TbirdMan Posted November 1, 2010 Share Posted November 1, 2010 lol, looks like Christmas with all the lights on the dash. Link to comment Share on other sites More sharing options...
docdrey Posted November 1, 2010 Share Posted November 1, 2010 AH COMON!!!! GET ON IT!!!! All this power and i have to watch you do 40mph... great video nonetheless. As a guy who's done allot of fab work and built crazy things like my wide-body wagon http://i267.photobucket.com/albums/ii313/andruskitheruski/saabaru%20edit/IMG_6368.jpg I have mad RESPECK for you man Link to comment Share on other sites More sharing options...
ehsnils Posted November 1, 2010 Share Posted November 1, 2010 We see progress all the time! That's inspiring. Link to comment Share on other sites More sharing options...
RALLYT-WRX Posted November 1, 2010 Share Posted November 1, 2010 I love all the warning lights on in the dash. Car is probably saying WTF is going on! Link to comment Share on other sites More sharing options...
ehsnils Posted November 1, 2010 Share Posted November 1, 2010 i cut the upper and lower rad supports, then replaced the lower one with a 1-1/2" square tube 3/16" wall and the upper one is a removeable angle iron 3/16" thick. this won't affect the structual regidity of the car becuase its mostly done by the unibody cab ie window struts and door posts. also what i replaced the parts with is much stronger than original. It may have some effect on the crumple zone, but since it's (from what I understand) only the radiator mount that's going across the travel direction of the car I don't see any problems either. Link to comment Share on other sites More sharing options...
frank_ster Posted November 1, 2010 Author Share Posted November 1, 2010 I love all the warning lights on in the dash. Car is probably saying WTF is going on! should take it to the dealer to put it on a scanner Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
joeblow Posted November 1, 2010 Share Posted November 1, 2010 ^You should do it. And then see how they react when they pop the hood. I'd be willing to bet that some dealerships' service departments wouldn't realize it was the wrong engine. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
snow05gtRI Posted November 1, 2010 Share Posted November 1, 2010 ^You should do it. And then see how they react when they pop the hood. I'd be willing to bet that some dealerships' service departments wouldn't realize it was the wrong engine. Link to comment Share on other sites More sharing options...
ruggerheist Posted November 1, 2010 Share Posted November 1, 2010 just leave the warning lights, jazzs up the instrument panel... Link to comment Share on other sites More sharing options...
AkumaMax Posted November 1, 2010 Share Posted November 1, 2010 should take it to the dealer to put it on a scanner should film that. Would love to see the techs face when he opens up the hood. WTF??? Link to comment Share on other sites More sharing options...
John M Posted November 1, 2010 Share Posted November 1, 2010 There's probably a CEL code for Engine Replaced with GM V6. You know how fancy cars are these days! Oh, and a major congrats on the first drive. Link to comment Share on other sites More sharing options...
PlaxPhoto Posted November 1, 2010 Share Posted November 1, 2010 should film that. Would love to see the techs face when he opens up the hood. Wtf??? +1 Link to comment Share on other sites More sharing options...
Laverne Posted November 1, 2010 Share Posted November 1, 2010 That would be priceless... love to see that.. Leave the charge pipes off too, that will likely be the only thing they notice..lol Link to comment Share on other sites More sharing options...
frank_ster Posted November 2, 2010 Author Share Posted November 2, 2010 ic lines Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Laverne Posted November 2, 2010 Share Posted November 2, 2010 (edited) YAYYYYY IC tubes!!!! Edited November 2, 2010 by Laverne Link to comment Share on other sites More sharing options...
SBT Posted November 2, 2010 Share Posted November 2, 2010 IC them too... - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
ehsnils Posted November 2, 2010 Share Posted November 2, 2010 I suppose that there was no routing that would have made them less obvious? But since it's a V6 a dual turbo solution would be a wonderful alternative. Link to comment Share on other sites More sharing options...
frank_ster Posted November 2, 2010 Author Share Posted November 2, 2010 I suppose that there was no routing that would have made them less obvious? But since it's a V6 a dual turbo solution would be a wonderful alternative. why ? its doubble the stuff .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
frank_ster Posted November 4, 2010 Author Share Posted November 4, 2010 so i disabled all the cel codes. except the cam position sensor ones 340 and 345 witch were omited randomly. i then disabled those and then car would never accecpt tach signal. ( ie not start the fuel pump ) however the cel turns off while cranking and engine running on the fuel pump prime. so the ecu know that the engine is turning. i can reproduce the ability for the tach to work every time now, the engine simply needs to be cranked for at least 5 seconds. ( nothing worked when i disabled codes 340 amd 345 i'm not sure why. i'll try angain later. But i do know for a fact that the subaru ecu checks for the cam alignement before allowing the engine to start. ( i had one cam off phase a little bit ) and the car would never start untill i unpluged the cam sensor. other than that i have made several trips to the store and around town. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Prog Posted November 4, 2010 Share Posted November 4, 2010 wow this is one crazy project, but cool! Link to comment Share on other sites More sharing options...
kaz98gt Posted November 4, 2010 Share Posted November 4, 2010 Loving the progress you've made, awesome job! And the ic lines are up too...wish I could see this one in person to learn a thing or two. Link to comment Share on other sites More sharing options...
executor485 Posted November 4, 2010 Share Posted November 4, 2010 It will never work! Quite the awesome project, been following for quite some time and I'm very impressed. Anxious to see some dyno charts someday If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
vr4Legacy Posted November 4, 2010 Share Posted November 4, 2010 The project hasn't really started nor am I getting the impression it will, aside from just talking about it. Good luck should you ever decide to do something, frank_ster. /unsubscribe :lol::spin: Is this guy out there now? Wonder if he's has check this thread recently? Progress is amazing thus far. I am AMAZED how quickly you have gotten so far on this project, and the fact that you are trying to make all the stock interior guages work. Keep up the awesome work and vids! Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 4, 2010 Share Posted November 4, 2010 Loving the progress you've made, awesome job! And the ic lines are up too...wish I could see this one in person to learn a thing or two. I get the feeling Frankster is very nice in person... And I get the feeling anyone would learn more than just two things... [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
ehsnils Posted November 4, 2010 Share Posted November 4, 2010 why ? its doubble the stuff .. Two smaller ones in parallel instead of one large will give better response and three cylinders per turbo is actually fairly good. However you can mount them close to the cylinder heads on the exhaust side. But it will make things a bit more complicated when it comes to plumbing. Maybe a future modification. Link to comment Share on other sites More sharing options...
