kopy_kat Posted May 13, 2006 Share Posted May 13, 2006 Did my first oil change today @ 2300 miles.. i got lazy @ 1k, then i got busy.. ANYWAYS... super easy! love the placement of the oil filter.. IT WAS ON SOOO TIGHT!! couldn't get it off. i need to work out! had to ask my neighbor to help me get it filter off.. i did not get the splashing that everybody said they got.. it drained nicely.. but woohoo!! used dino oil.. wait til 7.5-10k.. will start using full synth then. Link to comment Share on other sites More sharing options...
Lagacy GT Posted May 27, 2006 Share Posted May 27, 2006 where do you guys get your drain plug gasket/crush washers? My local autozone did not have them in 20 mm size. Link to comment Share on other sites More sharing options...
Ed_T Posted May 27, 2006 Share Posted May 27, 2006 I don't jack my LGT up for oil changes/oil drain. I'm fairly slender though and it takes a bit of contorting to get to the drain plug w/o jacking the car up. Dude if a tire goes flat while you're under there.... Link to comment Share on other sites More sharing options...
kopy_kat Posted May 30, 2006 Share Posted May 30, 2006 where do you guys get your drain plug gasket/crush washers? My local autozone did not have them in 20 mm size. i get them at my local subbie dealer.. Link to comment Share on other sites More sharing options...
vincedog3 Posted May 30, 2006 Share Posted May 30, 2006 Thank you Opie for the great procedure for oil change. Heck I didn't even know about the crush washer being a one time deal. Learned lots here. Thanks again. For your car audio/video needs:D Audio Crafters IS it. In Pasadena Ca. Arthur rules. www.audio-crafters.com Link to comment Share on other sites More sharing options...
tc11003 Posted June 14, 2006 Share Posted June 14, 2006 Did mine tonight so here they are! http://www.thel7.com/Mods/2005_Legacy_GT_Oil.pdf Let me know what you think! excellent!!!!!!!! Link to comment Share on other sites More sharing options...
Lagacy GT Posted June 15, 2006 Share Posted June 15, 2006 Wow that was much more work than I care to do. First, I couldn't crawl under the car. I'm 5'9" 175lbs, not exactly fat. I couldn't even fit my head under the car. 7 1/2 hat size. So maybe that's it? Well anyway, jacked it up with the spare tire jack and put blocks of wood under the car. Then had to use all my might and a few tools to loosen the damn filter and plug (3rd oil change so shouldn't have been so tight). Then it drained like an exploding bladder. blah blah blah. I think i'll just pay the dealer to change the oil. Link to comment Share on other sites More sharing options...
kopy_kat Posted June 27, 2006 Share Posted June 27, 2006 this is sort of a side question. first of all, let me emphesize that i am just all thumbs. the fact that i did an oil change is amazing. i guess the thing is getting there so i can do things myself. that said... i've been reading up on synth oil and the weak link is usually the filter not being able to do its job while the oil is still good. many of the peeps here have been doing 8k oil changes w/ filter changes @ 4k. my question is, can i change the filter w/out the spilling out everywhere? is there just the oil in the filter reserve?? or once i remove the filter, i have to get the new one in there as quickly as i can? thanks in advance. late, k Link to comment Share on other sites More sharing options...
nicheplayer Posted June 28, 2006 Share Posted June 28, 2006 Whew! I changed the oil / filter in my 06 Outback last night (Mobil 1 and OEM filter), and I was really stymied by the filter removal. It's not that it was terribly hard to unscrew (eventually), but that it is completely tucked away and nestled on all sides by what looks like exhaust manifold. Finally yanked it out with a channel lock and crushed it pretty bad, but I was able to tighten the replacement to SOA's specs just using my hand, thank God. Link to comment Share on other sites More sharing options...
Ed_T Posted June 28, 2006 Share Posted June 28, 2006 Is anyone using Synthetic oil? My LGT have 5000 on it and I'm planning on changing the oil next weekend. I'm not used to the whole turbo thing yet. I don't want to blow it up. That's all I use. So far, Mobil 1 10w-30 (pre-EP product, the current one might have less additive) (the least consumption) Mobil 1 TSUV 5w-40 (discontinued product) (fair amount of consumption) Shell Rotella Synthetic 5w-40 (fair amount of consumption) Vavoline Maxlife 10w-30 - in there now. (no consumption yet, 1,000 miles) Mobil 1 oil filters. You don't get the blackening nearly as bad as with dinosaur juice, and can run longer (I don't exceed 7.500 miles). Link to comment Share on other sites More sharing options...
fatbastard Posted July 23, 2006 Share Posted July 23, 2006 Well I just did my first oil change on the LGT this morning and I wish I read this thread first. Holy crap I thought I made a HUGE mistake! I have never seen oil come out like that, it was almost like it was under pressure. Oil filter was wicked tight...I eventually got it (obviously) but the filter wrench I had was useless, I'l have to pick up a smaller one for next time. Besides the scare the change was painless but there was one thing I realized I do not like. The damn dipstick has the low and full marker hole dead center but the hot full is a notch. This notch tens to grab bits of what ever your wiping your stick with. I think sometime when I get a chance I will take those corners off so it doesn't grab so easily. Anyone have another suggestion? Link to comment Share on other sites More sharing options...
