CL21376 Posted May 10, 2012 Share Posted May 10, 2012 Tell them to match the price or cancel your order and you'll buy it online. Link to comment Share on other sites More sharing options...
Rutchard Posted May 10, 2012 Share Posted May 10, 2012 Lesson learned: you will get raped at the parts counter 99% of the time, always check prices online first. Link to comment Share on other sites More sharing options...
HERB5T Posted May 10, 2012 Share Posted May 10, 2012 I would get "raped" without you guys. Thanks a lot Link to comment Share on other sites More sharing options...
HansGT Posted May 10, 2012 Share Posted May 10, 2012 good point. I agree. Ill also try another local dealer Order #1 and #2x2 It was @ $104 shipped for me. To a business address....cheaper ; ) http://www.trademotion.com/parts/2010/SUBARU/IMPREZA/WRX%20STI/?siteid=216335&vehicleid=1445543&diagram=7592488 Link to comment Share on other sites More sharing options...
HERB5T Posted May 10, 2012 Share Posted May 10, 2012 Order #1 and #2x2 It was @ $104 shipped for me. To a business address....cheaper ; ) http://www.trademotion.com/parts/2010/SUBARU/IMPREZA/WRX%20STI/?siteid=216335&vehicleid=1445543&diagram=7592488 love you man! Link to comment Share on other sites More sharing options...
HERB5T Posted May 10, 2012 Share Posted May 10, 2012 Order #1 and #2x2 It was @ $104 shipped for me. To a business address....cheaper ; ) http://www.trademotion.com/parts/2010/SUBARU/IMPREZA/WRX%20STI/?siteid=216335&vehicleid=1445543&diagram=7592488 are you sure this is the 19mm? it doesn't seem to specify... Link to comment Share on other sites More sharing options...
HansGT Posted May 10, 2012 Share Posted May 10, 2012 call them to confirm part numbers in this thread. I'm pretty sure the WRX/STI 2008-2010 is the same and fits our cars and thats what I ordered and bolted up. BIG difference. Link to comment Share on other sites More sharing options...
HERB5T Posted May 10, 2012 Share Posted May 10, 2012 Props to fredbeans.com they are great Link to comment Share on other sites More sharing options...
bonomia3 Posted May 11, 2012 Share Posted May 11, 2012 Been pretty aggressive on my 22mm Whitline for 7 weeks now w/o snapping oem endlinks. Link to comment Share on other sites More sharing options...
HansGT Posted May 11, 2012 Share Posted May 11, 2012 Been pretty aggressive on my 22mm Whitline for 7 weeks now w/o snapping oem endlinks. The ol GT ran 5+ years with stock endlinks and Cusco sways. Link to comment Share on other sites More sharing options...
islandborn Posted May 11, 2012 Share Posted May 11, 2012 Bought the Lateral lock kit for my 22mm Whiteline through Infamous - needed? prob not. But it gives me a bit of sureness. Link to comment Share on other sites More sharing options...
lgkahn Posted May 13, 2012 Share Posted May 13, 2012 off course i would be the one that had probems with this.. My car is over 2 yrs old and the stock end link bolts were pretty rusted up. I sprayed with lock tite and later wd40 and got most of the rust off.. it was hard getting one side off i had to keep backing it off and spraying with wd40 again to get the newly accumulated rust out of the threads.. I even have the correct size allen wrench 5mm.. Anyway got one sde off with much work but the other damn side even following the same procedures eventually jammed up so good i could not move it in either direction. So i took the whole end link out with the bar. IT WAS jamed up so good that even with the allen wrench in a vise i just stripped the allen threads. Also tried vice grips but all this got me was the grease coming out of the gasket, and taking metal off the other part.. Anyway didnt really want to pay double what the damn end links cost and wait a couple of days for the local dealer to order new endlinks.. Ordered a couple this weekend online.. and while waiting was able to cut the old nut off with a hax saw and filed it a little and got the remaining threads workable. Got a replacment nut (10mm) at home depot.. also bought a can of lithium grease with a little spray tube and put as much as i could get under the rubber gasket.. Got the new bar on.. and figure it will be fine until i get the replacment end links.. what a unexpected pleasure Link to comment Share on other sites More sharing options...
canadianelbow Posted May 14, 2012 Share Posted May 14, 2012 off course i would be the one that had probems with this.. My car is over 2 yrs old and the stock end link bolts were pretty rusted up. I sprayed with lock tite and later wd40 and got most of the rust off.. it was hard getting one side off i had to keep backing it off and spraying with wd40 again to get the newly accumulated rust out of the threads.. I even have the correct size allen wrench 5mm.. Anyway got one sde off with much work but the other damn side even following the same procedures eventually jammed up so good i could not move it in either direction. So i took the whole end link out with the bar. IT WAS jamed up so good that even with the allen wrench in a vise i just stripped the allen threads. Also tried vice grips but all this got me was the grease coming out of the gasket, and taking metal off the other part.. Anyway didnt really want to pay double what the damn end links cost and wait a couple of days for the local dealer to order new endlinks.. Ordered a couple this weekend online.. and while waiting was able to cut the old nut off with a hax saw and filed it a little and got the remaining threads workable. Got a replacment nut (10mm) at home depot.. also bought a can of lithium grease with a little spray tube and put as much as i could get under the rubber gasket.. Got the new bar on.. and figure it will be fine until i get the replacment end links.. what a unexpected pleasure After I stripped on of my allen key holes, I too took the link out with the bar. I was able to get a pair of needle nose 10" vice grips on the back side of the "bolt" to keep it from spinning while holding the bar in a vice and worked it out. I used a tap and die to clean both ends up for re-assembly and it all worked out. It's crappy that you were not able to get off. I see now that I was that one short step away from having to order new links too. I guess the best word of advice one could give after this experience is to WD40 those threads every day for a week before attempting to remove. A little patience could have saved both of us a whole lot of headache. Link to comment Share on other sites More sharing options...
