Scubaboo Posted May 22, 2019 Share Posted May 22, 2019 Rear DBA 4000 T3 slotted rotors to go with the fronts. I was gonna wait till the rears wear out to get these, but I couldnt wait after seeing the fronts! Will pair these with Stoptech Street Performance pads. Weird that these rears come with new caliper hardware but the fronts dont. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted May 22, 2019 Share Posted May 22, 2019 (edited) I'm finally going to give more love to my Legacy, Its front suspension has been moaning for a while. Going to order; From RockAuto.com, front lower control arms [included with ball-joints, should I use these though?] $90 Shipped Whiteline W0506 LCA front bushings. Waiting on a NASIOC member to reply back. SuperPro SPF4865K LCA rear bushings (with 0.5 caster) $110 Shipped on eBay I believe auto-part stores will lend you press kit tools, but it might be easier just to run to a repair shop instead. I'll be listing my old lower control arms up for sale once I swap it all out. Edited May 22, 2019 by ibr_adam09 Link to comment Share on other sites More sharing options...
Niko0422 Posted May 23, 2019 Share Posted May 23, 2019 My serpentine belt has been squealing a lot since last weekend so I bought a new OEM belt. I was planning to install this weekend along with my Perrin light weight crank and water pump pulley, but after doing some research I’ve seen some people claiming that the lightweight pulleys can cause damage to the engine. I also found this video Can anyone advise me whether I should install the Perrin pulleys or not? Link to comment Share on other sites More sharing options...
solgt Posted May 23, 2019 Share Posted May 23, 2019 My serpentine belt has been squealing a lot since last weekend so I bought a new OEM belt. I was planning to install this weekend along with my Perrin light weight crank and water pump pulley, but after doing some research I’ve seen some people claiming that the lightweight pulleys can cause damage to the engine. I also found this video Can anyone advise me whether I should install the Perrin pulleys or not?The biggest thing I took from that video. Is a tuner may need to adjust timing/firing in order to actually benefit/use using a lightweight crank pulley. Personally I have been advised against it. Even for looks. Link to comment Share on other sites More sharing options...
Niko0422 Posted May 23, 2019 Share Posted May 23, 2019 I also asked Perrin the same question and provided them with the video, this was their answer “Thanks for the question and keeping us in mind! Some of this video is accurate but some is not… However! Adding a crank pulley does not do no more harm to the motor than any other performance part you add to the car, so you have nothing to worry about. We have been making the LCP since 2002/03 and have been on thousands of cars with hundreds of thousands miles driven, With not one issue of motor failure or oil pump issues because of it. The reason why you should have nothing to worry about is because Subaru motors are very balanced motors with a really short crank shaft, so there is really not much to balance. Reason why people think there could be an issue, is because they think the Subaru motor is like a V8 or 6 cylinder, where they have a really long crank that needs a harmonic balancer or Dampener. I hope this helps you out, please let me know if you have any more questions or how I can help you further. Thank you!” Link to comment Share on other sites More sharing options...
4thsubaru Posted May 23, 2019 Share Posted May 23, 2019 My serpentine belt has been squealing a lot since last weekend so I bought a new OEM belt. I was planning to install this weekend along with my Perrin light weight crank and water pump pulley, but after doing some research I’ve seen some people claiming that the lightweight pulleys can cause damage to the engine. I also found this video Can anyone advise me whether I should install the Perrin pulleys or not? Good timing I am having the same debate need to change my belt too. lol if you do it I'll do it Link to comment Share on other sites More sharing options...
ripstik Posted May 23, 2019 Share Posted May 23, 2019 Good timing I am having the same debate need to change my belt too. lol if you do it I'll do it just do it, it takes all of 5 minutes. Link to comment Share on other sites More sharing options...
Niko0422 Posted May 23, 2019 Share Posted May 23, 2019 Good timing I am having the same debate need to change my belt too. lol if you do it I'll do it I don’t think I’ll be doing it , I don’t feel comfortable with the agreement/disagreement I’ve seen on whether it’ll be harmful or not Link to comment Share on other sites More sharing options...
GTEASER Posted May 23, 2019 Share Posted May 23, 2019 (edited) The real problems come when you couple a LWCP with a lightened flywheel. You'll be fine with a LWCP. And you only have a 2.5i, not a GT with high cylinder pressures (because turbo) exerting a lot of pressure on the rod and crank bearings. Edited May 23, 2019 by GTEASER GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
dgoodhue Posted May 24, 2019 Share Posted May 24, 2019 I had a LWCP on my '12 2.5i for around 60k miles and sold the car with it on. I think it will be fine. Maybe it is not ideal but I know plenty of owners who have had them on other cars for many miles. It really doesn't do all that much though. I tried before and after with my G-Tech and didn't notice any measurable difference in peak G forces. The only think I seem to notice was that it was was initially more responsive in 1st and 2nd gear. Even though it fit my GT, I didn't bother swapping it. Link to comment Share on other sites More sharing options...
