Zee199969 Posted September 30, 2014 Share Posted September 30, 2014 The 20mm RSB bolted right up and after about 1000mi I have not noticed any major oversteer. The rear end stays flatter than it did before. I would like to eventually install a 26mm FSB, but the install costs are prohibitive for me right now. First up aftermarket springs/struts! My "Build" Link to comment Share on other sites More sharing options...
GTEASER Posted September 30, 2014 Share Posted September 30, 2014 ^^That's a great plan, springs and shocks first. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
DugsSin Posted October 8, 2014 Share Posted October 8, 2014 these parts have been sitting on my shelf for way too long, not anymore. Link to comment Share on other sites More sharing options...
fredrik94087 Posted October 9, 2014 Share Posted October 9, 2014 The 20mm RSB bolted right up and after about 1000mi I have not noticed any major oversteer. The rear end stays flatter than it did before. I would like to eventually install a 26mm FSB, but the install costs are prohibitive for me right now. First up aftermarket springs/struts! The 24/20 F/R are probably matched up nicely. You may decide against the 26mm bar once you take care of springs/shocks and maybe adjustable LCAs and a proper alignment. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Zee199969 Posted October 9, 2014 Share Posted October 9, 2014 IIRC the 2010 OEM FSB is 23mm? I'm patiently awaiting pics of coppertone's RCE/bilsteins after he is able to get them off his car. The most suspension work I've ever done on any of my cars is a RSB, so installation will be a learning experience. But back to the FSB, I'm wondering how much the ride is changed from the 23mm to 24mm. Do you think the 26mm would create too much understeer when paired with the 20mm RSB? My "Build" Link to comment Share on other sites More sharing options...
jackal8788 Posted October 9, 2014 Share Posted October 9, 2014 IIRC the 2010 OEM FSB is 23mm? I'm patiently awaiting pics of coppertone's RCE/bilsteins after he is able to get them off his car. The most suspension work I've ever done on any of my cars is a RSB, so installation will be a learning experience. But back to the FSB, I'm wondering how much the ride is changed from the 23mm to 24mm. Do you think the 26mm would create too much understeer when paired with the 20mm RSB? Correct, 23mm is the stock FSB size. 26/20 might be a little more than you'd want, but some of that will depend on the rest of your setup. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
fredrik94087 Posted October 9, 2014 Share Posted October 9, 2014 IIRC the 2010 OEM FSB is 23mm? I'm patiently awaiting pics of coppertone's RCE/bilsteins after he is able to get them off his car. The most suspension work I've ever done on any of my cars is a RSB, so installation will be a learning experience. But back to the FSB, I'm wondering how much the ride is changed from the 23mm to 24mm. Do you think the 26mm would create too much understeer when paired with the 20mm RSB? You could always throw more negative camber up front and less in the rear if you had to balance it out. There is always a way.  Based on my 2.5i 6mt which was 50/50 F/R split and the 3.6R which is 45/55 F/R split (by split I mean how power is put down according to Subaru), a 26mm FSB and the 22mm RSB (set at 23mm) seem to work decently. My front camber was more negative than the rear for both cars to balance things out. That is the only reason I believe you will be okay with your F/R setup. If you go bigger up front, you will most likely need to go bigger in the rear. There are guys who are running more negative camber in the rear, but I don't know their complete setup. They may be running a 23mm/22mm F/R. All I can offer is my experience with the two cars. That being said, I have never owned an LGT, so I can't give you first hand information. However, I doubt it would be very different. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
linksusmaximus Posted October 13, 2014 Share Posted October 13, 2014 Not sure if i posted this already or not, and i guess this thread switched to a 20mm rsb install thread.. anyway, i'm in a 2013 2.5i 6MT with the 20mm rsb and stock 26mm fsb. Prothane urethane bushings for the rsb, fsb bushing upgrade is coming soon. Didn't notice much improvement in cornering to be honest (up from 16mm rsb), but feel MUCH more stable and confident at highway speeds. Maybe because my springs are already upgraded? Slight camber in the rears too. I don't know, regardless i'm very happy with the straight line cruising at least, so to me it was worth it. And it's blue for added hp Link to comment Share on other sites More sharing options...
