Max Capacity Posted January 13, 2012 Share Posted January 13, 2012 Wellllll ? whats the verdict ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
nessbran Posted January 13, 2012 Share Posted January 13, 2012 he said it should fire around 11 parts come in at 10 Link to comment Share on other sites More sharing options...
nessbran Posted January 13, 2012 Share Posted January 13, 2012 LOL, lurk much? Nice first post and welcome to the forum! And I wanna hear it runnin too hahaha ya im a friend of joe's been watching the build from the start. thanks for the warm welcome Link to comment Share on other sites More sharing options...
jblackwell1 Posted January 13, 2012 Author Share Posted January 13, 2012 Not sure what the issues is but it will start and putter out after a couple seconds. Gonna talk to the tuner and do some research, might end up having to take it to a professional because everything seems to be correct, but im going to look at the ignition system in the manual and see if anythings incorrect. Sad day for this guy. Ive got good oil pressure and def getting gas. Will update when i have more news. Link to comment Share on other sites More sharing options...
nessbran Posted January 13, 2012 Share Posted January 13, 2012 good luck, hope its something small and you can get it sorted out Link to comment Share on other sites More sharing options...
Max Capacity Posted January 13, 2012 Share Posted January 13, 2012 Can you load a basic base map for like stage 1 or some map you have used in the past that runs well. As long as you don't hit boost the engine should be fine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jblackwell1 Posted January 13, 2012 Author Share Posted January 13, 2012 Im running 0 psi boost on my tune. Im working with the tuner right now, after unplugging the maf and letting it idle it ran much better, tuner wanted the wideband reading and im hoping its an injector issue where im pumping too much gas but we will see. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 13, 2012 Share Posted January 13, 2012 Glad to hear your making progress. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jblackwell1 Posted January 13, 2012 Author Share Posted January 13, 2012 yea should be a long day of test and retest trying to track down any and all gremlins. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 13, 2012 Share Posted January 13, 2012 Been there, we flew a Tuner in from CO to start are race car, he finally got it going but a wiring issue kept it from reving over 4800rpm. That was at the Dyno we rented for the day... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Turkeylord Posted January 13, 2012 Share Posted January 13, 2012 Good Luck! Link to comment Share on other sites More sharing options...
jblackwell1 Posted January 13, 2012 Author Share Posted January 13, 2012 yea, this is my first motor swap, much less a fully built motor so i was half way expecting some problems but praying for the best. Gonna see if a new tune does anything, tuner thinks maf or injector scaling needs some adjusting, all hoses, plugs, and wiring LOOKS right, but ive been looking at this thing about 6-12 hours a day for the past 2 weeks so maybe a fresh set of eyes will see something. Link to comment Share on other sites More sharing options...
jblackwell1 Posted January 13, 2012 Author Share Posted January 13, 2012 Just got my first 20 min idle in. Took a video gonna have to figure out if i can edit it to shorten it cause its about 30 mins long. She sounds like heaven tho! Videos will be up at some point. Link to comment Share on other sites More sharing options...
planelazy Posted January 14, 2012 Share Posted January 14, 2012 Awesome! Can't wait! Link to comment Share on other sites More sharing options...
jblackwell1 Posted January 14, 2012 Author Share Posted January 14, 2012 Can anyone on here edit videos? No one wants to see 30 mins of the car idling, but i do have 3 dif views that a min or two of each in one vid would be nice. Link to comment Share on other sites More sharing options...
wpgspecb Posted January 14, 2012 Share Posted January 14, 2012 Yah its pretty easy, you can use windows movie maker to trim and cut... if not... put them on youtube under private and send me the link, ill edit it up for you, heck even youtube can do editing right on the site i think Link to comment Share on other sites More sharing options...
jblackwell1 Posted January 14, 2012 Author Share Posted January 14, 2012 i took a short video while logging tonite. I need a better camera i know but its the best i have right now. Link to comment Share on other sites More sharing options...
jblackwell1 Posted January 14, 2012 Author Share Posted January 14, 2012 Does it sound that bad? Ill keep trying w different recording devices. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 14, 2012 Share Posted January 14, 2012 Unless I'm missing something, it sounds pretty good to me. How does it drive ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Imprezsing04 Posted August 7, 2012 Share Posted August 7, 2012 Half year ago bump! Updates? Link to comment Share on other sites More sharing options...
brum Posted August 7, 2012 Share Posted August 7, 2012 It blew up again. Link to comment Share on other sites More sharing options...
Balrock Posted August 7, 2012 Share Posted August 7, 2012 It blew up again. Noooooooooo! WTF happened? It looked like there was alot of TLC put into this rebuild. It's not my car and this makes me wantto cry! Link to comment Share on other sites More sharing options...
musty_hustla Posted August 8, 2012 Share Posted August 8, 2012 I think and hope brum is joking. Link to comment Share on other sites More sharing options...
frank_ster Posted August 8, 2012 Share Posted August 8, 2012 no he broke it for real he has another thread. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
700watts Posted August 8, 2012 Share Posted August 8, 2012 link? Link to comment Share on other sites More sharing options...