4thsubaru Posted May 24, 2019 Share Posted May 24, 2019 The real problems come when you couple a LWCP with a lightened flywheel. You'll be fine with a LWCP. And you only have a 2.5i, not a GT with high cylinder pressures (because turbo) exerting a lot of pressure on the rod and crank bearings. So what is the sentiment on LWCP for the GT guys & gals? I don't have a light weight flywheel. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted May 24, 2019 Share Posted May 24, 2019 (edited) I've been advised not to do a LW pulley before because they don't do anything worthwhile for the $$, but some do look pretty. I have an ACT lightweight FW. No issues here. Just have to be a little quicker at shifting since the rpms want to drop more rapidly. I believe the the OEM FW is also a heavier dual mass, so some people swap it to a single mass. I think you'll also need a different set of FW bolts if you do this. Edited May 24, 2019 by ibr_adam09 Link to comment Share on other sites More sharing options...
Sarang Posted May 24, 2019 Share Posted May 24, 2019 So what is the sentiment on LWCP for the GT guys & gals? I don't have a light weight flywheel. I don't think there is an option. Correct me if I'm wrong.... Link to comment Share on other sites More sharing options...
GTEASER Posted May 24, 2019 Share Posted May 24, 2019 The one option that was available for the USDM GT is no longer in production. When the time comes to do a clutch I'm going with a LWFW .....because racecar! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Falcor Posted May 24, 2019 Share Posted May 24, 2019 (edited) Getting ready to pull the trigger on a shift plate. I have narrowed it down to Boomba or Cobb. I like the Boomba because of the extra weight, and the Cobb because, well...it's Cobb, and it is 5% shorter (not sure how much difference that will make). Cobb is about $95 and the Boomba is $85.50 with the memorial day discount. Edited May 24, 2019 by Falcor Link to comment Share on other sites More sharing options...
ibr_adam09 Posted May 24, 2019 Share Posted May 24, 2019 Getting ready to pull the trigger on a shift plate. I have narrowed it down to Boomba or Cobb. I like the Boomba because of the extra weight, and the Cobb because, well...it's Cobb, and it is 5% shorter (not sure how much difference that will make). They are both right about $95 unless I can find a memorial day discount somewhere. I vote Boomba! $85 shipped here https://www.ebay.com/itm/Boomba-Short-Throw-Shifter-Transmission-Plate-Bracket-for-15-18-Subaru-WRX-STI/282674576929?hash=item41d0b7be21:g:AcAAAOSwSQFaC87B:sc:USPSPriority!85716!US!-1 Link to comment Share on other sites More sharing options...
GTEASER Posted May 24, 2019 Share Posted May 24, 2019 I will be swapping out my Perrin for a Boomba eventually. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
4thsubaru Posted May 24, 2019 Share Posted May 24, 2019 I don't think there is an option. Correct me if I'm wrong.... Actually I found the following options: https://www.greatnorthperformance.com/product-page/2010-2012-legacy-lightweight-crank-pulley or https://www.greatnorthperformance.com/product-page/2012-17-lightweight-crank-pulley But for use with -2010-2012 Legacy GT must be used with Subaru part number 12339AA010 (some adapter) Link to comment Share on other sites More sharing options...
Sarang Posted May 24, 2019 Share Posted May 24, 2019 I'm skeptical because we've been burned before with incorrect part compatibility listings... But I hope it works. Link to comment Share on other sites More sharing options...
Sarang Posted May 24, 2019 Share Posted May 24, 2019 Getting ready to pull the trigger on a shift plate. I have narrowed it down to Boomba or Cobb. I like the Boomba because of the extra weight, and the Cobb because, well...it's Cobb, and it is 5% shorter (not sure how much difference that will make). Cobb is about $95 and the Boomba is $85.50 with the memorial day discount. Boomba FTW. 5% is a rounding error, so why pay extra for the Cobb sticker? Link to comment Share on other sites More sharing options...
Sarang Posted May 24, 2019 Share Posted May 24, 2019 What do you guys think about this working for our turbos? https://www.cobbtuning.com/products/turbo/subaru-turbo-blanket-wrx-2015-2019 Link to comment Share on other sites More sharing options...
Falcor Posted May 24, 2019 Share Posted May 24, 2019 (edited) Boomba FTW. 5% is a rounding error, so why pay extra for the Cobb sticker? Good point. I already have a couple of those from the AccessPort. Decided on the Boomba plate. Just placed the order. Edited May 24, 2019 by Falcor Link to comment Share on other sites More sharing options...
Niko0422 Posted May 24, 2019 Share Posted May 24, 2019 I will be swapping out my Perrin for a Boomba eventually. Is the boomba better than the Perrin ? Link to comment Share on other sites More sharing options...
Sarang Posted May 24, 2019 Share Posted May 24, 2019 Perrin is not weighted, the Boomba is. I had both in my hands at one point and the Perrin is very slightly shorter throw if I recall correctly. Link to comment Share on other sites More sharing options...
stewdogg Posted May 25, 2019 Share Posted May 25, 2019 I got the Kartboy short shift plate. They claim 38% reduction in shift length and the Boomba claims 30% reduction. I didn't use the bearing that came with it and paired it with the Perrin bushing instead. I like the setup a lot, but only have the stock setup to compare it to. Link to comment Share on other sites More sharing options...