Dieselj25 Posted March 4, 2016 Share Posted March 4, 2016 I did the 20mm RSB upgrade a few weeks ago on my 2013 Legacy 2.5, and I am amazed at the difference it made across the board. Going straight on the interstate is greatly improved, less corrections, better feel, more planted. Ride quality has not changed. The exit ramps and winding roads are a blast now. I'm glad I went with the 20mm over the 19mm, because I feel there is still more anti-sway that could be corrected. For around $100, worth every penny. If there is a larger budget, well, I think the even larger aftermarket RSB mentioned here may be best, but the 20mm nails it very well. Link to comment Share on other sites More sharing options...
gforce13 Posted March 5, 2016 Share Posted March 5, 2016 Anybody have any experience with the epic engineering 22mm adjustable RSB? I found a good price on one and wonder how it compares to whiteline. Â Â Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
cerrone Posted May 10, 2017 Share Posted May 10, 2017 Hey guys, I'm convinced to replace the stock 16mm RSB with ОЕМ 19 or 20mm on my Legacy 2010. Both have relatively the same price tag - 19mm costs $10 more. What would be the benefit of having 20 over 19mm? I’m just a regular driver of a family sedan with no sport habits at all, who doesn’t like what you all described as a feeling already here having the stock RSB in their vehicles. The roads around me a bit bumpy if that helps. Should I go for the 19 or 20mm? Thanks. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted May 10, 2017 Share Posted May 10, 2017 I am doing mine sunday I fudged up one of my end links lol Link to comment Share on other sites More sharing options...
Humble Rumble Posted May 10, 2017 Share Posted May 10, 2017 I would say go with 20 mm RSB, especially if it's cheaper. There's no real reason to go with the 19, as you won't really feel a difference between it and the 20. And replacing your RSB with a thicker one will not have any effect on harshness/softness on bumpy roads whatsoever. A thicker sway bar will just reduce body roll in the rear, which will make driving it feel less a bit less boaty around turns. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
GTEASER Posted May 10, 2017 Share Posted May 10, 2017 just do the 20. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted May 10, 2017 Share Posted May 10, 2017 +1 for the 20mm, it is like $30-40 cheaper Link to comment Share on other sites More sharing options...
dgoodhue Posted May 10, 2017 Share Posted May 10, 2017 Do the 20mm RSB. I did the 19mm because at the time 20mm was not available. (The WRX/STI didn't get 20mm RSB until 2015) Link to comment Share on other sites More sharing options...
Zee199969 Posted May 10, 2017 Share Posted May 10, 2017 I've got the WRX 2015+ 20mm RSB. no complaints whatsoever My "Build" Link to comment Share on other sites More sharing options...
cerrone Posted May 11, 2017 Share Posted May 11, 2017 Thanks a lot guys. Will go for the 20mm. I found some sites where you can order it 20451VA000 + 2 bushings 20464VA000 + shipping for $88. https://www.generalmotorspartsonline.com https://www.heubergersubaruparts.com https://www.parts.com http://www.subarupartsandaccessories.com Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted May 11, 2017 Share Posted May 11, 2017 these parts have been sitting on my shelf for way too long, not anymore.  where did you get those orange things? Link to comment Share on other sites More sharing options...
DugsSin Posted May 11, 2017 Share Posted May 11, 2017 AVO turboworld http://www.avoturboworld.com/catalog/product_info.php/products_id/148 Link to comment Share on other sites More sharing options...
Humble Rumble Posted May 11, 2017 Share Posted May 11, 2017 Great! Something else I didn't know existed for our cars and now want. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
CDKJudoka Posted May 15, 2017 Share Posted May 15, 2017 Looks like I will be giving my buddies a SOP a ring for the 20MM RSB. My 2014 handles nicely, but I have a bunch of fun roads here in PA that I would like to take advantage of, and there is a decent amount of push at times. 2014 Legacy 2.5i 6M - FB25 w/ a 6 speed 2002 Impreza 2.5TS - EJ251 w/ a 5 speed (The Stormtrooper) Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted May 21, 2017 Share Posted May 21, 2017 AVO turboworld http://www.avoturboworld.com/catalog/product_info.php/products_id/148 when you installed those, was it just as simple as remove bolt put on and reinstall that bolt (talking about the bolt that goes up into the chassis). I got the 20mm installed and it was best just to buy new end links and install the bar with links attached first to the bar first and then bolt end links to lower arms and then bolt up brackets. All done while the car was backed up onto ramps Link to comment Share on other sites More sharing options...
DugsSin Posted May 21, 2017 Share Posted May 21, 2017 ^^ Yes but if I remember correctly you should do them one at a time or risk a of some sort. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted May 22, 2017 Share Posted May 22, 2017 yes I plan on one at a time Link to comment Share on other sites More sharing options...