Nachowang Posted July 24, 2006 Share Posted July 24, 2006 Did my first oil change on the legacy too, wasnt too bad. Only trouble I had was removing the bolt to drain the oil. That sucker was on there tight!! Had to bang the wrench with the hammer to get it off. The oil filter came off easily with the filter wrench. All in all took me about 30 minutes. Would have been quicker if I had the ramps. Link to comment Share on other sites More sharing options...
Spec-B GT Posted August 5, 2006 Share Posted August 5, 2006 Nice write up, it came in handy locating the oil drain nut. Anyways, I used Mobil 5000 5w-30 and a K&N oil filter. Link to comment Share on other sites More sharing options...
ahains Posted August 20, 2006 Share Posted August 20, 2006 Sorry if this was already mentioned (only read half of the thread), but I recommend you pour oil in the new filter before you start. After you fill it the first time and let it sits a few minutes, it looks dry in there because it all soakes into the filter material. I had to fill up the filter 3 times before it stayed full. I topped it off between each of the other steps. Link to comment Share on other sites More sharing options...
EnvoyEd Posted September 4, 2006 Share Posted September 4, 2006 Where did you guys get the Fumoto valves? Getting ready for my first oil change. Ed in Philly Link to comment Share on other sites More sharing options...
mickeyd2005 Posted September 4, 2006 Share Posted September 4, 2006 I got mine here: http://www.fumotovalve.com/ The valve lever location will be hit or miss based upon the threads. In my particular case, if I used the standard Subaru crush washer, the valve lever would be inaccessible, but when I used the fabric washer included with the valve, it worked just fine. YMMV. Link to comment Share on other sites More sharing options...
lhsa Posted September 5, 2006 Share Posted September 5, 2006 i just took my fumoto valve off my 06 LGT and transferred it to my 05 LGT. the fit was great on the 06 with no clearance problems whatsoever. on the 05, though, the clearance was really, really close. around a thin sheet of paper depth. thank God it cleared and tightening took some creative steps, as well. i'm excited to have it on because its so much easier to change oil with it! Link to comment Share on other sites More sharing options...
HuskerScooby Posted September 10, 2006 Share Posted September 10, 2006 Hey guys, I just did my first oil change on my legacy and found the OE filter is about the same size or smaller than even honda cars i've owned in the past. That's a 1.5L to a 2.5L using a smaller filter?! Some of the guys I used to run with would use an aftermarket one that was "oversized" for better flow. I was planning on doing this with mine once I saw how tiny the filter was. I was originally planning on running a WIX filter anyhow, nothing against OE, but I've seen cut-outs of the WIX and it's a very well-made filter. Anyhow, if you buy a NAPA Gold filter it's the same as a WIX, and NAPA oil is the same as Valvoline, fyi. Turns out the NAPA Gold filter was already probably 30% greater in size, so I didn't need to find a cross-reference of threads to find an oversized filter for my car. I guess in simpler terms if you want an oversized filter just buy a NAPA Gold filter, which is made by WIX. And if you want good cheap oil NAPA oil is made by Valvoline. Link to comment Share on other sites More sharing options...
HuskerScooby Posted September 10, 2006 Share Posted September 10, 2006 TIP: Oh and about the actual changing of the oil, first I jacked up the car and put them on jack stands, drained the oil, but I KNEW there was still old oil inside so, I took the passenger side jack out while supporting it with a hydraulic jack, i lowered the passenger tires to the ground and VOILA got a bit more of the old oil out! BONUS TIP: for stubborn filter removal, use a piece of sandpaper wrapped around the filter, NEVER had a problem removing one, shouldn't anyway because it is 1 complete turn of the filter after it is seated. Link to comment Share on other sites More sharing options...
umcp Posted September 11, 2006 Share Posted September 11, 2006 This thread was a great help for me. I installed my Fumoto Valve with no issues. But oil did spurt out like it was under pressure, caught me off guard for a second and my hand was covered in oil. Link to comment Share on other sites More sharing options...
al-gorithm Posted September 11, 2006 Share Posted September 11, 2006 I should have got the valve with the nipple, would have been a lot cleaner Link to comment Share on other sites More sharing options...
umcp Posted September 11, 2006 Share Posted September 11, 2006 I bit the bullet and got the Nippled fumoto and am relieved that I didn't have any fitment issues. It is well within the plastic shroud and doesn't come close to hitting any underbody components. Also a note for the guide, I noticed on my 06 LGT that there are only 3 screws and a 'hinge' screw on the panel that covers the oil filter. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted September 12, 2006 Share Posted September 12, 2006 3 screws? Did 2 fall out? I have 5 screws and one hinge. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted September 12, 2006 Share Posted September 12, 2006 Seems like a strange cost savings measure to change from 5 to 3 going from the 2005 to 2006 LGT. Link to comment Share on other sites More sharing options...
umcp Posted September 13, 2006 Share Posted September 13, 2006 Ya, I thought it was wierd also to change from 5 to 3 screws and waste money making a new mold for the 06 tray. I'm sure it was 3 screws and 1 hinge. Link to comment Share on other sites More sharing options...
