hobo2701 Posted September 2, 2013 Author Share Posted September 2, 2013 I love my 6 speed. perfect for those big setups with spool since the 6 speeds gearing is shorting. let me know if u do a 6 speed. I got a whole excel spreadsheet with parts/part numbers and pricing from my swap. Perfect ! Proly gonna start sourcing parts after the holidays so I def will be hitting u up . Link to comment Share on other sites More sharing options...
boxkita Posted September 2, 2013 Share Posted September 2, 2013 I love my 6 speed. perfect for those big setups with spool since the 6 speeds gearing is shorting. let me know if u do a 6 speed. I got a whole excel spreadsheet with parts/part numbers and pricing from my swap. post to the 6mt swap thread so others can benefit, too? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
thisisthenewsic Posted September 2, 2013 Share Posted September 2, 2013 Will do ^^ Link to comment Share on other sites More sharing options...
stuck686 Posted September 3, 2013 Share Posted September 3, 2013 how much would a 6speed swap run? Link to comment Share on other sites More sharing options...
thisisthenewsic Posted September 3, 2013 Share Posted September 3, 2013 Mine cost me about 4500$ out of pocket. Got about 2k back from all my old parts. Total up front cost about 6500$ but I didn't cheap out on anything. It can be put together for cheaper. But at least about 5-5500$ Link to comment Share on other sites More sharing options...
brum Posted September 9, 2013 Share Posted September 9, 2013 04 STi 6 speed - ~2000-3000 Axles - ~500 Shifter assembly - ~300 clutch/flywheel - ~600 maybe crossmember - ~200 Link to comment Share on other sites More sharing options...
boxkita Posted September 9, 2013 Share Posted September 9, 2013 did that price include the dccd pro and front lsd diff? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
thisisthenewsic Posted September 9, 2013 Share Posted September 9, 2013 04 STi 6 speed - ~2000-3000 Axles - ~500 Shifter assembly - ~300 clutch/flywheel - ~600 maybe crossmember - ~200 That's a very short list. No cross member but you either need a auto driveshaft or custom. Also axles are almost impossible to find used, new is really the only way. Also if switching to spec b axles add the r180 rear diff. I'll post my excel spreadsheet tonite if I remember. Link to comment Share on other sites More sharing options...
thisisthenewsic Posted September 10, 2013 Share Posted September 10, 2013 06 sti transmission w/shift linkage $2,500 06sti rear diff $425 rear spec b axles $750 dealership 28421AG03B rear diff axle seals $20 both 806732200 driveshaft 6 speed/r180 (spec b/05-09 4eat) $600 1(866)4556622 Jeff Driveshaft Specialist (i went with custom built, not auto driveshaft) spec b shifter rod $31 35041AG020 spec b shifter stay $51 35031AG020 Downpipe support bracket $24 44021fe030 6mt clutch hose $27 goodridge 6mt slave cylinder $50 Reverse lockout cable $75 35060ag010 clutch kit(act hd-ss sti) $650 circuitmotorsports sti flywheel $100 cobb sts/knob/bushings $190 (used 6 speed) torque solutions(engine/trans/pitch mount) $485 mtrperformance.com (only need trans mount but i replaced all of them) clutch fork spring $8 whiteline rear diff bushing $130 rallysportdirect.com kdt901/903/905 (extras i added to tighten up the drivetrain spec b rear aluminum diff mount $133 41310ag040 05 STi 6MT front half shaft seals $20 both L/H 806735240 R/H 806735230 Link to comment Share on other sites More sharing options...
thisisthenewsic Posted September 10, 2013 Share Posted September 10, 2013 forgot to add, the dccd pro controller which is 545$ so thats another expense. the trans can be driven without it no problem. Link to comment Share on other sites More sharing options...
hobo2701 Posted September 10, 2013 Author Share Posted September 10, 2013 damn.. between that and a rotated turbo setup its proly gonna cost me around $10k for the next round of improvements. but seems worth it if im gonna go for more power. would hate to be left stranded with a blown tranny. Link to comment Share on other sites More sharing options...
boxkita Posted September 10, 2013 Share Posted September 10, 2013 do the tranny before anything else. It's an expensive replacement. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
thisisthenewsic Posted September 11, 2013 Share Posted September 11, 2013 yes^^ i did my 6 speed first, and now im building my motor. both pricey but atleast you know the parts have no miles/low miles. my car has 143k on it. replaced the trans with a 6 speed that has 24k on it. rear diff 24k everything else new. and when i rebuild my motor everything will be brand new and fresh. pricey but its like having a "brand new" car LOL just alot faster than off the assembly line Link to comment Share on other sites More sharing options...
hobo2701 Posted October 12, 2013 Author Share Posted October 12, 2013 Alcon love 6 piston mono bloc Link to comment Share on other sites More sharing options...
thisisthenewsic Posted October 12, 2013 Share Posted October 12, 2013 Damn. How much did those set you back. :0 Link to comment Share on other sites More sharing options...
hobo2701 Posted October 12, 2013 Author Share Posted October 12, 2013 damn. How much did those set you back. :0 2500 Link to comment Share on other sites More sharing options...
KBGRIZZLY64 Posted October 13, 2013 Share Posted October 13, 2013 I love and equally hate everything this thread withholds... Priorities change when car parts come into the equation Link to comment Share on other sites More sharing options...
hobo2701 Posted October 13, 2013 Author Share Posted October 13, 2013 Instead of being 1 of 48 I wanted 1 of 1 ultimate unicorn power can't wait for subie meet next year Link to comment Share on other sites More sharing options...
Snow Trooper Posted October 13, 2013 Share Posted October 13, 2013 Yes! It is so ironic and fitting that you ended up with a kit on the car that we designed at STaSIS. Unicorn status further cemented. Link to comment Share on other sites More sharing options...
thisisthenewsic Posted October 13, 2013 Share Posted October 13, 2013 2500 Used?? Link to comment Share on other sites More sharing options...
hobo2701 Posted October 13, 2013 Author Share Posted October 13, 2013 Used?? Ya but they go for around 4000 new Link to comment Share on other sites More sharing options...
JJr Posted October 14, 2013 Share Posted October 14, 2013 Never got to go for a ride in your beast, did you move back east? Link to comment Share on other sites More sharing options...
hobo2701 Posted October 14, 2013 Author Share Posted October 14, 2013 Never got to go for a ride in your beast, did you move back east? Ya but will be back out this winter for tranny swap party Link to comment Share on other sites More sharing options...
hobo2701 Posted October 16, 2013 Author Share Posted October 16, 2013 Brakes get in this weekend homie said there is only one other set made with these stasis mounting brackets which ironically was designed by Jared my tuner at vlmspec in Truckee ca Lake Tahoe back when he worked for stasis as the head engineer thanks again to josh who I bought them from and if anyone needs proper car work the guy does everything from tuning to custom fab part sourcing and everything in between . Guy knows his stuff on anything from Porsche Ferrari subie evo and especially audis so hit this guy up his website is vlmspec.com or hit my up and i can give ya his digits and I'm gonna be working with him this spring so come by !! ;)thx again for all the lgt love from everyone one here Link to comment Share on other sites More sharing options...
JJr Posted October 19, 2013 Share Posted October 19, 2013 Ya but will be back out this winter for tranny swap party I need to take a 30 min trip to Truckee when the snow starts to fall:) Link to comment Share on other sites More sharing options...
