stuck686
    580
Everything posted by stuck686
  1. Bump still have these. The shocks are $250 on amazon The springs are about .9" drop so mild
  2. Had these on about a month before getting another full set of Bilsteins. Never saw snow. Like new! $200+ shipping Best to txt me if you want them- 612.nine16.7900
  3. Yes I haven't posted in years, yes I still have my lgt.. 145k A few months ago I bought a set of brand new bilsteins for the rear and had them mounted with whatever springs I had (tein h think? About 1" drop). Now recently I bought a full set of Bilsteins mounted with pinks so I installed those instead. So I am selling the almost new rear set loaded with springs. I can check shipping but let's say $300 shipped give or take. Zero Issues, still clean don't need them sitting around. I know I will forget to check this so just txt me: 612-nine1six-7900
  4. could LCA bushings be responsble for a freeway speeds Shimmy and steering wheel play that comes and goes. If i take a corner or switch lanes it sometimes goes to firm steering feel with no play and etc
  5. had cyl 3 misfire due to poor coil pack connector, replaced coil pack just in case. Drive and idles fine now, except when it high boost it does sort of a stutter/surge and Roughness count in Cyl 3 goes up. injector or plug??? maybe the poor connection and misfire fouled up the plug a bit
  6. MNlegacygt type in without spacing out. We might have a meet Sat around 6/7pm
  7. Just curious what are some signs of worn out bushings? I was told mine look fine but my steering feels a bit loose at high speed and I also have some vibration when driving (tires are balanced.) Possibly have warped rotors too but curious how to rule our bushings
  8. is there anything else I have to buy thats not in the exedy kit or TSK3 kit?? any bearings?? wont be doing the work myself
  9. in the market for a new clutch...prob going with Exedy stage 1 i have already sourced a TKS3 kit and slight used 08 wrx flywheel
  10. Join MNLegacyGT group on facebook! also MNSUBIEZ is the local fbook group
  11. Not true, GS used my car 4+ times to test fit and also for the splitter. if anything its possible u got shipped a wrx top mount
  12. is this worth it??? im gonna buy the Grimmspeed one since they are by my house
  13. [ame=http://www.youtube.com/watch?v=o8Nu1PMSEiA]Legacy GT SPT V2 Catback - YouTube[/ame]
  14. i got the avo panel filter and u can hear the bov a little better. Cheap enough? u dont have to buy another filter. I also have a 50/50 bpv tho
  15. Just heads up Menards has rotella T6 at $21.xx for the gallon. Didnt know this!
  16. rallitek, stock struts http://sphotos-b.xx.fbcdn.net/hphotos-frc1/906446_10200858409243928_548989738_o.jpg
  17. that wagon looks great. I just bought the rallitek springs, should i go with a little spacer in the rear?? its a sedan
  18. do you you guys think i would be ok with H&r drop with 18x8 +48 235/40 tire?? or milder drop like ralitek?
  19. are these supposed to be like grids? which one is better http://www.aspecwheels.net/index.php?route=product/product&path=20_1352_1441_1519_1526&product_id=3719
