1of1547 Posted April 25, 2016 Share Posted April 25, 2016 Ok just checking. Thanks guys Link to comment Share on other sites More sharing options...
pinesol Posted April 26, 2016 Share Posted April 26, 2016 You have to hit the pin dead straight on and it will come out even though it doesn't seem like it will budge. It is a big PITA but that is what you have to do. I used a socket and extension on my punch to get a good angle on the pin. Thanks! You were of course correct. However, my punch just wasn't doing the trick to remove both the inner and outer components of the pin at the same time. I used a 3/8" drive hex bit socket that was a bit smaller than my punch and was able to separate the inner and outer pieces. After that, the punch made short work of the rest of it and I had my Boomba piece installed not 10 minutes later. What a difference! Link to comment Share on other sites More sharing options...
FLlegacy Posted April 26, 2016 Share Posted April 26, 2016 Glad you got it! I can't imagine trying to drill that pin out. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
Zakster87 Posted June 23, 2016 Share Posted June 23, 2016 Alright, just to triple check, the boomba short shift lever for the 15 WRX is a direct swap for the STI short shifter in my 2010 GT, correct? I saw people had it installed, I just want to know if there was any headaches making it work with the LGT. Link to comment Share on other sites More sharing options...
GTEASER Posted June 23, 2016 Author Share Posted June 23, 2016 Alright, just to triple check, the boomba short shift lever for the 15 WRX is a direct swap for the STI short shifter in my 2010 GT, correct? I saw people had it installed, I just want to know if there was any headaches making it work with the LGT. Yes it works, but there's something wonky about the throws being shorter in 5-6 than in 1-2. http://legacygt.com/forums/showthread.php/short-shifter-did-go-wrongi-251891.html?t=251891&highlight=boomba http://legacygt.com/forums/showthread.php/boomba-stick-uneven-throws-245289.html?t=245289&highlight=boomba Please keep the Boomba short shift lever info in a Boomba thread, not this one. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
jojorios Posted September 6, 2016 Share Posted September 6, 2016 Just wanted to add to this. Since install I was using the stock shift knob and got very used to it, to the point that I didn't think I needed a weighted shift knob. I recently came across a used Raceseng Ashiko and said wth i'll try it for the price. I get it now.....it's just shifts so smooth. Link to comment Share on other sites More sharing options...
Zee199969 Posted September 6, 2016 Share Posted September 6, 2016 Just wanted to add to this. Since install I was using the stock shift knob and got very used to it, to the point that I didn't think I needed a weighted shift knob. I recently came across a used Raceseng Ashiko and said wth i'll try it for the price. I get it now.....it's just shifts so smooth. haha, I had the same thought. Especially when you consider the price is over $100 for one of the Raceseng shift knobs. After install and paired with the Perrin bushing and SSA, I have absolutely no regrets My "Build" Link to comment Share on other sites More sharing options...
SURFNSLACKER Posted September 8, 2016 Share Posted September 8, 2016 Thanks guys...now I'm going to order a weighted knob Link to comment Share on other sites More sharing options...
ripstik Posted September 8, 2016 Share Posted September 8, 2016 Thanks guys...now I'm going to order a weighted knob right behind you. Link to comment Share on other sites More sharing options...
brandon.mol Posted September 10, 2016 Share Posted September 10, 2016 http://uploads.tapatalk-cdn.com/20160910/6806ead7c01b5562853825766053f61e.jpg Bazinga! Link to comment Share on other sites More sharing options...
blklgt05 Posted September 10, 2016 Share Posted September 10, 2016 http://i154.photobucket.com/albums/s253/blklgt05/IMG_6658_zpsbzxecows.jpg mod journal Link to comment Share on other sites More sharing options...
FLlegacy Posted September 10, 2016 Share Posted September 10, 2016 http://uploads.tapatalk-cdn.com/20160910/6806ead7c01b5562853825766053f61e.jpg Bazinga! http://i154.photobucket.com/albums/s253/blklgt05/IMG_6658_zpsbzxecows.jpg Those are some nice knobs! Link to comment Share on other sites More sharing options...
brandon.mol Posted September 10, 2016 Share Posted September 10, 2016 Heh. For colour reference, mine is the charcoal translucent powder coated and Blk's is uncoated, I think. Mine is virtually identical colour to the console trim. The powder coating seams to be enough to keep it from getting really hot or cold, so I'd definitely recommend the powder coating. Link to comment Share on other sites More sharing options...
Zee199969 Posted September 10, 2016 Share Posted September 10, 2016 I've got the Raceseng Slammology shift knob. It's not quite as heavy as the Ashiko, but it is made of a delrin cover, which keeps the temps way down even when its 110F+ inside the car My "Build" Link to comment Share on other sites More sharing options...
GTEASER Posted December 21, 2016 Author Share Posted December 21, 2016 For posterity. Torque Solution's take on the SS adapter. http://www.torquesolution.com/wrx-va-short-shifter-p/ts-ss-023c.htm GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
FLlegacy Posted December 22, 2016 Share Posted December 22, 2016 As soon as I can stomach the cost I am going to get a raceseng shift knob, lol. I don't know how long that will take... Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
jojorios Posted December 22, 2016 Share Posted December 22, 2016 The only thing I seriously have come to dislike is when it's freezing out. The Ashiko is like holding an ice cube. After 45 mins, the thing is still ice cold. Sent from my SM-G935F using Tapatalk Link to comment Share on other sites More sharing options...
Zee199969 Posted December 22, 2016 Share Posted December 22, 2016 The only thing I seriously have come to dislike is when it's freezing out. The Ashiko is like holding an ice cube. After 45 mins, the thing is still ice cold. Sent from my SM-G935F using Tapatalk The delrin Slammology warms up pretty quick. The downside is it isn't quite as heavy as the ashiko My "Build" Link to comment Share on other sites More sharing options...
FLlegacy Posted December 22, 2016 Share Posted December 22, 2016 I really want the one brandon got, but my metal shift knob now requires one of my babys old socks in the summer because it gets so hot. Link to comment Share on other sites More sharing options...
Zee199969 Posted December 22, 2016 Share Posted December 22, 2016 I really want the one brandon got, but my metal shift knob now requires one of my babys old socks in the summer because it gets so hot. this is what I have: http://www.raceseng.com/slammology-shift-knob-subaru-6-speed-manual# And it never gets too hot My "Build" Link to comment Share on other sites More sharing options...
brandon.mol Posted December 23, 2016 Share Posted December 23, 2016 The only thing I seriously have come to dislike is when it's freezing out. The Ashiko is like holding an ice cube. After 45 mins, the thing is still ice cold. Sent from my SM-G935F using Tapatalk This is true. With the powder coating you never feel like you hand will freeze to it, but yeah.. It can stay cold for hours with all that mass. Needs a beanie. Link to comment Share on other sites More sharing options...
ripstik Posted December 27, 2016 Share Posted December 27, 2016 This is true. With the powder coating you never feel like you hand will freeze to it, but yeah.. It can stay cold for hours with all that mass. Needs a beanie. gets you one of these Link to comment Share on other sites More sharing options...
GTEASER Posted December 28, 2016 Author Share Posted December 28, 2016 Where do I get one of those? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ripstik Posted December 28, 2016 Share Posted December 28, 2016 Where do I get one of those? on etsy but they aren't allowed to sell to the US because of copy right issues... maybe one of our Canadian brethren can ship them down to us Link to comment Share on other sites More sharing options...
Humble Rumble Posted December 28, 2016 Share Posted December 28, 2016 What copyright could that possibly be infringing on? 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