lgkahn Posted May 14, 2012 Share Posted May 14, 2012 After I stripped on of my allen key holes, I too took the link out with the bar. I was able to get a pair of needle nose 10" vice grips on the back side of the "bolt" to keep it from spinning while holding the bar in a vice and worked it out. I used a tap and die to clean both ends up for re-assembly and it all worked out. It's crappy that you were not able to get off. I see now that I was that one short step away from having to order new links too. I guess the best word of advice one could give after this experience is to WD40 those threads every day for a week before attempting to remove. A little patience could have saved both of us a whole lot of headache. ya tried the vice grips too.. just stripped the metal piece also.. it was really tight.. car drives ok with makeshift repairs. but without most of the lubricant in the end link dont think it will last long.. new ones should be here soon.. Link to comment Share on other sites More sharing options...
Rutchard Posted May 14, 2012 Share Posted May 14, 2012 Cleaning off the exposed threads with a wire brush helps a lot too... Link to comment Share on other sites More sharing options...
unloader Posted May 14, 2012 Share Posted May 14, 2012 Best mod ever. I'm disappointed subaru hasn't corrected this issue. I've had the bar installed for a month or so and just got back from a rainy, windy, 200 mile trip. It handled great. Can't put a price on safety! 16mm = unsafe at highway speeds 19mm = planted and reasonable stability Link to comment Share on other sites More sharing options...
subaruonlineparts.com Posted May 14, 2012 Share Posted May 14, 2012 The release info of the of the 2013 Outback says they have stiffened up the sway bar to reduce body roll, No mention on the sedan though.... Link to comment Share on other sites More sharing options...
faded-a-fool Posted May 15, 2012 Share Posted May 15, 2012 The release info of the of the 2013 Outback says they have stiffened up the sway bar to reduce body roll, No mention on the sedan though.... They also mentioned stiffer shocks and struts for the sedan to reduce body roll. Link to comment Share on other sites More sharing options...
subaruonlineparts.com Posted May 15, 2012 Share Posted May 15, 2012 For those of you with stubborn/rusted hardware we have available hardware and sway bar link kits. You can also order any specific nut or bolt you may need from the repair parts catalog as well. http://subaruonlineparts.com/subaru-legacy-rear-sway-hardware-p-1799.html http://subaruonlineparts.com/subaru-legacy-rear-sway-link-p-1800.html Thanks, Benny Link to comment Share on other sites More sharing options...
HERB5T Posted May 18, 2012 Share Posted May 18, 2012 While taking the stock bar off, I was loosening the bar from the end links and on both of them, i used vice grips, because i was having trouble with the allen wrenches, and when i used the vice grips, lots of greece oozed from the end link pillow joint... Is this at all a problem? Link to comment Share on other sites More sharing options...
canadianelbow Posted May 19, 2012 Share Posted May 19, 2012 While taking the stock bar off, I was loosening the bar from the end links and on both of them, i used vice grips, because i was having trouble with the allen wrenches, and when i used the vice grips, lots of greece oozed from the end link pillow joint... Is this at all a problem? Yup, buy new links. Those ones are gonna start makin noise soon. You could ride it out and see how long they last, but if your luck is anything like mine, when you need them, they will be back-ordered. Link to comment Share on other sites More sharing options...
HERB5T Posted May 20, 2012 Share Posted May 20, 2012 Yup, buy new links. Those ones are gonna start makin noise soon. You could ride it out and see how long they last, but if your luck is anything like mine, when you need them, they will be back-ordered. If they do start squeaking, couldnt i just add more grease inside? Sounds like its a big deal over a small part If I had to buy new ones, Id want to get bigger ones... How about the STi ones? I would like to stick with subaru stuff if they are good Link to comment Share on other sites More sharing options...
GravityGear Posted May 22, 2012 Share Posted May 22, 2012 While taking the stock bar off, I was loosening the bar from the end links and on both of them, i used vice grips, because i was having trouble with the allen wrenches, and when i used the vice grips, lots of greece oozed from the end link pillow joint... Is this at all a problem? wow, did you drove your car in Greece? you must have accumulated a lot of that country while you were there... I'm sorry, i had to do it. i still can't stop laughing. It's grease btw, just to avoid any confusion in future posts or if you happen to vacation in Greece or order some Greece from somewhere and you get food instead of lubricating material. oh also, that doesnt sound right that a bunch of grease came out, they should be sealed with that boot thing. it may cause noise if you don't keep them lubricated with some grease. Link to comment Share on other sites More sharing options...
CL21376 Posted May 22, 2012 Share Posted May 22, 2012 wow, did you drove your car in Greece? you must have accumulated a lot of that country while you were there... I'm sorry, i had to do it. i still can't stop laughing. It's grease btw, just to avoid any confusion in future posts or if you happen to vacation in Greece or order some Greece from somewhere and you get food instead of lubricating material. oh also, that doesnt sound right that a bunch of grease came out, they should be sealed with that boot thing. it may cause noise if you don't keep them lubricated with some grease. Link to comment Share on other sites More sharing options...
Rutchard Posted May 22, 2012 Share Posted May 22, 2012 If I had to buy new ones, Id want to get bigger ones... How about the STi ones? I would like to stick with subaru stuff if they are good STi endlinks might not fit, but even if they did it'd be the same style as your stock ones. Same shit, different Subaru Link to comment Share on other sites More sharing options...
