Posts
218 -
Joined
Content Type
Profiles
Forums
Gallery
Everything posted by amp583
I'm still having some issues with my 5EAT after replacing a bad VB and resetting the TCU, correctly. If I go medium hard on the throttle, I get a kick when gears change from 2nd to 3rd. I also will get a kick on downshifts periodically. I can drive it around and avoid the kick by driving slower and less punchy on the peda. But if i push on it a little bit, it will kick from gear 2 to 3. Same happens on the downshift. I replaced the VB in October 2017. Reset my TCU with the above mentioned method... Any advice is welcomed. thanks and happy 4th!
KILLER deal on Lower control arms
amp583 replied to Harsho1's topic in Fourth Generation Legacy (2005 - 2009)
GOOD POINT. Anyone buy the mevos or others listed here and swap out for Whiteline bushings? On the fence if I should just swap bushings while my MAS arms are not installed. -
Mevotechs are still sold out. Another member posted MAS - https://www.rockauto.com/en/parts/mas,CB72083,control+arm,10401 They look very similar to Mevotechs and UltraPowers. Do you think these are also the same part with a different p/n? -
Are Mevotechs better than Spec B's? Have a good deal right now on a set. -
2008 LGT 5EAT throwing a P0700 Turbine Speed Sensor 2 error. Is the sensor itself a replaceable item by re-soldering or do I replace the entire valve body? If the latter, where is the best place to aquire one? I'm guessing the dealer will ream me with an OEM.
Thanks for the boost of confidence. I'll search around for the writeup. Can you give insight on where to find a reputable valve body? I'm guessing my options are from a junker or rebuilt... I'm looking at this Sonnax: http://www.ebay.com/itm/Sonnax-VBX-SUB131-Transmission-Valve-Body-7-Solenoids-Wire-Style-/112330685605?fits=Make%3ASubaru%7CModel%3ALegacy&hash=item1a276e3ca5:g:gFoAAOSw4A5YwuFj&vxp=mtr thanks for the help!
Thanks mSprank. What advice can you give me on replacing/fixing the valve body? I'm guessing my options are: - Dealer - Mechanic, of which, I have no connection or dedicated dude - Self-repair I'm up for the challenge but I have no trans experience and am purely a hobbyist guy. DP, suspension, brakes...
P1710 Torque Converter Turbine 2 Speed Signal Circuit 2 Malfunction
amp583 replied to aktorides's topic in Transmissions
Bumping the past - sorry. Aktorides, did you get this work done at the dealer or mechanic? Also, was the valve body modified? I see the 5EAT-S in your details... thanks! -
Mine stock 08 5EAT is intermittently throwing P1710 TORQUE CONVERTER TURBINE SPEED 2 SIGNAL. From what I've read, It could be "a dent in the trans pan" to "a failing valve body". Although this post isn't about diagnosing 1710, I'm searching for options to cure the problem. Any word if TransGo will work on 08? Before I go find a spare valve body, want to make sure I get the best bang for the buck thanks!
Did it work out? -
I really like my setup - Invidia Q300 quad-pipe, though you'd get the same sound with the Q300 dual pipe. It's burly on startup and quiets down when idles at 1500. Upon blipping the pedal and under acceleration, it makes some great sounds, really unlocks the boxer rumble and isn't too loud overall. Stainless steel, great construction also make it a good choice though depending on where you live, you might not need it.
Sighting: White 08 LGT with black sparcos and a poorly fitted quad tip invidia...you here?? Oh wait, that's me and if ya'll see me be sure to honk or throw up your fav Chicago sign.
Can't decide between 06/07 Spec B Rims for my 08 SWP LGT. Photos attached of other cars with the aforementioned RIMs. One thing I run into is terrible winters in Chicago, potholes and potential replacement costs. With Rota Gravels, i'm thinking hyper black or anthracite.
When installing exhaust bits, downpipe, mid, y-pipe, etc is it advisable to replace original bolts with new ones? Most likely new parts ship with bolt kits but in the case of used parts, would you replace them?
How much modification is required? Do you think its worth it after the time and lack of proper fitment? I'm justifying this approach or getting a mesh grill...
How much modification exactly and do you have a thread you followed? Do you think its worth it? im considering the route
What bulb is for Fog lights on the 2008 USDM LGT?
