at last Posted February 19, 2007 Share Posted February 19, 2007 Hi alpha. No, I do not have easy access to NTSC (we are PAL here in Aus.)...but I would have thought that the Kenwood would be multi-input (PAL?NTSC)...but I'll try and find an NTSC source and give it a go. Unidentified, not sure what you mean...DC power...the camcorder I userd is not pugged in to AC (ie. battery ie.DC)...could you expand on this suggestion please? Anyone else? Link to comment Share on other sites More sharing options...
alphabit Posted February 19, 2007 Share Posted February 19, 2007 I can understand that. you could also try calling kenwood and asking if there system does multi-input. Link to comment Share on other sites More sharing options...
ama0787 Posted February 19, 2007 Share Posted February 19, 2007 ;897779']. Originally Posted by #072 http://legacygt.com/forums/skynetim/buttons/viewpost.gif here are the pics and some more info. the wire that needs to be cut for the nav functions to unlock is green/black at the dvd drive under the driver's seat. on the road test this is how it worked. -when you break the conn. the frozen icons will light up -the arrow will stop moving on the screen -@ 10 sec. after you breck the conn. the sat. picks up your location and the arrow will start to move again, but its choppy -@ 20 sec. after you break the conn. the icons will freeze again, its figured out your still moving and locks you out. -breaking the conn. again will bring them back -it does'nt lock you out if your in the middle of entering a destination this seems to work okay, not flawless but better than nothing. leaving the ant. plugged in does seem to help it repostion you quicker after it loses you. hope the pictures help with the video input and e-brake lock out Attachment 19524 Attachment 19525 ----------------------------------------------------------------------------- Everything above that lines is what I was trying to quote. So does this mean that we can use the navigation while sitting in the car? Also does this process have to be done every time we get in the car? What connection needs to be broke and does breaking mean unpluging or cutting? TIA, Anthony Link to comment Share on other sites More sharing options...
ama0787 Posted February 19, 2007 Share Posted February 19, 2007 If anyone understands how to follow the instrutions I quoted above or ahs done them please answer these questions for me. Do you have to cut this wire and put it back together every time you drive the car? The part about breaking the connection again throws me off. Do we cut the wire the reconnect it at some point and then break it again? Does this make access to all navigation features permanent after you complete the process once or does it have to be done every time you start the car? Also does everything function work as it did before the wire was originally cut after the first minute when it relocates itself etc..? Link to comment Share on other sites More sharing options...
unidentified84 Posted February 19, 2007 Share Posted February 19, 2007 Unidentified, not sure what you mean...DC power...the camcorder I userd is not pugged in to AC (ie. battery ie.DC)...could you expand on this suggestion please? well.. i was getting broken images on my screen too when i was installing rear view camera.. i first wanted to make sure the camera worked fine so i hooked it up to my car nav and wall outlet for power.. i suspected it was the camera, but when i tried it on my TV it worked fine.. so then i suspected it was the power.. my rear view camera needed a DC powersource and i had it connected to AC power all the while.. the instructions that came with my rear view camera said to get power from reverse lights, which runs 12V DC current, and i gave that a try.. and VIOLLA~ it was screen became crystal clear.. hm.. i dont know.. so i guess u could try finding 12V DC line from ur car and tap it.. ? i guess that helped.. feel free to ask me more if i was unclear on anything.. thanks~ Link to comment Share on other sites More sharing options...
at last Posted February 19, 2007 Share Posted February 19, 2007 Alpha, unidentified...Thanks for the help. I'll locate a NTSC source and (perhaps another camera - one that I can return to the shop after I trial it) and see what happens. I'll post back with the results. Link to comment Share on other sites More sharing options...
alphabit Posted February 20, 2007 Share Posted February 20, 2007 If anyone understands how to follow the instrutions I quoted above or ahs done them please answer these questions for me. Do you have to cut this wire and put it back together every time you drive the car? The part about breaking the connection again throws me off. Do we cut the wire the reconnect it at some point and then break it again? Does this make access to all navigation features permanent after you complete the process once or does it have to be done every time you start the car? Also does everything function work as it did before the wire was originally cut after the first minute when it relocates itself etc..? Breaking the wire = putting a switch could be ON = wire connected, and OFF = wire disconnected, ON = update where you are OFF = input while driving. as far as trying this for myself I have not. but thats how i understand it. Link to comment Share on other sites More sharing options...
ama0787 Posted February 21, 2007 Share Posted February 21, 2007 alphabit.. Thanks. Now it makes sense unidentified..... which camera did you go with? Also have any links or pictures of it? also thanks again for the ipod help. Is the sound quality out of it as good as the factory sound system can put out? I am getting ready to search for freddie froggy or who evers aux connection u told me about..thanks again Link to comment Share on other sites More sharing options...
djsauce Posted March 8, 2007 Share Posted March 8, 2007 So I did it I connected my iPod video to the Aux-In connector and a camera to the 4-pin connector. And it works Great!!!! I still have to buy a backup camera but I tested it with my camcorder and it worked great as soon as you threw it in reverse. I used some pins (females) and crimped them around the male pins in the 4-pin connector. My only issue is I could not figure out how to run them into the centre console so I "popped" off the "Aux-In" box in my armest cubby (in the 07 spec b) and ran then threw there - maybe I can figure out a way of doing that later. Also, the CD's around the NAV trim worked great! I also grounded the grayish-bluish wire, but I swear the wire colours where different, or at least in different pins than the picture that show what wire to cut. Which path is the easist to rtake to run the video cable for the backup camera from the front to the back of the car? regards, DJ Sauce Link to comment Share on other sites More sharing options...
ama0787 Posted March 8, 2007 Share Posted March 8, 2007 where did you get the 4 pin connector? TIA, Anthony EDIT Just read your poat better and realized you did not use a 4 pin connector. Which camera did you use and any links or pics to it would be great. Also has anyone seen the tribeca camera I imagine it probably wouldnt look good with our cars but I can not find a picture to verify this. Link to comment Share on other sites More sharing options...
djsauce Posted March 9, 2007 Share Posted March 9, 2007 www.kenwood.com camera is the CCD-900 (you can google it as well) Really good from the in store demo in Low-Ligh conditions. Link to comment Share on other sites More sharing options...
