Valve Body Mods, Giant Leaps Forward!!!
ClimberDHexMods
I am opening up shop!
Hexagram Modifications, aka HexMods, is now taking pre-orders for the HexMods Valve Body Modification line's first release, the F1!
Welcome to the HexMods F1 Package (F1 because your transmission will "finally" shift fast), for the 2005-07 LegacyGT and OutbackXT 5EAT (5-speed Electronic Automatic Transmission), using the TransGo shift kit many people have been talking about. The HexMods F1 produces faster shift times and more shift firmness under acceleration, while preserving reasonable shift comfort during low-throttle shifts. The HexMods F1 is all your healthy transmission needs to handle significantly increased power and torque output. No longer is the $4000+ transmission race build required for most big-power setups!
Hexmods F1 Service:
$500, which includes a $25 return shipping credit via UPS Ground, and Paypal fees. Faster return shipping upgrades such as Overnight or 2-Day are available for an additional charge.
How do I get my Valve Body modified by Hexagram Modifications to become a HexMods F1?
Remove your valve body from your transmission, box it up, and ship it to Hexagram Modifications in Dallas, TX.
Once received, the valve body will be cleaned, disassembled, cleaned again, upgraded with new valve control springs, valves, check balls and larger fluid passageways, reassembled, and packaged back up, all within 24 hours.
Then you re-install the valve body in your car, add back in ATF, and give the TCU (Transmission Computer) 100-400miles to learn the new valve body (it will act very weird at first).
Then you modify your car's power output to your heart's content, and rest assured that your transmission can handle whatever you throw at it!
http://www.harborfreight.com/media/catalog/product/cache/1/small_image/175x/9df78eab33525d08d6e5fb8d27136e95/i/m/image_2511.jpg
How to Remove and Install the Valve Body into the transmission?
To drain and fill ATF properly.
To remove and install the Transmission Pan and Valve Body.
Install Notes to make your life easier:
-8mm hex socket / allen key for ATF drain plug.
-10mm socket and extension for everything else!
-Electric Drill with socket adapter will really speed things up.
-Always have a big drain/drip pan handy to catch all the fluid. When you think it's done, you will loosen another VB bolt and it will start raining again. It will drip forever, don't be in a rush.
-You do not always need to replace the drain plug gasket, but assess on a case-by-case basis. If you are missing a gasket, add one. 18mm copper crush washer or regular copper washer is all you need.
-All bolt torque specs should be respected. Most important is that they are all even. Don't over tighten!
-Whether working on removing the transmission pan or valve body, loosen all bolts but do not at first remove them. This gives the pan or valve body a few millimeters to separate from its respected mating surface. For the pan, this trick will allow you to avoid ATF splash city (the drain plug does not drain all ATF from the pan. For the valve body, this allows the VB to decouple from the transmission, allowing yet more fluid to come out.
-Separating the pan from the transmission after the bolts are loosened/removed is a pain because the silicone/RTV gasket has glued it on. Use a plastic trim tool to wedge the pan off the transmission.
-When the pan is off, you will see leftover gasket on the transmission machined mating surface, and on the pan. Use a drill and wire wheel to knock off the gasket material from the pan. PICTURE Use a razor blade to shave the gasket material from the trans mating surface.
-Use Brake Cleaner to clean up the pan and pan magnet thoroughly.
-The VB is held in by 2 different lengths of bolts. Just be cognizant of this and reference the attached/linked PDFs when reinstalling.
-The VB is heavy. If you can get a jack with pad under it, that may make your life a little easier for uninstalling or re-installing it.
-Remember to line up the shift position rod with the transmission shift position cylinder when you are installing the new VB in the transmission. It will make sense when you see it.
-For pan re-installation, I recommend Permatex Right Stuff Gasket, because it dries in a few minutes, and is easy to apply. Put on a ring around the pan, lining the INSIDE (not outside) of each bolt hole. Less is more, unless you use too little ;)
First and last, use common sense.
Please PM or post any questions.
Valve Body Packaging Instructions:
  1. Put valve body in plastic trash bag to prevent leaking of fluid. Double bag just to be sure.
  2. Wrap VB in A LOT OF soft foam sheets and/or bubble wrap. The most important part to protect is the top of the valve body with all the wires and solenoids. Put extra foam and padding on top of that area, and on the side with the plastic and wires. Pad sufficiently such that the VB is insulated from blunt force impacts and getting dropped on the pavement.
  3. Place in a box that is sufficiently filled with padding such that there is no room for anything to bounce around. More is better.
  4. Mark as Fragile if available.
  5. Private Message me with your PayPal email address, and I will invoice you and send you shipping instructions.
How much power/torque will my 5EAT be able to handle with a HexMods F1?
