hadvw Posted August 20, 2016 Share Posted August 20, 2016 PMed.. Link to comment Share on other sites More sharing options...
snow05gtRI Posted August 23, 2016 Share Posted August 23, 2016 keep trying him. he disappears for a little bit at a time, probably busy modding VBs and also doing his real life job. Link to comment Share on other sites More sharing options...
robburns201 Posted August 10, 2017 Share Posted August 10, 2017 Bump this old thread up....I need this F1 bad...I want to keep my 5Eat but won't be able to put much power in it....climberD please Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
thorton0 Posted August 10, 2017 Share Posted August 10, 2017 He told me that he doesn't do it anymore. I installed a transgo kit last week. It's not to bad with climberd's walk through. Link to comment Share on other sites More sharing options...
robburns201 Posted August 11, 2017 Share Posted August 11, 2017 (edited) He told me that he doesn't do it anymore. I installed a transgo kit last week. It's not to bad with climberd's walk through.Did you have to drop the whole trans? Or just drop out valvebody from under car[emoji16] Sent from my 0PJA2 using Tapatalk Edited August 11, 2017 by robburns201 Link to comment Share on other sites More sharing options...
m sprank Posted August 11, 2017 Share Posted August 11, 2017 Just the VB, not the entire trans. Link to comment Share on other sites More sharing options...
Bigwillystyle Posted August 11, 2017 Share Posted August 11, 2017 Is there anyway to talk to climberd? I'd like to chat with him? Link to comment Share on other sites More sharing options...
Carlz0r Posted August 11, 2017 Share Posted August 11, 2017 Is there anyway to talk to climberd? I'd like to chat with him? He's got a phone number listed on the hex mods facebook page, not sure if it's current or not though. Link to comment Share on other sites More sharing options...
amp583 Posted September 16, 2017 Share Posted September 16, 2017 Mine stock 08 5EAT is intermittently throwing P1710 TORQUE CONVERTER TURBINE SPEED 2 SIGNAL. From what I've read, It could be "a dent in the trans pan" to "a failing valve body". Although this post isn't about diagnosing 1710, I'm searching for options to cure the problem. Any word if TransGo will work on 08? Before I go find a spare valve body, want to make sure I get the best bang for the buck thanks! Link to comment Share on other sites More sharing options...
whitrzac Posted September 17, 2017 Share Posted September 17, 2017 Short answer, no. Link to comment Share on other sites More sharing options...
m sprank Posted September 19, 2017 Share Posted September 19, 2017 Mine stock 08 5EAT is intermittently throwing P1710 TORQUE CONVERTER TURBINE SPEED 2 SIGNAL. From what I've read, It could be "a dent in the trans pan" to "a failing valve body". Although this post isn't about diagnosing 1710, I'm searching for options to cure the problem. Any word if TransGo will work on 08? Before I go find a spare valve body, want to make sure I get the best bang for the buck thanks! In my experience the issue is the valve body. Once, and only once have I found a loose connection causing the issue. Of course to find it, I had to go through the entire troubleshooting flow chart and find the issue just before the "replace valve body" step. This is once in 15+ years of working on Subarus. Link to comment Share on other sites More sharing options...
amp583 Posted September 20, 2017 Share Posted September 20, 2017 Thanks mSprank. What advice can you give me on replacing/fixing the valve body? I'm guessing my options are: - Dealer - Mechanic, of which, I have no connection or dedicated dude - Self-repair I'm up for the challenge but I have no trans experience and am purely a hobbyist guy. DP, suspension, brakes... In my experience the issue is the valve body. Once, and only once have I found a loose connection causing the issue. Of course to find it, I had to go through the entire troubleshooting flow chart and find the issue just before the "replace valve body" step. This is once in 15+ years of working on Subarus. Link to comment Share on other sites More sharing options...
