careercadaver Posted September 30, 2014 Author Share Posted September 30, 2014 It's #2 that's misfiring...so it should at least be easy to get to. I'll check the coil tonight and I that doesn't change things I'll check the plug. For the price of cleaning I may as well buy a use set of injectors for $100...just OE. Link to comment Share on other sites More sharing options...
careercadaver Posted October 1, 2014 Author Share Posted October 1, 2014 Today I started it up and it began misfiring pretty badly...CEL came on...rant to Advanced ran a code and I had the P0203 and now a P0201... :/ Ran home swapped the coilpack I had lying around and reset the ecu. No hesitation under WOT and no CEL!! Stoked!! Finally feels like there might be light at the end of this tunnel as opposed to the train I keep envisioning... Going to have the shop that built the block do a compression test and of all is good I'll be ready for a tune!! Link to comment Share on other sites More sharing options...
Tehnation Posted October 2, 2014 Share Posted October 2, 2014 Glad to hear your heading in the right direction. If you have a laptop and any of the cheap vag com cables you can check your fuel trims, log and check cel's. Rather than running to auto parts store. i keep my laptop under my front seat and have a car adaptor for my laptop, anytime i get a cel i pull over and jack in. Link to comment Share on other sites More sharing options...
careercadaver Posted October 2, 2014 Author Share Posted October 2, 2014 I was just right there. Ran over to a friends and had him log it. There is still an intermittent mis on cylinder 1 that we believe is injector related. It went away above 1500rpms and there was no sign under wot. Going to boost leak check I and get it to my tuner!! Link to comment Share on other sites More sharing options...
careercadaver Posted October 3, 2014 Author Share Posted October 3, 2014 Did the compression test today and everything can back good!! 142--I--146 141--I--146 Also had them do a boost leak check while I was there and we found one or two I had overlooked. I am officially ready for a tune! Link to comment Share on other sites More sharing options...
Tehnation Posted October 3, 2014 Share Posted October 3, 2014 More boost please!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
careercadaver Posted October 3, 2014 Author Share Posted October 3, 2014 More boost please!!!!!!!!!!!!! Hoping very soon!! Gotta get this tuner to call me back! Lol I'd meet him today if I could! Link to comment Share on other sites More sharing options...
careercadaver Posted October 12, 2014 Author Share Posted October 12, 2014 At this point I've still yet to hear from my preferred tuner. Might have to look elsewhere if I don't hear back soon. In the meantime, I have decided to swap suspension set-ups in favor of Koni's and an Eibach Pro Kit. Should have everything in by the 15th and hoping to have it all on the car over that weekend. BC's are posted FS. Still piecing the OE stuff as I did not have any of the stock suspension with the car. Link to comment Share on other sites More sharing options...
careercadaver Posted October 17, 2014 Author Share Posted October 17, 2014 http://tapatalk.imageshack.com/v2/14/10/17/e75b675952193460c6d5a9d0ce4fb530.jpg http://tapatalk.imageshack.com/v2/14/10/17/19d1434d954f89851890054dc3e47871.jpg http://tapatalk.imageshack.com/v2/14/10/17/2811e6ca2904f12447736b112a476fde.jpg Let the fun begin!! Link to comment Share on other sites More sharing options...
Eliott Posted October 18, 2014 Share Posted October 18, 2014 http://tapatalk.imageshack.com/v2/14/10/17/e75b675952193460c6d5a9d0ce4fb530.jpg http://tapatalk.imageshack.com/v2/14/10/17/19d1434d954f89851890054dc3e47871.jpg http://tapatalk.imageshack.com/v2/14/10/17/2811e6ca2904f12447736b112a476fde.jpg Let the fun begin!! Saw your hunt for a spring/strut setup, glad you got it! I'd like a comparison to your bc's once you've ridden on them for awhile. Might be making the switch as well. Link to comment Share on other sites More sharing options...
careercadaver Posted October 18, 2014 Author Share Posted October 18, 2014 Sure thing man! Just waiting on a few pieces that are supposed to arrive today...but it's looking as though it will be Monday... :/ Link to comment Share on other sites More sharing options...
careercadaver Posted October 19, 2014 Author Share Posted October 19, 2014 Well, I got the fronts together today. My spring compressor will not compress the rear springs enough to get the top hats on. Hoping to find something locally tomorrow to make this happen. Link to comment Share on other sites More sharing options...