No absolute number is known, or can be known. There are too many variables to make a reliable power/torque claim. So much depends upon the torque converter's response to your power setup. The torque converter magnifies torque especially at lower RPM. This means an early-spooling Stage 2 Legacy and a late-spooling Stage 4 GT35r Legacy could produce a comparable threat to the longevity of a transmission, even though the GT35r produces monster power when compared to a Stage 2 Legacy. This example takes into consideration that the TCU (Transmission Computer) is programmed to apply a certain amount of clamping power per variables such as RPM and MPH. The GT35r may make a ton more power, but the TCU is conveniently programmed to apply more line pressure through the big turbo's high RPM area of operation.
I estimate the HexMods F1 able to handle any Stage 2 setup, as well as any Stage 3 / Stage 4 setup up to 350wtq (all wheel torque), as referenced by what a comparably-setup 5MT Legacy would produce. It can probably handle a lot more, but there is simply not enough hard information to know how 5eats behave at that power level.
Will a valve body modification help or improve a partially worn out or slipping transmission?
NO! If you have a transmission with some clutch pack wear due to abuse, improper care and maintenance, high mileage, or excessive engine torque output (from engine modifications), then at best a modified valve body will marginally extend the life of the transmission. However, it could make a slipping condition worse, and could make problematic shifting worse. If you have a worn transmission, consider a rebuild in addition to a valve body modification. If you are not sure whether your transmission is worn, seek the assessment of a local transmission expert. Note that the TCU is designed to learn around wearing transmission clutches, such that it can hide the feeling of wear that might be more evident without computer learning. With engines as with transmissions, you can only do so much to diagnose an internal wear condition without removing it and opening it up.
How does the HexMods F1 compare to IPT's Valve Body Modification?
To be strictly objective, IPT charges a higher price, and makes a much fewer number of physical modifications to the valve body. In terms of transmission shift behavior, the HexMods F1 changes gear ratios faster and firmer than IPT's modification. Neither modification significantly compromises shift comfort at low loads.
_____________________________________________________________________________________________________________________________
Original Write-up:
Background
A few of you know I have been spending almost all my free time working on my transmission, specifically my valve body collection. I'm the type of person who seeks to dissect a complicated mechanism down to its most basic elements, at least when I have the information available to comprehend what I am looking at.
A couple things had been bugging me about our valve body modification options:
1) IPT valve body service, only shop in town, charges $769 + 2x shipping, and says nothing about what they do. They had been performing their service awfully quick. So either they had nothing else going on in the shop, or it was super easy. So we were all getting taken easy.
2) IPT valve body does not make the shifting as good as it needs to be. Shifts still take a while at high RPM, for instance. Way better than stock, but nothing like what the 350Z clowns describe or show in their videos.
3) The 350Z TransGo shift kit was/is making RE5R05A transmissions shift very very well. But we don't have a TransGo option.
4) One member had his trans shop custom install a 350Z TransGo kit, which he said shifted superior to the IPT valve body mod.
Goals
I seek to solve every transmission "problem" found on my 5eat, and I have been busy.
In doing so, I hope to bring to the 5eat community a set of R&D'd shift kit / valve body modification services that are superior to IPT, and are more on par with the 350Z options. I intend to bring these to market at a lower cost than IPT. A win for all of us.
I am aiming to become more of a business entity in the LGT community. I intend to make some money doing this. If I did not intend to make money with providing a service, I would stop investing most of my evenings working on this, and I would do the minimum to accomplish my own shift performance needs, which are almost met. Instead, I aim to develop a valuable service in order to help any 5eat enthusiast achieve the shift performance they need to hold real power. This would include modifying both stock valve bodies and IPT modified valve bodies to achieve proper shift performance across the board for all.
Thanks
Special thanks to Frank_ster for helping me learn so much about transmissions, and Buick 3.8L motor swaps.
Special thanks to others, you know who you are.
Progress
I have figured out exactly what IPT does in their 05-07 LGT 5eat VB mod. One can intuitively figure a similar type of mod is done to many similar transmission valve bodies. I will not get into how I feel about knowing what they have been charging $769 to do all these years. It makes me feel depressed that at one point I was so beholden to the forum group think that I was actually excited to join the ranks and pay IPT good money for their VB mod service. It breaks my heart, and I'm very confused about the whole situation.
I believe I can successfully implement a superior shift kit modification to 08-09 LGT valve bodies as well as 05-07s, but that will come only after 05-07 model years have a working proof of concept.
