DrD123 Posted March 22, 2019 Share Posted March 22, 2019 I think realistically it is a bit more than an inch, more like 1.5 ish drop. I added a 1 inch spacer and it still dropped down noticeably. The first bit of compression seems a bit stiffer than stock, but they firm up really quick to way over stock. I would say the firm end of the progressive is about where the 13+ seem to fall if I recall some of the reviews correctly. I love them for their feel, and if you already have other suspension upgrades, swaybars and links then these will complement them nicely. However, if you want a strictly firm suspension these probably aren't for you. I am looking to firm things up a bit - but don't want a significant drop. So maybe I'll go with the 13 springs... I dunno. where do you source spacers? an 0.5" drop would be acceptable, I think... I like the idea of the firmer spring, but which stays more stock-ish for small bumps... Link to comment Share on other sites More sharing options...
Humble Rumble Posted March 22, 2019 Share Posted March 22, 2019 Just sent payment on a set of Raptor headers. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
FLlegacy Posted March 22, 2019 Share Posted March 22, 2019 I am looking to firm things up a bit - but don't want a significant drop. So maybe I'll go with the 13 springs... I dunno. where do you source spacers? an 0.5" drop would be acceptable, I think... I like the idea of the firmer spring, but which stays more stock-ish for small bumps...Anderson design and fabrication. https://andersondesign-fab.com Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
Falcor Posted March 23, 2019 Share Posted March 23, 2019 Just sent payment on a set of Raptor headers. Those are from Australia, correct? Link to comment Share on other sites More sharing options...
Humble Rumble Posted March 23, 2019 Share Posted March 23, 2019 Those are from Australia, correct? Yup. They’ve been out of stock since January (I missed the last set by one day, they sold them the Thursday before my check hit Friday), and will be out of stock until August. Found a brand new set in CT thanks to RikGT and snagged them. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
stewdogg Posted March 26, 2019 Share Posted March 26, 2019 I finally put my order in for my engine upgrades today. ID 1050X injectors with adapters Cobb flex fuel kit with pressure sensor ARP head studs South Bend stage 2 daily Sti 11mm oil pump Billet clutch fork and pivot ball Invidia catted down pipe Link to comment Share on other sites More sharing options...
ibr_adam09 Posted March 26, 2019 Share Posted March 26, 2019 I finally put my order in for my engine upgrades today. ID 1050X injectors with adapters Cobb flex fuel kit with pressure sensor ARP head studs South Bend stage 2 daily Sti 11mm oil pump Billet clutch fork and pivot ball Invidia catted down pipe I believe our cars already have the 11mm oil pump since 2010+ came with dual avcs Link to comment Share on other sites More sharing options...
stewdogg Posted March 26, 2019 Share Posted March 26, 2019 Thanks for the heads up. I checked the part numbers and they are indeed the same between the LGT and STi. I'll switch the oil pump out for an AEM fuel pump. Link to comment Share on other sites More sharing options...
FLlegacy Posted March 27, 2019 Share Posted March 27, 2019 I believe our cars already have the 11mm oil pump since 2010+ came with dual avcs Oh man you just saved me some money too! Thanks a lot. Link to comment Share on other sites More sharing options...
Falcor Posted March 27, 2019 Share Posted March 27, 2019 Did you guys see COBB released some WRX shifter parts along the lines of Perrin, Kartboy, and Boomba? Optional 15% or 35% short throw. https://www.cobbtuning.com/products/drivetrain/subaru-shift-plate-wrx-2015-2019/?utm_source=ET&utm_medium=Email&utm_campaign=Raptor021819 Link to comment Share on other sites More sharing options...
FLlegacy Posted March 27, 2019 Share Posted March 27, 2019 Did you guys see COBB released some WRX shifter parts along the lines of Perrin, Kartboy, and Boomba? Optional 15% or 35% short throw. https://www.cobbtuning.com/products/drivetrain/subaru-shift-plate-wrx-2015-2019/?utm_source=ET&utm_medium=Email&utm_campaign=Raptor021819 Those bastards...why why why do they have to make such a beautiful part and with adjustment options... Link to comment Share on other sites More sharing options...
Humble Rumble Posted March 27, 2019 Share Posted March 27, 2019 Gaaaaaaaad they're beautiful. Actually quite a bit smaller than I was expecting. Either way, time to get busy this year. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
Leggygirl Posted March 28, 2019 Share Posted March 28, 2019 I bought the Kyb struts and mounts to install the springs my boyfriend bought for me 340043 - rear struts 3340106/7- front struts Sm5765 - read mounts Sm5361- front mounts Sb103/sb113- belows But from what I’ve read on the forum it seems like I’m missing some pieces ? Is there something that goes between the mounts and the springs? My car is from 2014 Link to comment Share on other sites More sharing options...
