bmx045 Posted June 21, 2012 Share Posted June 21, 2012 Who cares. Fix yer moter. Link to comment Share on other sites More sharing options...
amp0412 Posted June 22, 2012 Share Posted June 22, 2012 you are very knowledgeable bmx, a great asset to this forum. +1 well currently at 349whp and i keep hearing 28% drivetrain loss that puts me right around 450 crank horse. I really don't see myself going much bigger with this car as before i chunked that piston I was really happy with it as a moderately fast and reliable DD. I want to be able to take long trips and sit in traffic without breaking my leg with some huge choppy clutch. Say I just went with pistons... is there anything else I should take into consideration of replacement while inside the engine? valve springs? valves? pulleys (do they even really do much?)? would be nice to make it another 60-100 thousand miles without having to tear back into the engine again. I'm trying to price out an estimated repair/modification bill and look into getting a personal loan (what am i getting myself into oh boy haha) I'd obviously need a new clutch with a 6mt, would I have to replace my comp clutch flywheel as well? And its only logical to replace the timing belt and water pump on top of all that. I was in a somewhat similar position to you last winter. I got a new sb put in from the dealer under warranty 2 yrs ago and about 1000 miles after it popped and ringland on a accessport stg2 tune. Only reason we (tuner and I) knew it was broken was because of false knock randomly. Sometimes we would get completely clean logs and others the car would try to pull 12 degrees from the entire map. I ended up turn knock control off and driving it with the broken ringland for 15k miles. During this time I knew the motor was on its way out. Being in college I ended up doing everything to a very strict budget. I ended up with a motor with stock rods, wiescos, bearings, 12mm oil pump killerb oil pickup, all new gaskets and everything that was used had 15k on it because it was from the warrantied sb. I ended up keeping my stock 100k mile heads they were cleaned and the lash checked before reassembly. Make sure that you replace the stock oil pickup with an aftermarket one like the killerb pickup. Currently that motor has about 20k on it with an hta green and pump gas. Put down 400whp on a dyno dynamics and 370 on the airboy. I have the stock rods in there an I'm not particularly worried about them at this power level because I don't make a ton of torque. Only around 330 wtq on the airboy. If I were you and wanted to keep the car I would get a built short block that fits your budget. I would personally stay away from h-beam rods and would buy I-beams if the budget allowed if not I would stay stock again. The best course of action would be to figure out your budget then contact a reputable subaru engine builder to discuss your options(dom @mps, Micah @ 3MI, crystal imprezza) to name a few that I would pick from nasioc. The most important thing that you can do once you have decided on a motor is to get the best tune you can. Good luck let me know if you have and specific questions. -Aaron Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted June 22, 2012 Mega Users Share Posted June 22, 2012 So you lost a chunk of piston and it took out the spark plug tip. Where did it go? Have you inspected your turbo for damage? I'd be worried about the turbo hot side if I had chunks of metal coming out of my engine. Link to comment Share on other sites More sharing options...
SubieChik Posted June 23, 2012 Share Posted June 23, 2012 Damn I thought I had a pic but I deleted it from my photobucket...... Anyways, mine looked like that but covered in oil when I blew my motor. But I couldn't drive on it after like someone else earlier said they could. My engine started violently shaking from a rough idle, oil pressure light came on and that was all she wrote Link to comment Share on other sites More sharing options...
specialB Posted June 24, 2012 Author Share Posted June 24, 2012 So you lost a chunk of piston and it took out the spark plug tip. Where did it go? Have you inspected your turbo for damage? I'd be worried about the turbo hot side if I had chunks of metal coming out of my engine. The piece that had come off was very small. I still haven't looked st the hot side if the turbo but she seems to be in good working order she still makes full boost and holds. I'm rather passive the piece had passed through because after it had happened I heard a little peeve of metal rattling around in the exhaust for a few days and then it blew out. So what's so bad about saving close to two grand and just building the stick block as opposed to buying a new short block? Are their concerns about cracking the block or is it just nice to know everything is fresh. Link to comment Share on other sites More sharing options...
SubieChik Posted June 24, 2012 Share Posted June 24, 2012 I just got an '08 WRX engine with 20k on it that was wrecked from the rear for $2k. If you have the money build it.....why not. I didn't, so I just got what I could afford. Still running strong with 60k on it now. *knock on wood* Link to comment Share on other sites More sharing options...
specialB Posted June 27, 2012 Author Share Posted June 27, 2012 in the works of attaining a new short block with nitrated crank, and forged rods/pistons. probably go TGV delete too and take care of the oil system while im at it Link to comment Share on other sites More sharing options...
specialB Posted August 14, 2012 Author Share Posted August 14, 2012 http://sphotos-b.xx.fbcdn.net/hphotos-prn1/557330_10151182458174789_700991349_n.jpg damn surprised my turbo is 100% unharmed. Link to comment Share on other sites More sharing options...
specialB Posted August 17, 2012 Author Share Posted August 17, 2012 new short block arrives tomorrow Link to comment Share on other sites More sharing options...
