JB's Teardown and Rebuild
  • Replies 302
  • Created
  • Last Reply
You'll get lots of opinions on that question. Did you say someone is building the engine ?
Ask them.
I would just use a name brand 5-30 for the first 20 minutes. Then change the oil and filter.
Then take the car off jacks and drive it. Make sure you have a good tune for a base map. That's the most important thing, after making sure the fuel pump is working correctly.
We lost a race engine once in the first 20 minutes of run time because the fuel pump was working intermittently. We have the 4 CP pistons to show for it.
Engine Build - Click Here
Met up with a local guy today and ended up getting a Blouch 2.5xtr, 3 inch Perrin inlet, and a Perrin intake. Im not sure the Perrin intake will work on my car (from an STi iirc) but for the price i thought id take a chance and see. This completes my buying of parts minus fluids or gaskets and small stuff like that.
Final Mod List to Date:
ENGINE:
2011 sti short block -forged internals w CP pistons
Fast Motorsports FMIC
South Bend stage 2 HD Daily clutch
Deatschwerks Side Feed 1100cc injectors
Walbro 255lph fuel pump
CNT catless Down Pipe
GT Spec UEL Headers and Uppipe, wrapped
killerb oil pick up
Sti oil pump
Gates racing timing Belt
1 step colder plugs
AEM wide band
tgv deletes
SS oil lines
perrin 22mm rsb
ARP Head studs
Perrin 3 inch inlet
Perrin intake
Grimmspeed BCS
Manley SS Valves
AutoSpeed Catback
Blouch 2.5xtr
Other:
Whiteline RSB
Avo RSB mounts
Kart Boy endlinks
Kartboy Short Shifter
Yellow Fogs
Soon to come Grill Mesh Mod
http://i36.photobucket.com/albums/e2/jeeped07/Legacy%20GT%20Build/IMAG0196.jpg
Mating the engine to the tranny is easier than mating the tranny to the engine.. It helps to have an extra person there to raise and lower the engine hoist and tranny jack so they can fit together easier... the tranny will start slightly tilted up, but you'll need to lower it as they come together if I remember right...
To prime it I used a breaker bar on the crankshaft sprocket for a few full revolutions. After that I pulled the wire on the fuel pump and turned it over by starter for awhile. I'm sure you'd be fine with an impact wrench, but I've "heard" the hammering of an impact whrench can actually twist the crankshaft enough to break it, albeit probably on smaller motors...
I made it to the machine shop today as i got in my new manley valves and crank pulley so i had to drop them off. Walked in just as they had finished glass blasting the heads, had 6 bent valves in them btw. I also got my FMIC piping back in which Josh and Import Image got done in wrinkle black for me, ive only taken one out so far but it looks awesome compared to the original chrome/polished finish. Enough blabbering
http://i36.photobucket.com/albums/e2/jeeped07/Legacy%20GT%20Build/IMAG0198.jpg
http://i36.photobucket.com/albums/e2/jeeped07/Legacy%20GT%20Build/IMAG0199.jpg
http://i36.photobucket.com/albums/e2/jeeped07/Legacy%20GT%20Build/IMAG0200.jpg
http://i36.photobucket.com/albums/e2/jeeped07/Legacy%20GT%20Build/IMAG0201.jpg
Wow! I'm jealous of your mechanical aptitude. I have the same car and just went through the same (similar) build. New Subie block, cams, valvesprings & retainers, pistons, rods, shims etc etc. Cost me $8700 for everything. Sucks having to pay someone to do the wrenching. I'm glad your ordeal is almost over. Can't wait till you have it tuned and running.
____Spending funds in mass quantities! I keep telling myself it's just a hobby?
holy hell i love the car in your avi... searching for more pics now.
Thank you. We're like long lost siblings. You're gonna love your car. Especially after all the blood, sweat and tears you put into it in the last month. I'm waiting for Shamar to get back to me for a tune. The place that did my motor build and install blocked all my old maps. Freakin' A__holes! I'm not bringing it back to them, so I figured I'd give Shamar at Infamous a try. Right now still breaking in the new motor. Only have 800 miles on it. Keep us posted.
Yea i cant seem to get ahold of shamar right now. Kinda on a time frame so might look else where if i dont hear from him soon.
In other news i got a couple things done today, figured out the routing and placement for the FMIC piping and started putting some of it in, also put the fuel pump all back together with the new walbro unit in. im running out of things to do while waiting for the motor....
Shamar is always busy. He would be well worth waiting for. It is not a fast process once you start, but so worth it. I have said it before, my Shamar e-tune is way better than my old protune. I spool faster on my fmic than I did on my tmic. You will not be disappointed.
he's short on time and has a limited timeline. You could however just try to get a base tune through Shamar and continue with the e-tuning process while at school. Since all you have to do is log a little and upload revisions to your ecu, very doable while away from home. Just make sure you bring your laptop and cable.
To prime the fuel system. Just power up the fuel pump. It will fill the system in a matter of seconds.
If you can make sure the spark plugs are out of the heads when you turn the engine over to prime the oil system. You don't need the compression pushing the pistons and rods into the bearings on a slightly lubed crank. Granted ,most people just start the engine and go from there, but if you have the time and can, pull the plugs.
Ran the piping from the front mount into the engine bay and got the bumper trimmed to fit around the FMIC. Took about 10 tries of cut, fit, cut, fit, but it finally went on. I eventually plan on cutting out the lower center support of the bumper and glassing it so that its a nice big opening for the intercooler.
http://i36.photobucket.com/albums/e2/jeeped07/Legacy%20GT%20Build/020-3.jpg
http://i36.photobucket.com/albums/e2/jeeped07/Legacy%20GT%20Build/025-3.jpg
Nice job, think hard about cutting out the center support, I don't think fiberglass will work there with the flexible plastic.
