007 Share Posted July 21, 2007 thanks! been looking for this for a while! Link to comment Share on other sites More sharing options...
rallysquirrel Posted July 29, 2007 Share Posted July 29, 2007 OK it was because I was using v2.0. I went into the diagnostics screen and checked that it was working. I ended up using 16awg wire and supergluing it at the pin. Works like a charm. Thanks. Link to comment Share on other sites More sharing options...
mmontgom Posted July 30, 2007 Share Posted July 30, 2007 I was linked here from another Subaru forum and I just wanted to say that on my 06 Tribeca you do not need to remove the seat in any fashion to do this (I also think it is harder to remove the seat because it is a power seat?). There is a black metal panel covering the back of the DVD/GPS unit and it is secured by two bolts. You access everything under the driver seat from the back seat going under. Jam a wire in there and screw the other end around the right side bolt that secures the black metal plate when you put it back and you're all set. cheers! Link to comment Share on other sites More sharing options...
dr_sharp Posted July 30, 2007 Share Posted July 30, 2007 I was linked here from another Subaru forum and I just wanted to say that on my 06 Tribeca you do not need to remove the seat in any fashion to do this (I also think it is harder to remove the seat because it is a power seat?). There is a black metal panel covering the back of the DVD/GPS unit and it is secured by two bolts. You access everything under the driver seat from the back seat going under. Jam a wire in there and screw the other end around the right side bolt that secures the black metal plate when you put it back and you're all set. cheers! Thanks for the input but its definitely different in the Legacy. There are only 4 bolts to remove the power seat. And the wiring in question is in the front, not behind the seat. Although I am comparing it to an 07 Legacy so maybe changes have been made compared to 06s? lol Link to comment Share on other sites More sharing options...
2006Specb122 Posted July 30, 2007 Share Posted July 30, 2007 Hey guys...you mentioned that it is a small price to pay...it will no longer automatically start the route.... What hack did you do that caused this? I'm too lazy to look back at evey post..... thanks Link to comment Share on other sites More sharing options...
Vimy101 Posted July 31, 2007 Share Posted July 31, 2007 ^ When you ground that wire which tells the 'puter that the parking brake is on, the puter no longer automatically selects quickest route after 10 or so seconds while you are in motion. Pretty minor side effect, IMHO. Link to comment Share on other sites More sharing options...
XiiiXiii Posted August 1, 2007 Author Share Posted August 1, 2007 You're right about that auto select not working anymore. I didn't even think about that but after you mention it I did notice it didn't do it anymore. I just didn't put 1 and 1 together. Oh well, its not even a big deal. Shoot I might even just put a toggle switch in to be lazy. Not like I am always inputing data while driving anyways. Good to see so many successful results. I've been so busy this summer I haven't had time to even drive my car in the past month. Good thing is I'm dedicating Saturday to work on the Legacy. I'm going to gut the NAV screen apart and start studying it to hopefully hack the annoyance screen. Link to comment Share on other sites More sharing options...
rallysquirrel Posted August 1, 2007 Share Posted August 1, 2007 for the results Link to comment Share on other sites More sharing options...
