GTSPECB STI Posted August 6, 2009 Share Posted August 6, 2009 STI lines won't fit, neither 04-07 nor 08-09. In fact, JDM tuned by STI that came with Brembos.... also uses the stock location ghetto fitting lines (braided) . Not sure about S402. There is apparently newer style Goodridge lines that fit better - they have less "bend" to them. One of Edmundu's original lines blew (luckily for him in my driveway) and he got replacement ones that fit better with the Brembos. pic of my rear sti brake line to brembo rear caliper connection http://i77.photobucket.com/albums/j60/Aussiedave_2006/brembo%20brakeline%20connection/rearbrakelinetocaliper1.jpg Link to comment Share on other sites More sharing options...
PhilT Posted August 6, 2009 Author Share Posted August 6, 2009 pic of my rear sti brake line to brembo rear caliper connection That's very different to a USDM Legacy. You haven't had to use an adapter bracket, and the rotors are small enough to fit the dust shields. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
GTSPECB STI Posted August 6, 2009 Share Posted August 6, 2009 yep thats how they come on the tuned by sti version here in Oz Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2009 Share Posted August 6, 2009 Yeah, this interesting because I checked JDM Subarufast (OEM application with part #s) and it refers to the aftermarket STI brake lines for regular Legacy GT. That's why I thought they are ghetto rigging it... Partially they do, e.g. the splash shield on your car looks hand cut for the caliper. I bet the tuned by STI and S402 is indeed "hand tuned" on the side.... given the limited numbers it make sense. pic of my rear sti brake line to brembo rear caliper connection http://i77.photobucket.com/albums/j60/Aussiedave_2006/brembo%20brakeline%20connection/rearbrakelinetocaliper1.jpg Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2009 Share Posted August 6, 2009 Btw, Dave, do you have any idea about the rear rotors? I.e. what is the diameter of the parking brake drum? I.e. do you need special rotors or regular STI rotors (just 5x100) will work? EDIT: Or, maybe you have regular LGT rear rotors actually ... just the caliper is somehow bolted directly to the backplate. Either special caliper or special backplate? Next time when you have the wheels off we would appreciate more detailed pics of the rear brakes and rear suspension bits! Thanks in advance! Link to comment Share on other sites More sharing options...
GTSPECB STI Posted August 6, 2009 Share Posted August 6, 2009 Ok I will make a note about the parking brake set up and check this on Aug 17th when the car goes in for a service a re-tune (open source flash) using a awd hub dyno. Perfect time to take pics of suspension and brakes. I recently changed out both front and rear stock rotors and replaced them with Dixcel Heat Treat and Slotted Rotors on fronts and Dixcel Slotted Rotors on the rears..a bit heavier but well worth it I believe. Link to comment Share on other sites More sharing options...
Waxiboy Posted August 6, 2009 Share Posted August 6, 2009 The lgt brake line should be rotated 90 degrees counter clockwise where it mounts to the caliper banjo bolt. Then its just a straight shot back to the hard line. Why have the ridiculous right angle bend in the line? So just like how the green wire is shaped but have the hard line do that part. I agree, maybe keep the "L" bend on the LGT line and just shorten the actual SS hose itself. I think a bit shorter would even work, say 7-7.25". Sorry to hear about your car. Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2009 Share Posted August 6, 2009 Ok I will make a note about the parking brake set up and check this on Aug 17th when the car goes in for a service a re-tune (open source flash) using a awd hub dyno. Perfect time to take pics of suspension and brakes. I recently changed out both front and rear stock rotors and replaced them with Dixcel Heat Treat and Slotted Rotors on fronts and Dixcel Slotted Rotors on the rears..a bit heavier but well worth it I believe. That will be great, thanks. But can you tell what size are the rear rotors? I.e. in order to buy replacements you must have specified whether you're buying LGT or STI rotors... Link to comment Share on other sites More sharing options...
VXCL Posted August 6, 2009 Share Posted August 6, 2009 :eek: What? Sorry to hear that man, but good you're alright yeah im fine. car is prob a goner though. bent the frame rails up front. slid into wall with front passenger side. seems like my lgt days are over. sucks. car only had 36k on it, never a prob, and always performed. hate the new ones and cant rock another 05 unless its mine. im weird like that. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2009 Share Posted August 6, 2009 Go buy a leftover 09. Maybe you can find a SpecB. You'll love the 6MT. Link to comment Share on other sites More sharing options...
