VTGT Posted June 26, 2010 Share Posted June 26, 2010 Subscribeeee for craziness Link to comment Share on other sites More sharing options...
Scruit Posted June 27, 2010 Share Posted June 27, 2010 What rear end ar you going to use? The stocker is designed to handle 50% of 250hp. You're gonna give it 100% of 600hp? I know these things always have some leeway designed into them but you're honestly going to expect it to hold up after you quintuple the power it has to handle?? Link to comment Share on other sites More sharing options...
frank_ster Posted June 27, 2010 Author Share Posted June 27, 2010 What rear end ar you going to use? The stocker is designed to handle 50% of 250hp. You're gonna give it 100% of 600hp? I know these things always have some leeway designed into them but you're honestly going to expect it to hold up after you quintuple the power it has to handle?? as i said before its not going to get more traction so the torque going through the diffrential is limited to the traction of the tires, and in stock form i could make the 4 tires spin. The most abusive thing to drive lines are manual trannys and clutch dumping. for the wrx's i have seen doing years of clutch dumping clutch dumping = torque of engine + inertia of the engine accelerating the enertia of the wheels and tires. You can think of it as a 1 lb hammer vs a 12 tonne shop press. they both can remove the same stubborn bearing. E= mv^2 my 600 hp camaro is running with the stock diffrential with 10.5" slicks 4.10 gears and 4000 stall torque. the same diff would have snaped axels on a 4 speed version after a few clutch dumps. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Scruit Posted June 27, 2010 Share Posted June 27, 2010 So the power above 125hp is wasted as wheelspin, then? (kidding...) Link to comment Share on other sites More sharing options...
frank_ster Posted June 27, 2010 Author Share Posted June 27, 2010 So the power above 125hp is wasted as wheelspin, then? (kidding...) well i would say its more like 2500 -3000 ft lbs coming out of the diffrential is the limit of traction .. and the idea is to keep that torque output for as long as possible ( into higher gears ) the 3.8 should develop 550 ft lbs tq * 3.53 for first gear ratio and then times 3.23 for final ratio = about 6000 lbs tq availiable in first gear 4000 lbs in second gear 2600 in 3rd gear 1700 in 4th gear so i forsee first second and posibly 3rd gear burn outs Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
zmarko Posted June 27, 2010 Share Posted June 27, 2010 Interesting idea. Good luck with it. Link to comment Share on other sites More sharing options...
BennnGeee Posted June 27, 2010 Share Posted June 27, 2010 Why would you even want a 600hp subaru? Who are you ken block? Can you even handle that much power under your right foot? I would like to see this happen though pictures and videos please. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted June 27, 2010 Share Posted June 27, 2010 Why would you even want a 600hp subaru? Who are you ken block? Can you even handle that much power under your right foot? I would like to see this happen though pictures and videos please. He forgot to check with you first [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
frank_ster Posted June 27, 2010 Author Share Posted June 27, 2010 had 600 hp camaro for 9 years and have driven various 1200 hp cars Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
NSFW Posted June 27, 2010 Share Posted June 27, 2010 He forgot to check with you first Link to comment Share on other sites More sharing options...
TheWeatherWarrior Posted June 28, 2010 Share Posted June 28, 2010 shucks....I'd go V8 if I was gonna swap a motor. I'm thinking the 4.0 northstar from the Olds aurora wasn't too big. Of course likely doesn't have the aftermarket parts. Link to comment Share on other sites More sharing options...
frank_ster Posted June 28, 2010 Author Share Posted June 28, 2010 shucks....I'd go V8 if I was gonna swap a motor. I'm thinking the 4.0 northstar from the Olds aurora wasn't too big. Of course likely doesn't have the aftermarket parts. the idea to get away from expensive engines! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
moncur_6 Posted June 28, 2010 Share Posted June 28, 2010 Definitely subscribed. I am anticipating some pictures along with most everyone else. Link to comment Share on other sites More sharing options...
underpowerd Posted June 28, 2010 Share Posted June 28, 2010 (edited) Except many people have made rotated kits, while not too many people put GM engines in Subarus. This configuration has already been done, including with a slightly bigger Garrett Frankster probably spent $20k less though ok, then a guy who does 'that'...in a 5eat Edited June 28, 2010 by underpowerd Link to comment Share on other sites More sharing options...