I have a tester valve body and a TransGo RE5R05A shift kit, and I am investing a lot of my time and energy in working to fully analyze the 350Z TransGo VB modifications. I am well on my way to having an absolutely superior valve body to the IPT valve body.
Posting
Now, if you have a 05-09 5eat LGT and are interested in having your valve body modified (some of you for a second time), please post the following information and feel free to ask any questions.
LGT 5eat car year? 05 06 07 08 09
IPT VB mod already performed? Yes or No
Are you willing to pay close to but less than IPT prices (perhaps again) for a proper shift kit modification performed by fellow 5eat performance enthusiast ClimberD himself?
2005-2007 5EAT ATF Procedure.pdf
2005-2007 5EAT Valve Body & Pan Procedure.pdf
Edited by ClimberD@HexMods
[CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER]
  • Replies 1.4k
  • Created
  • Last Reply
Top Posters In This Topic
Depends, yes interested. If we shift faster, don't we still have the problem with clutches and slippage with more then stage 2 power?
No. We have a problem if the shifts take too long. We also have a problem if it slams shifts, but that will be avoided since no one really wants that. The ideal situation is to have quick, positive shifts when WOT, which is the whole point to me going to all this trouble. If it shifts quick and positively, then the period during a shift when the clutches are engaging/disengaging is shorter. So there is less heat and less wear, so your trans should hold up to the greater power & be more fun to drive since you won't need to pay as much mind to the shift duration dragging out.
IPT VB does not shift quick enough at higher RPMs for me. Bugs the heck out of me. I know I'm not alone. It is good with IPT vs stock, but it needs to be much better to achieve a proper sporty shift behavior.
IPT VB mod already performed? No
Yes, depending on price and down time of my only vehicle of course.
Subscribing to this thread, awesome work you've done man in dissecting the 5EAT.
Are you willing to pay close to but less than IPT prices (perhaps again) for a proper shift kit modification performed by fellow 5eat performance enthusiast ClimberD himself? Yes
In time.. Maybe by the end of summer, I will have the money and need this kit. Unfortunately it will take that long but i'm still willing.
One simple quick question and sorry for the thread-jack. I'm going stage 2 shortly. I do not drive hard, never even been WOT. What if my tranny were still to go? Would I need a new tranny and then the new shift kit that ClimberD himself may be producing? Or if my tranny went, can I just replace the valve body?
LGT 5eat car year? 09
Are you willing to pay close to but less than IPT prices (perhaps again) for a proper shift kit modification performed by fellow 5eat performance enthusiast ClimberD himself?yes
Question, Need to see working proof of course, no error codes. Also, downtime must be minimal as this is my only vehicle.
I built and raced muscule cars( '69 Mustangs one with a 390 big block and C6 auto/ reverse shift pattern and hi-stall, shift kit, etc the other I put a 351C w/4sp,'56 F-100 w chey 327 built 350 TH, etc...) before I got into Subarus. I built engines and I helped my mentor built Ford and Chevy trannies for drag racing. I remember most of what he taught me on how to keep a tranny together behind a big block. So if there is anything I can help you with let me know. The members here helped me get my FMIC bussiness off the ground and I like to give back. I'm going to send you a PM and good luck. Bryan
Background
Goals
Thanks
Progress
Posting
Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com
if you can build it to the standards you detail, you'll own the segment.
people here tend to get wet for ipt vb, because as you said, they're the basically only game in town.
i wouldn't worry about establishment v. individual; enthusiasts want pudding, period.
if you could offer a radically better performing product, at a competitive cost, with equal user install effort/downtime/reliability, i don't see any reason you couldn't become the go-to for what is already a fairly popular mod for power-hungry 5eat'ers.
I don't think anyone who already has a IPT VB mod, will post here just to say, no they wont do it again. So I have a feeling you'll get mostly and only the ones that are willing.
But I figured you are looking for interest before investing time and money. BTW, if nothing you are doing the whole community a great service simply by enlightening us as to what IPT service is really worth.
I just got my VB done, and its not even installed. However given that it was a 1 day turn around, it seems its a simple modification or they have it down pat after all these years.
One final question with your goals of the quicker shifting, does it in any way increase the power/torque threshold on the 5EAT. For that matter does IPT VB mod. ? I think great many ppl on this boards seem to believe they do, and not sure given the "mystical" nature of the 5EAT if it ever been actually proven.
"MAYBE" in the near future, DEFINITELY if I can sell the brand new never installed IPT VB right now.
  • Mega Users
Are you willing to pay close to but less than IPT prices (perhaps again) for a proper shift kit modification performed by fellow 5eat performance enthusiast ClimberD himself? Yes, Please
This is my subscribe/bump/ILOVEREVERSENGINEERING shout out. Keep up the good work for us slushboxers (get it?)
