F-WDC Spec B Posted April 20, 2014 Share Posted April 20, 2014 fyi the cs9900 is discontinued, I want to get my hands on one but resellers are selling it for over $500 Link to comment Share on other sites More sharing options...
FroGuidO Posted May 3, 2014 Share Posted May 3, 2014 Hy, I have the elef2 main unit, and I already use the connector cable that enables the audio/video input. When I bought this cable it was bundled with a special cable to connect a backup cam. So far I understood, it was intended to be connected directly to the screen. But when I took off the touch screen, I was disappointed to see that there is no connector for this device. However, when I enter in the service menu of my setup, I do find a prompt with backup camera not connected. I also noticed that on my main unit, there is a port that could receive the back up camera cable I received, but it is already used. Here are pics of both plugs : the plug that is already in place the plug from the cable to connect the backup cam As you can see, the plug are similar, but the pin used aren't the same. I do believe that it should be possible to merge the two to activate the backup cam entry on my unit. I have read a lot about the audio setup of my Suby, espacially in this post, but I may have missed some informations about the elef2 specificities, so please if you can confirm my guess, I would be very grateful. Link to comment Share on other sites More sharing options...
FroGuidO Posted May 7, 2014 Share Posted May 7, 2014 Ok, today I removed once again my HD and unplugged the cord that I suspected to occupy the port I need to set the rear cam plug I mentioned in my previous post. I then turned on my stereo and I checked to see what was missing. But nothing is wrong : stereo works, DVD player works, Navy ok. I turned into the service menu (test mode) and nothing seems to be wrong, all inputs ok, reverse engagement detected. I have no idea what this cord is doing. I suspect that these wires are not connected to anything but are just prewired for optional device. Then I plugged in the adaptor cable I have (video input as rear cam) and grounded the wire to enable the rear cam. It works : in test mode, the rear cam is detected connected, and if I engage reverse, the screen automatically switch to rear view, displaying nothing for the moment as I have no cam connected. Link to comment Share on other sites More sharing options...
pantata Posted January 4, 2016 Share Posted January 4, 2016 Is it there anything I can do to connect camera to that? I guess I`m f*ed up with this european, but still if there is any hope, please tell me what to do. http://i.imgur.com/GCgOttk.jpg http://i.imgur.com/CBhQVFV.jpg http://i.imgur.com/GnDDhIj.jpg Link to comment Share on other sites More sharing options...
bullit Posted August 30, 2016 Share Posted August 30, 2016 hi there. I need some help. I bought DVD/RADIO/NAVI HU kenwood FZDA-07ELEF2, (or FZDA-07ELREF2 for uk) and i need the part number of wiring harness wich connect the differents parts of the HU. Link to comment Share on other sites More sharing options...
Jacobpockros Posted May 9, 2017 Share Posted May 9, 2017 I'm gonna bump this because I do not want to read through 44 pages. Has anyone been able to get boost and afr gauges to read on the oem screen? Link to comment Share on other sites More sharing options...
f85stealth Posted May 9, 2017 Share Posted May 9, 2017 I'm gonna bump this because I do not want to read through 44 pages. Has anyone been able to get boost and afr gauges to read on the oem screen? Not possible using the oem screen. You csn ditch it and add a tablet to do that though. Link to comment Share on other sites More sharing options...
Jacobpockros Posted May 14, 2017 Share Posted May 14, 2017 Not possible using the oem screen. You csn ditch it and add a tablet to do that though. There's no way to do it even though you can play dvd's through the backup camera??? Link to comment Share on other sites More sharing options...
ama0787 Posted May 15, 2017 Share Posted May 15, 2017 Rear view camera signal goes through the molecular connector the rca yellow connector is video there were a few companies that made devices that u could wire in get a boost gauge then use that rca as away to get in your nav think his camp was what it was called other companies did the same go through the 44 pages if u really want to know Link to comment Share on other sites More sharing options...
Chris GTO TT Posted May 15, 2017 Share Posted May 15, 2017 The stock software will not give you the information you are looking for, but systems like the HKS Camp II do exist which can use the stock screen to display the information you are after. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
Jacobpockros Posted May 20, 2017 Share Posted May 20, 2017 Thanks. Oem screen is what I was referring to. How do you toggle through the screen once everything is hooked up? Link to comment Share on other sites More sharing options...
DadBod Posted May 12, 2018 Share Posted May 12, 2018 Anybody try one of these yet? Curious if it's worth the shipping cost and effort to wire in, or easier to just get the JDM Double DIN plate kit. https://car-solutions.com/en/cs9320-navigation-box-on-android-for-oem-monitors-gps-and-glonass.php Link to comment Share on other sites More sharing options...
