specialB Posted June 15, 2012 Author Share Posted June 15, 2012 Car ran awesome all day not one issue. I tried putting straight Bacardi 151 in it and pulled on an Enzo ha. I didn't get around to scoping it today hopefully tomorrow I'll get aroundt to it. How long did it take for you to notice the symptoms of the bust piston bmx? Link to comment Share on other sites More sharing options...
bmx045 Posted June 15, 2012 Share Posted June 15, 2012 about 4-5 days. 1 good WOT pull did it in after the mangled plug incident Link to comment Share on other sites More sharing options...
specialB Posted June 15, 2012 Author Share Posted June 15, 2012 I gave it a couple good WOT pulls but didnt take it past 6k Link to comment Share on other sites More sharing options...
bmx045 Posted June 15, 2012 Share Posted June 15, 2012 Need a clearer look at that piston Link to comment Share on other sites More sharing options...
ericem Posted June 15, 2012 Share Posted June 15, 2012 didn't spec b's have better pistons? Link to comment Share on other sites More sharing options...
bmx045 Posted June 15, 2012 Share Posted June 15, 2012 Funny Link to comment Share on other sites More sharing options...
Spec B Posted June 15, 2012 Share Posted June 15, 2012 didn't spec b's have better pistons? Yes. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 15, 2012 I Donated Share Posted June 15, 2012 didn't spec b's have better pistons? Can't tell if serious or joking. Link to comment Share on other sites More sharing options...
Nrw Posted June 15, 2012 Share Posted June 15, 2012 Titanium Pistons Link to comment Share on other sites More sharing options...
robinlsb Posted June 15, 2012 Share Posted June 15, 2012 Titanium Pistons Provides an additional 55 HP and 3000lbs TQ. The 06 had unobtanium pistons;) "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
specialB Posted June 16, 2012 Author Share Posted June 16, 2012 Well there you have it, cracked a little piece of piston off I can see ring http://i3.photobucket.com/albums/y89/Max00racer/2012-06-16_17-24-53_414.jpg Link to comment Share on other sites More sharing options...
specialB Posted June 16, 2012 Author Share Posted June 16, 2012 http://www.briancrower.com/view.php?pn=BC0629Â I guess a Stroker kit is the only logical solution Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 16, 2012 Share Posted June 16, 2012 Link to comment Share on other sites More sharing options...
bmx045 Posted June 16, 2012 Share Posted June 16, 2012 lol   CALLED IT!  welcome to the club buddy.  http://i1240.photobucket.com/albums/gg489/bmx045/2f948c19.jpg  take a good hard look. if you still have compression right now, the ringlands below the top ring are probably still in tact. but wont be for long. one good WOT and the force will push the top ring down and crack the lower lands Link to comment Share on other sites More sharing options...
specialB Posted June 16, 2012 Author Share Posted June 16, 2012 Yea you broke a lot more off but I dont doubt that it will make the rings die sooner or later. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 16, 2012 I Donated Share Posted June 16, 2012 Why a stroker kit and not just forged pistons? Link to comment Share on other sites More sharing options...
specialB Posted June 16, 2012 Author Share Posted June 16, 2012 Stroker kit and cams just sounds like so much more fun Link to comment Share on other sites More sharing options...
bmx045 Posted June 16, 2012 Share Posted June 16, 2012 not with a vf52 Link to comment Share on other sites More sharing options...
specialB Posted June 17, 2012 Author Share Posted June 17, 2012 Why not? Link to comment Share on other sites More sharing options...
ericem Posted June 17, 2012 Share Posted June 17, 2012 need much bigger of course??!! Your car will probably last much longer than bmx especially considering your not running a 20g....... going to drive it till it gets noticeably worse i presume? Link to comment Share on other sites More sharing options...
bmx045 Posted June 17, 2012 Share Posted June 17, 2012 I understand the need for the new parts, but the stroker kit and cams may be a bit overkill for the size of a 52. If i were you right now I'd buy a new ej257 and put forged pistons in and call it a day. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted June 17, 2012 I Donated Share Posted June 17, 2012 I personally just did the pistons (and timing belt, and gasket kit, etc.). Link to comment Share on other sites More sharing options...
bmx045 Posted June 17, 2012 Share Posted June 17, 2012 I said new block with better pistons based on his presumed budget of a stroker kit and cams. Link to comment Share on other sites More sharing options...
specialB Posted June 17, 2012 Author Share Posted June 17, 2012 I'm taking the car off the road asap, last thing I need is more piston breaking loose and floating through my new turbo. Time to get a beater and pull the legacy into the garage for mass open heart surgery Link to comment Share on other sites More sharing options...
WhiskeyTango Posted June 17, 2012 Share Posted June 17, 2012 the engine is fucked plain and simple. Link to comment Share on other sites More sharing options...
