Infosecdad Posted April 12, 2022 Share Posted April 12, 2022 Today: Drove it around the block checking the water injection system and tweak the boost control. The former looked strange on the display, but was actually working fine including failsafes tripping when I turned up the scaling. The latter was closer than I though already once I upped the overboost failsafe to 19PSI. It was apparently barely going over 18PSI tripping it out. It looks like that was caused by the "I" term building up because I'd tuned it originally around freezing. But it seems to have developed some sort of strange noise while turning over bumps. Which I have no time to diagnose as I'm moving very soon. Maybe I do need to take boxkita's lowball offer to just get this thing gone. Not sure how he'd get it across the country though. Trying to get my taxes done so I can see if I can come get it Link to comment Share on other sites More sharing options...
jams20 Posted April 12, 2022 Share Posted April 12, 2022 Replaced the oil seal where the drive shaft meets the transmission. Now onto the valve cover gaskets in my quest to resolve the oil leaks at the front end. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
SubOperator Posted April 12, 2022 Share Posted April 12, 2022 Thanks for the link - jogged my memory from when I rewired the FPCM many years back. You can just make out the vent in the shadow on the left side of the pic. I'll check those vents and make some more mesh screens if needed. TBH it's way easier to do it on the outside - the design will be the same as you did for the intake. Chance to inspect the body under the bumper skin at the same time. I hope you don't drive it year long, it's too good of a condition car for NE winter and salt. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
ohno06gt Posted April 12, 2022 Share Posted April 12, 2022 My buddy drives a wrx and was saying with Subarus you can get an estimate of whp by using the maf g/s reading. He stated on his car it was close to 1:1. Does this hold true for our cars? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 12, 2022 Share Posted April 12, 2022 Did a full fluid change but I believe my father in-law added a full 5qts of 5w30 [emoji1751]. Debating draining some tomorrow. Sent from my SM-S908U using Tapatalk FSM actually says 4.5 qt (or 4.3 L) if you change the oil and filter. Just need to remove ~.5 qt. Link to comment Share on other sites More sharing options...
Infosecdad Posted April 12, 2022 Share Posted April 12, 2022 FSM actually says 4.5 qt (or 4.3 L) if you change the oil and filter. Just need to remove ~.5 qt. Or in my case, just drive for 500 miles and it will take care of itself... Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 12, 2022 Share Posted April 12, 2022 Link to comment Share on other sites More sharing options...
whitexc Posted April 12, 2022 Share Posted April 12, 2022 Or in my case, just drive for 500 miles and it will take care of itself... [emoji38]Was very similar to what I typed and failed to post lol.... Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted April 12, 2022 Share Posted April 12, 2022 Was very similar to what I typed and failed to post lol.... Sent from my SM-G996U using Tapatalk Ditto, I always add a let more than the full line. Don't worry, the ej will be happy to use it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Notorious Posted April 12, 2022 Share Posted April 12, 2022 Anyone see something wrong here? …. Link to comment Share on other sites More sharing options...
Infosecdad Posted April 12, 2022 Share Posted April 12, 2022 nah, just looks like you'll need to take a cutting wheel to your tranny bellhousing to fit that turbo line... Link to comment Share on other sites More sharing options...
seanyb505 Posted April 12, 2022 Share Posted April 12, 2022 Yeah, you have to take then engine stand off the car before you can fit the transmission. Though when I first saw it I let out a nervous "noooooo." Daughter became immediately concerned. Link to comment Share on other sites More sharing options...
whitexc Posted April 13, 2022 Share Posted April 13, 2022 Anyone see something wrong here? …. What yah gonna do with that oil line? Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
SubOperator Posted April 13, 2022 Share Posted April 13, 2022 Anyone see something wrong here? …. Ugh. What turbo is that? 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
finsta Posted April 13, 2022 Share Posted April 13, 2022 Started prepping my new power harness. Thanks to rhino6303 for the pointers to begin. 2AWG for the starter, 2 AWG for the transmission ground and 4 AWG for the chassis ground. Still need to decide how I want to do the fuse box. I took measurements of everything and will be posting them on my build page in due time for anybody who wants to make a new power harness. Link to comment Share on other sites More sharing options...
Notorious Posted April 13, 2022 Share Posted April 13, 2022 Ugh. What turbo is that? JmP 20g. Not sure what the move is, but we'll tackle this problem again tomorrow. Maybe we can rotate the line parallel with the other but I doubt it would work. Other solution is to use a different line kit but this turbo has sort of unique dimensions. I've contacted John as well and we'll see what we can think of. Didn't think this would be an issue out of all the things being installed haha Link to comment Share on other sites More sharing options...
Max Capacity Posted April 13, 2022 Share Posted April 13, 2022 (edited) Anyone see something wrong here? …. Why won't the stock style cooling line work ? https://www.amazon.com/Turbo-Subaru-Suabru-Forester-Outback/dp/B083QWHVCK or https://www.amazon.com/JM-Water-cooling-Subaru-Turbo/dp/B083QW22JD Edited April 13, 2022 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Notorious Posted April 14, 2022 Share Posted April 14, 2022 Yep, we ended up just using some OEM lines instead and it fit. Just need to install the Aeromotive FPR tomorrow and things are looking good. Link to comment Share on other sites More sharing options...
seanyb505 Posted April 15, 2022 Share Posted April 15, 2022 Drove 45 minutes to a dealership for the 2nd recall. While scheduling it on the phone they said it should only be 60-90 minutes. I figure, I can make a picnic out of this with my 3yo and give my wife some peace. I get there, and now it's 3-4 hours. Yo. I've got a 3 year and a sandwich. I can maybe last 2 hours. I'm out. At least I picked up my engine bay splash shield. Now to see what hard & plastic ware I need, and reschedule the recall for a closer dealership I was attempting to avoid. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 15, 2022 Share Posted April 15, 2022 So, it sounds like they were going to change the airbag through the glove box area? In other words, they don't touch the dash. Link to comment Share on other sites More sharing options...
boxkita Posted April 16, 2022 Share Posted April 16, 2022 Today: Drove it around the block checking the water injection system and tweak the boost control. The former looked strange on the display, but was actually working fine including failsafes tripping when I turned up the scaling. The latter was closer than I though already once I upped the overboost failsafe to 19PSI. It was apparently barely going over 18PSI tripping it out. It looks like that was caused by the "I" term building up because I'd tuned it originally around freezing. But it seems to have developed some sort of strange noise while turning over bumps. Which I have no time to diagnose as I'm moving very soon. Maybe I do need to take boxkita's lowball offer to just get this thing gone. Not sure how he'd get it across the country though. tennessee? probably find a friend to store it for me until i can get it home. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
utc_pyro Posted April 17, 2022 Share Posted April 17, 2022 tennessee? probably find a friend to store it for me until i can get it home. You'll have to fight infosecdad for it, I think I finally convinced him to come get it next week On the wagon today: I drove it to grab Korean tonight to make sure everything was still in advertised condition and fill it up with gas. I'm going to miss this thing a lot, but proceeds from it are needed for boring things like a washer and drier at the new house. Link to comment Share on other sites More sharing options...
boxkita Posted April 17, 2022 Share Posted April 17, 2022 i'm glad it went to someone who will appreciate it Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted April 17, 2022 Share Posted April 17, 2022 My wife's 2018 wrx got totaled this evening. other than the 6mt, what other parts will work on a 4th gen? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Infosecdad Posted April 17, 2022 Share Posted April 17, 2022 My wife's 2018 wrx got totaled this evening. other than the 6mt, what other parts will work on a 4th gen? Oh crap, hope she's ok. Link to comment Share on other sites More sharing options...