m sprank Posted September 21, 2017 Share Posted September 21, 2017 Honestly it is not that hard. I can swap out a 4th gen LGT in 2-3 hours with clean up. I believe Dave has a install write up buried on this forum somewhere. His instructions are probably very thorough. Link to comment Share on other sites More sharing options...
amp583 Posted September 23, 2017 Share Posted September 23, 2017 Thanks for the boost of confidence. I'll search around for the writeup. Can you give insight on where to find a reputable valve body? I'm guessing my options are from a junker or rebuilt... I'm looking at this Sonnax: http://www.ebay.com/itm/Sonnax-VBX-SUB131-Transmission-Valve-Body-7-Solenoids-Wire-Style-/112330685605?fits=Make%3ASubaru%7CModel%3ALegacy&hash=item1a276e3ca5:g:gFoAAOSw4A5YwuFj&vxp=mtr thanks for the help! Honestly it is not that hard. I can swap out a 4th gen LGT in 2-3 hours with clean up. I believe Dave has a install write up buried on this forum somewhere. His instructions are probably very thorough. Link to comment Share on other sites More sharing options...
m sprank Posted September 25, 2017 Share Posted September 25, 2017 I have only purchased new from Subaru. I have worked with IPT and Hexmods modified valve bodies. Link to comment Share on other sites More sharing options...
fmowry Posted September 26, 2017 Share Posted September 26, 2017 I have a Hexmod/ClimberD valve body that I just pulled from my 05 LegGt. PM me if interested. I'll put it up in the classifieds this weekend (or maybe earlier) when I get time to get a pic. Link to comment Share on other sites More sharing options...
RooTBeeR Posted March 3, 2018 Share Posted March 3, 2018 Im still hoping that i can get an f1 valvebody for my lgt soon, somehow "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
utc_pyro Posted March 3, 2018 Share Posted March 3, 2018 (edited) Transgo shift kit. Also adjusting the calculated torque tables will get you 90% there unless you’re running a crazy high power setup. Edited March 3, 2018 by utc_pyro Link to comment Share on other sites More sharing options...
thorton0 Posted March 4, 2018 Share Posted March 4, 2018 Transgo shift kit. Also adjusting the calculated torque tables will get you 90% there unless you’re running a crazy high power setup. I have the trans go kit. and its great. but what about torque tables? I don't understand. Link to comment Share on other sites More sharing options...
robburns201 Posted March 5, 2018 Share Posted March 5, 2018 Transgo shift kit. Also adjusting the calculated torque tables will get you 90% there unless you’re running a crazy high power setup.Can your tuner adjust this? Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
Btman Posted November 10, 2018 Share Posted November 10, 2018 Hi, from sibiria!) My practics with modification hydraulic schem for fast shift VB 5EAT 08+: stage 1: stage 2: And ver "nigtmare") for 5EAT 04+: Link to comment Share on other sites More sharing options...
Outback2.5XT-05 Posted November 12, 2018 Share Posted November 12, 2018 Hi, from sibiria!) My practics with modification hydraulic schem for fast shift VB 5EAT 08+: stage 1: stage 2: And ver "nigtmare") for 5EAT 04+: This is a physical modification or software tuning? Link to comment Share on other sites More sharing options...
Btman Posted November 12, 2018 Share Posted November 12, 2018 This is physical modification of hydraulics processes in VB, but line pressure is raised only in the “nightmare” version 5EAT 04+. With ST2 shifts more than 2x faster. In addition, accelerated circulation ATF in lube line & heat exchanger is and cut time lag for PRND. Link to comment Share on other sites More sharing options...
nevets27 Posted November 12, 2018 Share Posted November 12, 2018 (edited) Can I assume b@tman, that this is the best place to follow the progress of the 08+ vb mod? https://forums.drom.ru/subaru/t1151851873-p52.html So this mod increases the fluid flow and therefore makes the shifts quicker but doesn't change line pressure or make the shifts more firm, correct? Edited November 12, 2018 by nevets27 Link to comment Share on other sites More sharing options...