GTSPECB STI Posted August 7, 2009 Share Posted August 7, 2009 sure happy to measure them unclemat. Here are the details on the dixcel rotors I recently bought and installed. Product Description Dixcel FCR SD Slotted Disk Set STI Brembo 5 x 100 PCD * For increased high performance use with Z type or R01 type pads. * The initial brake response will be improved. * It is recommended to the professional racing drivers who require more braking stability. * HD type will be substituted with FCR type when available, please understand that FCR type is of a higher grade than HD. FCR (FP) type is supplied automatically with no extra charge. * Although each one of the FCR(FP&FS) rotor, the heated disk rotor(HD) and heated slot disk rotor(HS) has had heat treatment, please take a bedding-in procedure. Sudden heating or cooling by braking may cause cracks, tensions and judder. * The appearance of anti-rust coating and heat treatment varies on individual product, but it does not affect the quality of products. Suit Models Impreza STi 01-04 With Brembos Link to dixcel application table here http://www.dixcel.co.jp/en/rotor_zaiko.html Link to comment Share on other sites More sharing options...
Guest Posted August 7, 2009 Share Posted August 7, 2009 So these are standard STI rotors... you must have STI sized parking brake shoes than. Did you replace the rotors yourself? Curious if the parking brake shoes looked unusual in any way. Link to comment Share on other sites More sharing options...
GTSPECB STI Posted August 7, 2009 Share Posted August 7, 2009 I believe that is the case but I did not do the install myself. I left that to my mechanic as he did the pad replacement at the same time plus some other mechanical tweeks. Link to comment Share on other sites More sharing options...
VXCL Posted August 7, 2009 Share Posted August 7, 2009 Go buy a leftover 09. Maybe you can find a SpecB. You'll love the 6MT. no swp with black int kills it for me. been eyeing a leftover volvo c30r 6mt and its white. they have some great deals going on. haven't really read anything bad about them either so far. got a post about it in other cars MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Waxiboy Posted August 10, 2009 Share Posted August 10, 2009 Yup. This weekend I finally will have chance to mock up the actual line - I'll have an old stock line cut & taped to proper length (atc5 - ) Link to comment Share on other sites More sharing options...
Guest Posted August 10, 2009 Share Posted August 10, 2009 Yeah, I mocked up the line. Camera died so I don't have the pictures, but I'll be in touch with magnetic1 soon. Link to comment Share on other sites More sharing options...
Waxiboy Posted August 10, 2009 Share Posted August 10, 2009 So what length did you get? I wouldn't be surprised if you ended up with something shorter than 7.5" Link to comment Share on other sites More sharing options...
Waxiboy Posted August 14, 2009 Share Posted August 14, 2009 Any news from magnetic1? Link to comment Share on other sites More sharing options...
magnetic1 Posted August 15, 2009 Share Posted August 15, 2009 Whoops, sorry. Totally missed your PM. Will reply tomorrow morning after I figure out if that is all TF needs Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Guest Posted August 15, 2009 Share Posted August 15, 2009 magentic1, I've busy as hell, but I can mail you the mocked up line so you can give it to Technafit as a template. Pming you. Link to comment Share on other sites More sharing options...
Waxiboy Posted August 15, 2009 Share Posted August 15, 2009 Yay! We are finally moving Link to comment Share on other sites More sharing options...
Guest Posted August 18, 2009 Share Posted August 18, 2009 Yay! We are finally moving Well, I haven't heard back from magnetic1 yet. Hey, magnetic1, did you get my pm? Link to comment Share on other sites More sharing options...
atc5 Posted September 1, 2009 Share Posted September 1, 2009 YO...magnetic1....where you at? Link to comment Share on other sites More sharing options...
magnetic1 Posted September 3, 2009 Share Posted September 3, 2009 Waiting on lines from unclemat. Should be here soon, then template, send test lines to unclemat and if they are ok, then we produce and ship! Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Guest Posted September 3, 2009 Share Posted September 3, 2009 Sorry, I've been lagging (first magnetic1 was ) - the line will be put in mail tomorrow. Link to comment Share on other sites More sharing options...