ERLoft Posted March 9, 2007 Share Posted March 9, 2007 www.kenwood.com camera is the CCD-900 (you can google it as well) Really good from the in store demo in Low-Ligh conditions. OOps, just realized you haven't gotten the camera yet. Please post up once you have it installed so we can see how/where you installed it and how big it is! 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
camber Posted March 9, 2007 Share Posted March 9, 2007 http://www.cars101.com/subaru/tribeca/tribeca07camera2.JPG Backup camera from Tribeca Link to comment Share on other sites More sharing options...
X-Lead Posted March 9, 2007 Share Posted March 9, 2007 Manuals I have collected for the Satnav: http://files.l33t.net.au/servicemanuals/FGZ000UF2_Service_Manual.pdf <-- Screen Service Manual http://files.l33t.net.au/servicemanuals/FGZ201_Service_Manual.pdf <-- Screen Service Manual http://files.l33t.net.au/servicemanuals/KNA-DV3200_Installation_Manual.pdf <-- Satnav Installation Manual http://files.l33t.net.au/servicemanuals/KNA-DV3200_Service_Manual.pdf <-- Satnav Service Manual http://files.l33t.net.au/servicemanuals/KNA-DV3200_User_Manual.pdf <-- Satnav User Manual And for the McIntosh users: http://files.l33t.net.au/servicemanuals/McIntosh_Audio_Wiring.pdf <-- Audio Wiring Diagram http://files.l33t.net.au/servicemanuals/mc-audio1.jpg http://files.l33t.net.au/servicemanuals/mc-audio2.jpg http://files.l33t.net.au/servicemanuals/mc-audio3.jpg Link to comment Share on other sites More sharing options...
ama0787 Posted March 9, 2007 Share Posted March 9, 2007 I think I am going to buy the tribeca navi one that looks like it would wount eassy and wouldnt require drilling through metal to hide the wiring Any chance you have anymore info about the tirbeca camera like model # or if we buy it does it come with the proper connectors and wires. The pic really helped me Thanks! TIA Anthony Link to comment Share on other sites More sharing options...
NormanPA Posted March 10, 2007 Share Posted March 10, 2007 Has anyone noticed that the 2.0 DVD is now available? Anyone know what's new? http://store.kenwoodusa.com/subaru/ Link to comment Share on other sites More sharing options...
at last Posted March 11, 2007 Share Posted March 11, 2007 Hi folks. FWIW here are some pic's of my removal of the sat nav for my MY07 3.0. The part that got me was having to lift and slide it to the right to release it from the plastic clips at the back of the unit...was about to snap the off when it occured to me it might slot in to the clips...one hard pull to the right and out it came We live and learn! I can also confirm that the Sat Nav requires an NTSC source. It does NOT handle PAL sources. Here is a short video showing it working...Thanks to my Tivo [ame=http://www.youtube.com/watch?v=UMglX-sj9yA]YouTube - Subi Sat Nav with NTSC source[/ame] Link to comment Share on other sites More sharing options...
ama0787 Posted March 11, 2007 Share Posted March 11, 2007 Does anyone know what the third input is? It looks similar to a s-video cable Link to comment Share on other sites More sharing options...
djsauce Posted March 12, 2007 Share Posted March 12, 2007 That "third" connector is already connected to a calbe (in North American cars at least). It is not S-video at all (S-video is 4 pins). Link to comment Share on other sites More sharing options...
ama0787 Posted March 12, 2007 Share Posted March 12, 2007 DJ whats it connected to? Link to comment Share on other sites More sharing options...
at last Posted March 12, 2007 Share Posted March 12, 2007 hmmm...actually, now that you mention it, there was a connector there I looked at the manual a few pages back...and it's the connector to the nav unit. Odd thing is that the nav's been working fine without it plugged in....hmmmm.....interesting... See the manual here.... http://files.l33t.net.au/servicemanuals/FGZ000UF2_Service_Manual.pdf Link to comment Share on other sites More sharing options...
Reverend Posted March 29, 2007 Share Posted March 29, 2007 Here's a good read for you technical types.... http://tl.acurazine.com/forums/showthread.php?t=129765 http://philipedge.com/Acura%5FTL/ Link to comment Share on other sites More sharing options...
Gator GT Posted March 31, 2007 Share Posted March 31, 2007 anything more with the Tribeca camera? "If we are to guard against ignorance and remain free, it is the responsibility of every American to be informed." - T. Jefferson Link to comment Share on other sites More sharing options...
natoli4 Posted March 31, 2007 Share Posted March 31, 2007 anyone in Los Angeles want to help me install this in my 07 Outback? or at least drink my beer and do some pointing? I'd love someone to guide me through the install! Link to comment Share on other sites More sharing options...
WiseYoda Posted April 24, 2007 Share Posted April 24, 2007 [FONT=Arial][SIZE=1][COLOR=Navy][B]"Do, or do not. There is no 'try'." -Jedi Master Yoda (I believe he was talking about the search tool)[URL="http://specb.jerkerstudios.com/"][/URL] [/B][/COLOR][/SIZE][/FONT] Link to comment Share on other sites More sharing options...