specialB Posted August 17, 2012 Author Share Posted August 17, 2012 but da da da! but just my f**king luck, one of the tranny studs is bent and one of the head cooling port dealys is mangled. how the hell do I remove that without it shearing off leaving the rest inside that cooling port? http://i3.photobucket.com/albums/y89/Max00racer/2012-08-17_15-42-52_973.jpg http://i3.photobucket.com/albums/y89/Max00racer/2012-08-17_15-42-21_93.jpg http://i3.photobucket.com/albums/y89/Max00racer/2012-08-17_16-21-30_874.jpg Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted August 18, 2012 I Donated Share Posted August 18, 2012 Might want to initiate a shipping claim... Link to comment Share on other sites More sharing options...
specialB Posted August 18, 2012 Author Share Posted August 18, 2012 just did Link to comment Share on other sites More sharing options...
specialB Posted August 31, 2012 Author Share Posted August 31, 2012 New motor build should be wrapping up today! Hopefully drop in and start by Monday!!! Link to comment Share on other sites More sharing options...
InnocentGuns Posted September 1, 2012 Share Posted September 1, 2012 Very nice. I also should have my motor back in and running this weekend if all goes well. and my radiator actually comes in. I read the whole thread and if you want a 60-100k reliable engine i would go with a moderate tune staying on the rich end not lean so you dont detonate and possibly blow your pistons apart. the main reason from failure almost always stems from the tune being ever so slightly lean, over heating internals and causing failure. just my two cents. good luck and hope your back running this weekend. Link to comment Share on other sites More sharing options...
PaSprinter24 Posted September 3, 2012 Share Posted September 3, 2012 damn man im suprised you put the plug bac in let alone drive it. my lgt wouldve been parked Link to comment Share on other sites More sharing options...
specialB Posted September 4, 2012 Author Share Posted September 4, 2012 Motor is in, just got to work on some vacuum lines and finish bolting everything up under the hood. Hopping to turn the key by Thursday night. Turns out though that sti and GT TGV deletes have Slightly different bolt pattern and the two centermost intake manifold bolts don't line up by like a quarter of an inch. I got some Grimmspeed deletes off a nasioc member. Might just round out the holes on the intake manifold and make some kind of sandwich plate. Link to comment Share on other sites More sharing options...
kaz98gt Posted September 4, 2012 Share Posted September 4, 2012 subscribed, looks like this will be one of those feel-good-in-the-end stories Link to comment Share on other sites More sharing options...
specialB Posted September 6, 2012 Author Share Posted September 6, 2012 Picking up some fresh gaskets tonight after work and hopefully wrapping up this project!! Well at least the physical labor end then its off to get some tuning work Sent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
ControlFreak Posted September 6, 2012 Share Posted September 6, 2012 subscribed, looks like this will be one of those feel-good-in-the-end stories Here's to hoping! Link to comment Share on other sites More sharing options...
specialB Posted September 7, 2012 Author Share Posted September 7, 2012 Soo close i can taste it, didn't have it in me to stay up all night so just a few more hours tonight. Check out how i fixed my iwg closed Sent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
specialB Posted September 10, 2012 Author Share Posted September 10, 2012 Update: Car sounded like it was only making compression on one or two cylinders trying to turn it over. Took off the timing covers and somehow nothing is aligned now? The crank and both intakes and one exhaust gear is off by one tooth (crank is off one in the opposite direction of the other two) and the other exhaust is off by like 90 degrees! I don't know how the hell it jumped so bad, everything lined up perfectly the first time i installed it Sent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
specialB Posted September 10, 2012 Author Share Posted September 10, 2012 AND, the motor holds oil fine but after cranking it several times i found a small puddle of oil under the car... Do oil seals need to heat up once our something before they make a good seal?? Can't tell for sure just yet but it seems like its coming from the back of the block... Rear main seal??? Sent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted September 10, 2012 I Donated Share Posted September 10, 2012 Do oil seals need to heat up once our something before they make a good seal?? Nope, you did something wrong. Can't tell for sure just yet but it seems like its coming from the back of the block... Rear main seal??? Have you checked your banjo bolts? That was my problem. Car sounded like it was only making compression on one or two cylinders trying to turn it over. Took off the timing covers and somehow nothing is aligned now? The crank and both intakes and one exhaust gear is off by one tooth (crank is off one in the opposite direction of the other two) and the other exhaust is off by like 90 degrees! I don't know how the hell it jumped so bad, everything lined up perfectly the first time i installed it Hopefully you didn't bend any valves. Link to comment Share on other sites More sharing options...
specialB Posted September 10, 2012 Author Share Posted September 10, 2012 With the intake cams only being off one tooth i don't see it hitting the pistons...and the exhaust side can't hit in any position so I'm safe there. Once i get the timing together again I'll have someone crank the motor while i look underneath on the lift to see where oil is coming from. Sent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
meier motor sports Posted September 10, 2012 Share Posted September 10, 2012 not a cool fealing when it does not fire up first time round and a few problems. been there done that. drink a cold one, chill out and start over. Link to comment Share on other sites More sharing options...