I've considered the IPT valvebody upgrade, heck I've even told myself I would treat myself to their full race transmission when mine checked out. But the mystery behind it all has always kept me at bay. I feel if it wasn't a scam (not saying that it is), they would love to share at least some general information about the modification. If this all comes to fruition I'll just by up 10 or 15 5eat's (and this mod as well) and have them for parts/replacements to keep it at 100% :lol:
If people knew what their $769 was buying them, it is entirely possible people would call IPT and start screaming for 10 minutes straight. Yes, it's easily that insulting to an adept "enthusiast's" intelligence. I would be pissed as all get out if Frank_ster hadn't been preparing me for months to the possibility that IPT does 10 minutes of work, costing them $2, for which they charge $769. Actually, IPT does even less than he thought, and he thought they just drilled a couple of holes. It's the steep price people pay for jumping before understanding what they're jumping into. That needs to end, at least for those who want to get good value and performance for their money.
Nothing against IPT as a business. I would be so lucky as to own a cash cow like IPT. And they did nothing illegal or misleading. They simply say, send us $769 and your VB and we'll send it back and it will shift better. You don't have to send them your money if you don't want to. But it comes with the territory that people like me will raise the bar of value for money, and now they will have to either subsist on their reputation, or make a better shift kit, or lower their prices. In reality, the Subaru 5eat generates them perhaps 0.5% of their volume, if that. I won't even be a blip on their radar unless they want to belittle me for bursting their bubble. They'll still make their boat payments just fine, and they will still perform their core business of rebuilding transmissions with more frictions/steels stacked on the drums that get the most abuse, in addition to cryo, etc.
I have 3 5eats :lol: The key is to have the shift kit go into a healthy trans. If the trans already has worn clutches anywhere, then the IPT VB or any other VB won't prevent the inevitable. Kind of like if you start consuming oil in your engine because your piston rings are starting to wear, you can try to bandaid it but compression will continue to drop until you're going nowhere.
Can you say $2.00 RadioShaft resistor to increase line pressure. :lol:
Next you're going to tell us there's no Easter Bunny, Tooth Fairy, or Santa. :eek:
Edited by lieutenantcolumbo
LGT 5eat car year? 08
Are you willing to pay close to but less than IPT prices (perhaps again) for a proper shift kit modification performed by fellow 5eat performance enthusiast ClimberD himself? - From the day I heard of IPT and looked at the VB, I told myself that $769 was alot of $ for a modification to my valve body. It shouldn't cost that much is what I thought, but if they are the only ones then so be it. It is strange they do not make claims to a "upgraded this", or "your car should hold XX HP with proper operating 5EAT".
I am disgusted with the slow poor up-shifts, especially in manual moder and not even at WOT. Some down-shifts are sloppy or hard too.
I am interested in what anyone can do with the 5EAT. I want to find a way to make it hold up to a 16G or 18B billet, stage 3 setup down the road. I want to see some claims and testing of what a stock VS. IPT vs. anyone else modfied VB or tranny will hold. At some point I think one would have to upgrade the clutches and plates or even new shafts (billet) and/or converter stall.
Does anyone offer any TCM tuner I am surprised the AP or device, doesn't up the line pressure or someone else has't already figured out the "$2 radio shack resistor" thing. That is not the best way (from what I know and have hard), the only way to make a slushbox better is to upgrade it's parts.
Edited by Tomkat1127
additional comment
Once the high performance 5eat guys see what their $769 bought them, I bet you I will eventually get several IPT VBs to re-modify to a proper performance level. It's literally that minimal and lacking.
So what exactly do they do, IPT to the valve body b/c if It was something cheap, you already got my service to properly do mine.
I was beginning to think no one was going to ask! I will post up a proper picture of what it is, and I will post up the TransGo kit for comparison later. Unfortunately I have a booked up Sunday.
------yes (only after you tell me what IPT did and after i get my 10 min with them on the phone j/k)but ----yea for sure
I'm just curious, does anyone care to guess what changes IPT may have done to your valve body? Come on, take a guess! You don't lose points if you're wrong! My guess was way off. I will post what they did tomorrow. You're going to be like "oh that's what you get for $769?" Edited by ClimberD@HexMods
The changed the resistor on the solenoid to trick it into thinking TCU is calling for more line pressure ?
Also, do these mods in anyway increase the hp or torque holding ability ?
My VB was supposed to be installed 23rd, but if your mod becomes available before than, then I am up for going through you method.
Edited by Deadleave
Along with everyone else I hate how long it takes in between shifts esp in manual mode so as long as that's taken care of I'm game.
