Koni Shock/Strut & Epic Engineering Spring Install
Just take 1 of the top hat nuts off when you arrive and park at the parts store, walk into the store and make sure the nut off your car fits the bolt, put the nut back on your car and drive home.
After recently pulling my suspension, the M12 that you guys are throwing around sounded too big, thats about 1/2" diameter bolt. I didn't remember it being that large.
Listed here it looks like the bolts should be M10x1.25 and for 3/8" spacers you will need a 30mm +/- length.
http://www.subtle-solutions.com/product_info.php?cPath=21_25_64_92&products_id=234
Edited by GTEASER
Looks like I forgot that the Geo Metro was not correct. I found my post from earlier. If you haven't gotten new top hats (like you should), buy them from Tire Rack for $25 or face squeaks of death). Take them to the store and compare the stud.
From #121:
wheel stud for 3/8" spacer is M10x1.25x29mm. You can get them at NAPA
Edited by compsurge
I've been looking but can't find a good answer. Do the Cusco camber plates work with the stock spring perches for this install to get up graded bearings with out raising the front end from the Spec B top hats? Or just go with the Whitelines? Thanks.
They will work. But in all honesty the Cusco plates are rather weak. Bearing is single (so it is doing double duty as the bearing takes the load and pivots). They are also out of stock and must be imported so that takes 8 weeks. Go Whiteline at this point if you want aftermarket.
So just to clarify... It is a M10 X 1.25 X 29mm. At Napa, it's a wheel stud for a 1994-2000 Metro.
Does it matter which way the lower perch faces on the rear Koni's?? Doesn't seem like it would... I wasn't to careful about the orientation on the first one.
Side note: The black bolt provided by Koni to secure the bottom of the insert in the strut assembly was cracked across the bolt head from the center to the edge :confused: Didn't notice it until the assembly was completed...
Finished installing the fronts, with Htech Springs, today.
Job was straightforward and I'm very confident that I could def take less time when I do it next time.
Only bad thing I came into was one of the lug nuts was hot when I took it off and took quite a bit of time to remove it.
  • I Donated
^^ Thanks.
Anyone figured out how to adjust the rear Koni's as the supplied key is to short??
If you have a wagon, there's a post midway through these pages that show a DIY for making the adjuster a bit longer so that it works. If you have a sedan, it's not too short.
Edit: here it is - http://legacygt.com/forums/showpost.php?p=3847249&postcount=144
Edited by bucko3the7man
^^ Thanks.
Wouldn't needle nose pliers work ? They make some that are really long.
Engine Build - Click Here
Someone used my tool! :wub:
Needle nose pliers should work as well, but in my experience it was a blind operation; mainly due to me not figuring out how to get the carpet completely out :rolleyes:
I'm not sure if the Metro wheel stud is correct. The proper size is the one that matches the thread pitch and bolt diameter of the nut on the current top hat.
The lower perch shouldn't matter, but I like symmetry. The spring will compress and rotate into place. If it doesn't, a few good bumps should seat it. You really want new top hats, as the new rubber won't squeak like the old, worn rubber might.
Edited by compsurge
  • I Donated
I disagree. I have a sedan, and I can tell you 100% it IS too short!! Needle nose pliers will be a b*tch based on the amount of room back there. Think I will check the DIY :icon_tong
I have a sedan and have no problems using it. Is it close to the bottom? yes. Is it too short to be useful? No.
