trohler Posted October 26, 2006 Share Posted October 26, 2006 ^ Nope those are all for Turbo cars. 07 Impreza 2.5i Special Edition 07 Kawasaki Ninja 250 Link to comment Share on other sites More sharing options...
ScoobyInc Posted October 26, 2006 Share Posted October 26, 2006 I am a bit confused by all the posts. I have a question: Do all the aftermarket Intakes require modification for installing them? Is there one that is made specifically for our cars? Link to comment Share on other sites More sharing options...
05ABP2.5i Posted October 26, 2006 Share Posted October 26, 2006 Do all the aftermarket Intakes require modification for installing them? Is there one that is made specifically for our cars? YES NO Link to comment Share on other sites More sharing options...
ScoobyInc Posted October 26, 2006 Share Posted October 26, 2006 So I guess that means no intake for me -- not down for chopping it all up. Link to comment Share on other sites More sharing options...
jackacc Posted October 26, 2006 Share Posted October 26, 2006 I just bought this one off ebay: http://img.photobucket.com/albums/v630/safety_furst/LJMYSPACE/intake1.jpg Hopefully I can get it installed before it gets to cold outside! How are you guys cutting the pipe? I was just going to dremel it. Do you just cut about 1-2 inches straight off the end or do you cut at an angle? Also, what other connectors will I need to hook up the tubing? I know I'll at least need a 3" rubber connector to mate iti with the airbox and some clamps. Anything else to know before I head to the auto parts store? Thanks! JDM GT Bilsteins (F-Tanabe R-Pinks) JDM RSB - Modded Kartboy SS - Subaru Momo Knob Subastyle Grille Link to comment Share on other sites More sharing options...
trohler Posted October 26, 2006 Share Posted October 26, 2006 Thats the same one i put on my car, use a sawzall i tired dremel it didnt work well. Get a good assortment of hose clamps and vac. connectors to join the new hose to the factory. Also soak the supplied connector for the pipe to TB in hot water for about 5-10 min. The older TB's must have been smaller because that one is hard as hell to get on unless you let it expand a little. And as stated before take out the front bolt on the bottom of the air box and lossen the back one. 07 Impreza 2.5i Special Edition 07 Kawasaki Ninja 250 Link to comment Share on other sites More sharing options...
digitaldebris Posted October 26, 2006 Share Posted October 26, 2006 You can also just use a hack saw too with a little bit of elbow grease, the metal isn't too thick so it'll cut nicely... I didn't use any of the connectors from the intake... I bought 3" connectors from pep boys. Link to comment Share on other sites More sharing options...
jackacc Posted October 26, 2006 Share Posted October 26, 2006 Thanks guys, I appreciate it. I will have to borrow a sawzall or give the hacksaw a try. Is it just a straight cut across it? How much did you take off altogether? vac connectors... They are the little metal sleeves that fit inside the hoses you are joining right? What size connectors and clamps did you use? JDM GT Bilsteins (F-Tanabe R-Pinks) JDM RSB - Modded Kartboy SS - Subaru Momo Knob Subastyle Grille Link to comment Share on other sites More sharing options...
ScoobyInc Posted October 27, 2006 Share Posted October 27, 2006 In response to using a cone filer and MAF not throwing a CEL. Wouldnt this work? It provides the distance between the intake and the sensor: http://www.hopupracing.com/peshraminsul.html http://us.st11.yimg.com/us.st.yimg.com/I/hopup1_1919_15986107 Link to comment Share on other sites More sharing options...
05ABP2.5i Posted October 27, 2006 Share Posted October 27, 2006 i tried all of that. i dont think its a distance issue. i had an extension run all the way into the wheel well, a good foot and still threw a cell. its just a very picky maf. as far a performance is concerned, i dont feel that much difference in the extension and having the stock box, silencer delet and diy piping. the only difference is how loud it is. plus NO MORE CEL!!!! Link to comment Share on other sites More sharing options...
iroczu Posted October 29, 2006 Share Posted October 29, 2006 So I guess that means no intake for me -- not down for chopping it all up. same boat as me eh? '03 n/a Link to comment Share on other sites More sharing options...