FLlegacy Posted March 28, 2019 Share Posted March 28, 2019 I bought the Kyb struts and mounts to install the springs my boyfriend bought for me 340043 - rear struts 3340106/7- front struts Sm5765 - read mounts Sm5361- front mounts Sb103/sb113- belows But from what I’ve read on the forum it seems like I’m missing some pieces ? Is there something that goes between the mounts and the springs? My car is from 2014 From top to bottom: Front: strut mount->conical washer->coil spring mount->bumpstop->coil spring->lower spring mount->strut/shock. The rear doesn't have the conical washer or bearing in the strut mount. Most people reuse the coil spring mounts as they don't wear out quickly. Link to comment Share on other sites More sharing options...
GTEASER Posted March 28, 2019 Share Posted March 28, 2019 (edited) From top to bottom: Front: strut mount->conical washer->coil spring mountupper spring seat->dust cover->bumpstop->coil spring->lower spring mount->strut/shock. The rear doesn't have the conical washer or bearing or upper spring seatin the strut mount. Most people reuse the coil spring mounts as they don't wear out quickly. FTFY bud! Edited March 28, 2019 by GTEASER GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Leggygirl Posted March 28, 2019 Share Posted March 28, 2019 Thank you! I knew there was something missing. I looked at the Subaru diagram for the front suspension and they only have the mount, spring, strut and bum and dust cover. There’s no conical washer or upper spring seat and rock auto doesn’t seem to have it either . Does Any one have the part numbers? Link to comment Share on other sites More sharing options...
Niko0422 Posted March 28, 2019 Share Posted March 28, 2019 Front 20326aa000 -spacer 20323ag00b- spring seat 20325aa001- rubber seat Rear 20375fg000- spring seat Link to comment Share on other sites More sharing options...
dgoodhue Posted March 28, 2019 Share Posted March 28, 2019 I bought the Kyb struts and mounts to install the springs my boyfriend bought for me 340043 - rear struts 3340106/7- front struts Sm5765 - read mounts Sm5361- front mounts Sb103/sb113- belows But from what I’ve read on the forum it seems like I’m missing some pieces ? Is there something that goes between the mounts and the springs? My car is from 2014 I did not like the KYB dust covers (I assume those are the Sb103/sb113- bellows) I bought a set of them and had to modify them to so they would work and I wasn't happy with the way they came out. I think they are universal dust boost. Link to comment Share on other sites More sharing options...
Leggygirl Posted March 28, 2019 Share Posted March 28, 2019 I also did have a question about the dust cover and the bump stop, is the bump stop suppose to slide down all the way down to that silver plate on the strut? Or does it rest at the top ? When I tried assembling it I had to force it down a bit until it was resting on that silver plate Link to comment Share on other sites More sharing options...
GTEASER Posted March 28, 2019 Share Posted March 28, 2019 I also did have a question about the dust cover and the bump stop, is the bump stop suppose to slide down all the way down to that silver plate on the strut? Or does it rest at the top ? When I tried assembling it I had to force it down a bit until it was resting on that silver platePut it toward the top. Suspension compression will move it up there anyway. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
islandborn Posted March 28, 2019 Share Posted March 28, 2019 The LAST Blast plate! Figured since its out...... Link to comment Share on other sites More sharing options...
GTEASER Posted March 28, 2019 Share Posted March 28, 2019 The LAST Blast plate! Figured since its out......Do you mean you ordered the last one that Vince had available? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
A_A_ron Posted March 28, 2019 Share Posted March 28, 2019 Good! I was worried we talked him into doing a limited run and no one bought any. Build Thread Link to comment Share on other sites More sharing options...
ibr_adam09 Posted March 28, 2019 Share Posted March 28, 2019 The LAST Blast plate! Figured since its out...... Is that this? https://www.ebay.com/itm/Transmission-Reinforcement-legacy-gt-fifth-gen-blast-plates-wrx-2015-6mt-blast-/253523921512?nma=true&si=jkWn5udE5cC7Phw4mCRwwygJdns%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557 Link to comment Share on other sites More sharing options...
GTEASER Posted March 28, 2019 Share Posted March 28, 2019 Yes. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