Tommyh Posted June 28, 2010 Share Posted June 28, 2010 So this, it's gonna be awesome isn't it? Martin Luther - "Who loves not women, wine and song remains a fool his whole life long." EL4NFZT7 Link to comment Share on other sites More sharing options...
ece_tim Posted June 28, 2010 Share Posted June 28, 2010 shucks....I'd go V8 if I was gonna swap a motor. I'm thinking the 4.0 northstar from the Olds aurora wasn't too big. Of course likely doesn't have the aftermarket parts.Actually, it's huge. DOHC V-engines take up a LOT of space. Cam-in-block OHV motors like the GM LS series are actually very compact, and it's why you find them swapped into all manner of rides. The turbo V6 OP is using is rather compact also, as I do believe its OHV as well. I have a pic somewhere of a 5.0L OHV and 4.6L DOHC Mustang motors side by side - the difference is shocking. Link to comment Share on other sites More sharing options...
ehsnils Posted June 28, 2010 Share Posted June 28, 2010 One thing that may be worth considering is to select a different oil for the differential that is has a thicker viscosity than standard as well as being more resilient to breaking the oil film. Link to comment Share on other sites More sharing options...
BennnGeee Posted June 28, 2010 Share Posted June 28, 2010 He forgot to check with you first Lol naw i was just curious, i can defiantly appreciate a good build subscribed awhile ago. I'm not sure if you went over this but are you using the same rear end or butting something a bit more beefy in there to support that power? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted June 28, 2010 Share Posted June 28, 2010 ok, then a guy who does 'that'...in a 5eat It says a lot about the 5eat. Subaru ATs get a lot of flack, but they have also held up really well in certain instances. You have to be willing to fix things as they break though. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
dudeondacouch Posted June 28, 2010 Share Posted June 28, 2010 Link to comment Share on other sites More sharing options...
frank_ster Posted June 29, 2010 Author Share Posted June 29, 2010 One thing that may be worth considering is to select a different oil for the differential that is has a thicker viscosity than standard as well as being more resilient to breaking the oil film. not worried about actual wear on the teeth! woried about plastic deformation of hardend parts ! Ie stuff breaking [ame=http://www.youtube.com/watch?v=hLsT92KbjTU&feature=related]YouTube- sunbird 3.8 turbo at napierville dragway[/ame] this is my sunbird launch from idle no bringing up the boost it had a consistant 2.00 60 foot on normal street tires the subie auto launch with no boost is what 2.6 sec ? or worse ?! man i can't wait ! i fly home tomorrow! wednesday the swap begins ! pictures will be posted wednight of first test fit. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
airyn Posted June 29, 2010 Share Posted June 29, 2010 subscribe Link to comment Share on other sites More sharing options...
ehsnils Posted June 29, 2010 Share Posted June 29, 2010 Just check out another user on this board too - Tomcat who has a decently tuned 3.0... (3.6 liter, supercharger...) A lot of fun stuff in this thread: http://legacygt.com/forums/showthread.php/rotrex-power-3-0r-68613.html Maybe you can get some additional tips there. Link to comment Share on other sites More sharing options...
Strizzy Posted June 29, 2010 Share Posted June 29, 2010 A lot of fun stuff in this thread: http://legacygt.com/forums/showthread.php/rotrex-power-3-0r-68613.html 404 - Not Found... My bad luck build Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted June 29, 2010 Share Posted June 29, 2010 http://www.thisis-matt.co.uk/images/Fail%20Pictures/Cheese%20fail.jpg That is ALL Link to comment Share on other sites More sharing options...