05silverbus Posted October 29, 2006 Share Posted October 29, 2006 Autobac intake on my i. I used a hack saw and a littlefine grind on th ebench grinder t make it look pretty. I am extremely impressed in the overall difference in noise and actually feel some freeway speed performance increase, this is with the stock cleaner box and a K&N panel filter, as well as another air flow mod. Awsome Awsome Awsome!!!! Link to comment Share on other sites More sharing options...
05ABP2.5i Posted October 30, 2006 Share Posted October 30, 2006 as well as another air flow mod. do tell:icon_mrgr Link to comment Share on other sites More sharing options...
Guest subiecity Posted October 30, 2006 Share Posted October 30, 2006 any performance gains outta theses intakes??? anyone feel a difference or is it better to just stay wit the oem intake box and knn filter Link to comment Share on other sites More sharing options...
digitaldebris Posted October 30, 2006 Share Posted October 30, 2006 I feel a difference... i have an intake tube, stock air box w / k&n. The car's shifting pattern changed... it wanted to shift appox. 5mph faster in each gear than with the stock setup. IE: shifting to 2nd @ 5mph... became 10mph, shifting to 3rd @ 20mph became 25mph ... etc. plus the sound Link to comment Share on other sites More sharing options...
05silverbus Posted October 31, 2006 Share Posted October 31, 2006 do tell:icon_mrgr Silencer removed and replaced with a PVC elbow. No fog lamps so I used the existing hole intended for fogs placed mesh (tweety catcher) and now my primary flow comes from the front bumper much bigger hole than stock and deffinatly a difference although I think a certain percent of the performance improvement is mental due to great sound. Link to comment Share on other sites More sharing options...
Guest subiecity Posted October 31, 2006 Share Posted October 31, 2006 yea mine is piped the same way but i have no "tweety catcher" not yet anyways...i think im gonna leave the stock air box and do the pipe.....whats the website where everyone ordered their "intake pipe" ....one mnore quik question...does the intake pipe come with a MAF hole? just incase i change my mind and i do decide to take off my oem airbox? Link to comment Share on other sites More sharing options...
05ABP2.5i Posted October 31, 2006 Share Posted October 31, 2006 ...does the intake pipe come with a MAF hole? just incase i change my mind and i do decide to take off my oem airbox? what i did was take the stock airbox and cut it just beyond the maf sensor. i saw a post of this somewhere on here but couldnt find it again. make the cut as far toward the box as possible this will retain the factory maf piping diameter and location. then you can get another pipe to extend it into the wheel well and have a true CAI. this was what i did at first, and still threw a CEL. Link to comment Share on other sites More sharing options...
hatchd Posted November 1, 2006 Share Posted November 1, 2006 has anybody changed the MAF? so that you can run a cold air and not throw a cel. i had the problem in my focus with my cams and my CAI it was getting to much air and all i had to do was replace my MAF and the car ran fine afterwards. Link to comment Share on other sites More sharing options...
trohler Posted November 29, 2006 Share Posted November 29, 2006 i've got an intake for sale if anyone is interested, didnt post it with the for sale stuff. but if anyone is interested just shoot me a pm and an offer. pics added SOLD IT thanks Tolly 07 Impreza 2.5i Special Edition 07 Kawasaki Ninja 250 Link to comment Share on other sites More sharing options...
Guest subiecity Posted November 29, 2006 Share Posted November 29, 2006 why u selling it? Link to comment Share on other sites More sharing options...
trohler Posted November 29, 2006 Share Posted November 29, 2006 why u selling it? Check my sig. 07 Impreza 2.5i Special Edition 07 Kawasaki Ninja 250 Link to comment Share on other sites More sharing options...
Guest subiecity Posted November 30, 2006 Share Posted November 30, 2006 ahh ic so u sellign ur car any other parts up for sale? Link to comment Share on other sites More sharing options...
trohler Posted November 30, 2006 Share Posted November 30, 2006 cars already traded in, yeah check the member classifieds section. 07 Impreza 2.5i Special Edition 07 Kawasaki Ninja 250 Link to comment Share on other sites More sharing options...
Guest subiecity Posted November 30, 2006 Share Posted November 30, 2006 ic im sure i already have everything but ima check it out ne ways Link to comment Share on other sites More sharing options...
