S402 Clone build
The pics do make the header look tight against the pan. There's a 'decent' space-but as suggested they'll get ceramic  coated next week.  Anyone have a source for a twin scroll up-pipe gasket?
Engine is assembled. The officially tally at this stage is:
-Built STI Ra Manley piston/Pro-H rod short block
-New OEM Subaru 11mm oil pump
-OEM Subaru full gaskets/seals
-ARP headstuds
-NGK 1 step colder sparkplugs
-OEM Subaru oil cooler
-New OEM exhaust valves
-Machine deck/heads (S402)
Always nice to see the ebb and flow of cars in the shop. I thought the two white GTs were nice then the red one showed up. Someones having some fun this weekend after a good tune.
Edited by ChicagoSam
  • Like 6
@dscoobydoo thanks for the info. I read that retaining the OEM twin scroll header/uppipe doesn't completely transform the exhaust tone to a smoother pitch (keeps some rumble).
Dropping off the headers for ceramic coating. The engine builder doesn't wrap headers anymore. His reasoning is a small spot of oil can( and has) leak onto the hot header wrap  and ignite causing a fire.
May as well powder coat some other engine bits that will be visible in front around the alternator. I'll go with an aluminum finish to try and match the block( ordered a new OEM  alternator as well-)
  • Like 3
So not all twin scroll up pipe to turbo flanges are created equal. Tomei's Expreme up pipe flange is little off. AVO has an up pipe that looks like it would match the turbo, but for headers ,Tomei has a better track record. Stock up-pipe will have todo for now until I find a second hand AVO one.
( saw too many dyno numbers to stay stock for manifolds. I'm trying to be as kind as possible for the vf51's potential)
I'd love to keep the chrome shine, but ceramic will be the way.
  • Like 1
Wow!! What an impressive build you’re undertaking mate!! I own s402 and you’ve given me even more appreciation for it! I’m a little jealous of that hks dump pipe 😍
happy to answer little detail questions if you need along the way mate
keep up the good work!
  • Like 5
  • Thanks 1
@s402legacy gorgeous car.
As you said (FB) the factory headers are part of the s402's unique character. I  had the Tomei manifold before the vf51 turbo and discovered the up-pipe doesn't match the turbo's flange.( Tomei part # TOMTB6010-SB01A  item description says "For Twin-Scroll JDM vehicles only. Not sure why it doesn't fit the s402?)
As free flowing as the Tomei's are I'm not liking the larger Tomei header downsizing into the stock up-pipe. (If only it was the other way around.. and the turbo sits much higher with the Tomei/OEM mismatched combo). I'll stay the course and run the factory given manifold-but may add some welds to the back of the oem pipe's flange like the Tomei has.
It's a big help to have an S402 owner join in- appreciate it!
Some of the original pieces with corrosion will be cleaned up/coated to look in line with the new block, but some parts, like the timing belt tensioner, are pretty cheap new( $40).
New water lines ands most importantly, new clamps.
  • Like 3
Posted (edited)
Ceramic Coating (CERAKOTE) drying on the oem headers( Subaru describes the s402 unique headers as: "Equal length/burst exhaust system" .
 (Found a gasket as well for the up-pipe. part# 44011AG020 ) I Should be all set with the manifolds for now. ( most of the engine bay is black, so I went with little color. It'll darken some after a season or two)
  • Like 5
Coming together with OEM: Water pump/thermostat/Oil cooler lines/clamps/AVCS oil pipe/water pump lines, hoses,clamps/Cam gears(exhaust)/Center timing cover/timing tensioner bracket/Billet TGV's/ gaskets for coolant cross pipe, tensioner bracket, AVCS Can gear O-rings, Exhaust manifold, Uppipe, TGV upper and lower, and timing cover/ STI intake manifold.
Fuel: ID1050 Injectors/Injector plug and play harness adapters, Billet fuel rails/Aeromotive fuel pressure regulator/new fuel pressure sensor and harness and a braided fuel line kit( they look very tidy).
image.thumb.png.a081973e96755d7e9a506035e8903d97.pngimage.thumb.png.fc099228d54a60aec6667946dc0610ac.png
  • Like 4
1 minute ago, DoctorDaveLGT said:
If you don't have it already, do yourself a favor and get a Fluidampr crank pulley. You won't regret it.
I second that.
  • Like 1
  • Thanks 1
Posted (edited)
I took off my lightweight Perrin pulley years ago-but this is different.
thanks for the eyes on- really appreciate it. ( most first impression reviews say the idle is a lot smoother after install-sounds good to me)
  • Like 1
Posted (edited)
 All votes are in..landslide victory.
 I asked if anyone on FB's ,'Modified Legacys' had any opinion/experience with the Fluidampr pulley on their EJs. Sounds like the pulley is coming aboard.
( again- thanks for chiming in above )
  • Like 2
On 8/25/2023 at 9:25 PM, ChicagoSam said:
Lucky me- some talented friends worked their magic. Bumper is “safely” back together. Exhaust sticks out for now but not bad.
think ur buddies can make another one and sell/ship it to me?
So since the original alternator in the car has over 165k miles on it, I'll use the s402's-it  has far less miles on it but still has a lot of corrosion. I wanted to remove the front and had to drill out the 4 screws. One didn't come very easily but it's off for powder coating.
Fuel rails are on as well.