careercadaver Posted October 24, 2014 Author Share Posted October 24, 2014 Got the rears assembled and struts are on the car!! Drive around the bloc] and the car feels like it makes far better contact with the road. This is likely to do with my poor alignment...in any case I'll be driving quite a bit this weekend so once the springs settle I'll give a more accurate review but this far they are stiff but surprisingly comfortable. It will be nice to get some different tires on it too...these are worn pretty heavily... http://tapatalk.imageshack.com/v2/14/10/24/4d2a76ca71930b78fdc48ce593c35bf2.jpg Before: http://tapatalk.imageshack.com/v2/14/10/24/9d73b5a82182b078aac157d5a9b25bed.jpg http://tapatalk.imageshack.com/v2/14/10/24/d98f2bf6e22dbf39756d3f503fb68d0b.jpg After: http://tapatalk.imageshack.com/v2/14/10/24/3b4390024ef3a2182cc6eaf7ea4ea0e3.jpg Link to comment Share on other sites More sharing options...
careercadaver Posted October 24, 2014 Author Share Posted October 24, 2014 Put about 100mi on this far...starting to settle. http://tapatalk.imageshack.com/v2/14/10/24/a3c17c25fb9def55d28643b124bb38a5.jpg So far ride is immensely better. Hoping it gets a little more comfortable after they fully settle and an alignment but this far I'm thrilled! Link to comment Share on other sites More sharing options...
MrTris Posted October 24, 2014 Share Posted October 24, 2014 I can't really see a difference in ride height.. Link to comment Share on other sites More sharing options...
careercadaver Posted October 24, 2014 Author Share Posted October 24, 2014 I can't really see a difference in ride height.. I'll try and get pics in better lighting. It's up at least 2.25" in the back, about 1.25" in the front compared to where they were on the coils. Link to comment Share on other sites More sharing options...
magnusonsubie Posted October 28, 2014 Share Posted October 28, 2014 How do you like the Eibach springs? I went back and forth a bit between those and the H&R's before getting the H&R/s for my wagon. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
careercadaver Posted October 28, 2014 Author Share Posted October 28, 2014 How do you like the Eibach springs? I went back and forth a bit between those and the H&R's before getting the H&R/s for my wagon. So far they're great! Ride is still stiff but comfortable. I think they will soften up a bit more with a few more miles on them. Going to wIt another week before playing with the alignment. Figure I'll swap tires at the same time and be done for winter. Link to comment Share on other sites More sharing options...
careercadaver Posted November 4, 2014 Author Share Posted November 4, 2014 Koni's are better and better each day! They are breaking in and are more and more confidence inspiring! There is definitely more body roll but I will be slapping on some sways come spring to combat that. Picked up a ID Top Feed Conversion set-up, Perrin FPR and SS lines today. Lines and regulator came with side feed rails that I'll be looking to part with if anyone is interested. All sh9uld be in the mail today. I also picked up some Perrin Exhaust hangers and wrap for the exhaust. Driving a bit more I'd like a little less competition with the radio on the highway. lol Link to comment Share on other sites More sharing options...
leoh88 Posted November 5, 2014 Share Posted November 5, 2014 Well, someone fell in love with his Legacy again... Link to comment Share on other sites More sharing options...
careercadaver Posted November 5, 2014 Author Share Posted November 5, 2014 It's a love hate thing...it's what makes a Subaru a Subaru. Really just trying to get things finished up before snow is a constant. Getting snow tires and an alignment done next week. And getting Dyno tuned Saturday...I've only ever done road tunes so I'm not really excited about the extra cash...but it's one of the top tuners in the area and he's far closer than normal. Him being somewhat local saves me about 4hrs of driving... Link to comment Share on other sites More sharing options...
careercadaver Posted November 8, 2014 Author Share Posted November 8, 2014 On my way to get a tune!! Been a long road...hopefully there are no other speed bumps today. I was unable to get my ID1000 set-up installed prior but I really wasn't planning to push much beyond the Capacity of the OE side feeds at this point...but that may change come spring. Link to comment Share on other sites More sharing options...
careercadaver Posted November 8, 2014 Author Share Posted November 8, 2014 317.88whp@18.5psi/352lbs@3300rpm http://tapatalk.imageshack.com/v2/14/11/08/e266f8675f74988d02726e9dd59f9d9e.jpg http://tapatalk.imageshack.com/v2/14/11/08/293fcd92403e29b3da04e1a0ea63b801.jpg https://vimeo.com/111299112 Link to comment Share on other sites More sharing options...
MrTris Posted November 9, 2014 Share Posted November 9, 2014 Yay! GOOD JOB!! Link to comment Share on other sites More sharing options...
kzr750r1 Posted November 9, 2014 Share Posted November 9, 2014 352 is stout! Nice job. Link to comment Share on other sites More sharing options...
