Guest Posted June 10, 2009 Share Posted June 10, 2009 I know but I think that plan won't work... Link to comment Share on other sites More sharing options...
LGT_King Posted June 12, 2009 Share Posted June 12, 2009 So I had a peek at the brake lines when I switched rims yesterday. Is there any reason why we can't just make one longer line but still have a captive nut to hold the line in place on the trailing arm (like imprezas have on the rear strut)? I would think this would increase the flexibility of installing the calipers or change pads on a stock setup. Just knock out the locking tab and you have a nice long line. Just seems like a lot of work/cost to have an extra set of fittings. Link to comment Share on other sites More sharing options...
zmarko Posted June 13, 2009 Share Posted June 13, 2009 Interesting thread. In to see where this goes. Still trying to piece together my Brembo setup. Link to comment Share on other sites More sharing options...
Waxiboy Posted June 16, 2009 Share Posted June 16, 2009 I am scheduled to go under the rear of the car this week to lube the PU bushings in my sway bars. I can make a mock from the hard line to the rear Brembo using a clear tube or even a string just so we have an exact measurement. Link to comment Share on other sites More sharing options...
Guest Posted June 16, 2009 Share Posted June 16, 2009 I took some pics, haven't had chance to upload them yet, but I can confirm that adding STI fitting to LGT's length line will make matters worse (if not impossible to fit). STI fitting and shortening the line is the ticket. Link to comment Share on other sites More sharing options...
PhilT Posted June 16, 2009 Author Share Posted June 16, 2009 I'm working away this week so can't get to see how the lines run on my car, but I'm sure it will be the same as yours. Can you get measurements UM ? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
ShockerGT Posted June 17, 2009 Share Posted June 17, 2009 I'll have to keep checking on this thread. While the LGT fitment lines work, the setup does not comply to my OCD standards. Would love to see a solution. Link to comment Share on other sites More sharing options...
Guest Posted June 17, 2009 Share Posted June 17, 2009 Here is a picture of the line (Goodridge SS line). As you could imagine keeping the line length same, but using straight fitting would make matter worse and force the line to bend too much. Link to comment Share on other sites More sharing options...
atc5 Posted June 22, 2009 Share Posted June 22, 2009 based on the above, Magnetic1 are you revising your lines to create a better solution? Link to comment Share on other sites More sharing options...
magnetic1 Posted June 23, 2009 Share Posted June 23, 2009 based on the above, Magnetic1 are you revising your lines to create a better solution? Yes, but Im waiting for some exact measurements..... Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Guest Posted June 23, 2009 Share Posted June 23, 2009 Yes, but Im waiting for some exact measurements..... magnetic1, it may take a while but I'll take the old stock line, I'll cut it to the needed length, then duct tape it - then I can sent to you so Technafit can use it as a template. Link to comment Share on other sites More sharing options...
VXCL Posted June 23, 2009 Share Posted June 23, 2009 magnetic1, it may take a while but I'll take the old stock line, I'll cut it to the needed length, then duct tape it - then I can sent to you so Technafit can use it as a template. nice! ill check it out when i rotate my tire this weekend as well. i got both oem and the lgt technica fit rear lines laying around. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
VXCL Posted July 2, 2009 Share Posted July 2, 2009 never got a chance to work on the car. maybe this weekend. prob just going to estimate a size so magnetic can get a set for me. bump for revival MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
VXCL Posted July 7, 2009 Share Posted July 7, 2009 So after checking out the rear lines while rotating my tires this is what I found out. Basically same as unclemat was saying, but figured this rough drawing would help explain it. I'm prob just going to mount mine like #2 not sure why people turn the line and go under the brembo tabs and run similar to the oem routing, but with a much more drastic bend. All we need is the same lgt braided setup just shorter. seems like about 2" for now but couldn't get an exact measurement. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
atc5 Posted July 7, 2009 Share Posted July 7, 2009 VXCL nailed it w/ the fabulous MS paint SKILLAZZZZZZ... Anyways....I will take measurements via photo's with a ruler up to the lines this weekend as I am swapping over to a black set of brembo's versus the goldies on the car now. Stay tuned. Link to comment Share on other sites More sharing options...
VXCL Posted July 8, 2009 Share Posted July 8, 2009 well now that i actually have rear rotors im prob going to do the rear swap after auto-x on sat. ill let you know about measurements. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Waxiboy Posted July 10, 2009 Share Posted July 10, 2009 I tried to check my rear pads today and I noticed that the upper shaft hits the brake line when you pull it out. I could not get the inner pad out but was able to pull the outer because the shaft only goes out halfway. I think this is more compelling reason why we should change the rear lines for correct fitment to the caliper. Link to comment Share on other sites More sharing options...
VXCL Posted July 10, 2009 Share Posted July 10, 2009 I tried to check my rear pads today and I noticed that the upper shaft hits the brake line when you pull it out. I could not get the inner pad out but was able to pull the outer because the shaft only goes out halfway. I think this is more compelling reason why we should change the rear lines for correct fitment to the caliper. which way is you line run? like 1 or 2? i havent seen anyone run it like in #2 but thats what im going to try as it doesnt have the extreme bend like in #1. did not check on this pins though. ill find out tomorrow cant wait to work on the drum e brakes should be super fun. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Waxiboy Posted July 11, 2009 Share Posted July 11, 2009 I did mine like #1. I don't think #2 is possible. Oh, can you also measure the correct line fitment? I forgot to do mine. Link to comment Share on other sites More sharing options...
VXCL Posted July 13, 2009 Share Posted July 13, 2009 I did mine like #1. I don't think #2 is possible. Oh, can you also measure the correct line fitment? I forgot to do mine. autox ran long on sat so i didnt get to do the brakes. as far as #2 i held the caliper and line in place when i rotated my wheels and everything lined up nicely. not going to rub on anything either, but an inch or two shorter would be much better. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Waxiboy Posted August 5, 2009 Share Posted August 5, 2009 Ok, so I finally made some measurements using automotive wire. http://i180.photobucket.com/albums/x6/Lukipooh/IMG_4735.jpg Measured from hex at the hard line joint to the center of the banjo bolt. Looks like 7.5" is the length to use. Can anyone confirm or double check? http://i180.photobucket.com/albums/x6/Lukipooh/IMG_4737.jpg Link to comment Share on other sites More sharing options...
atc5 Posted August 5, 2009 Share Posted August 5, 2009 nice! thanks for doing this.. Link to comment Share on other sites More sharing options...
VXCL Posted August 6, 2009 Share Posted August 6, 2009 http://i180.photobucket.com/albums/x6/Lukipooh/IMG_4735.jpg The lgt brake line should be rotated 90 degrees counter clockwise where it mounts to the caliper banjo bolt. Then its just a straight shot back to the hard line. Why have the ridiculous right angle bend in the line? So just like how the green wire is shaped but have the hard line do that part. good work. I would have done this but i hit a divider avoiding a deer and think my car is totaled. The rears just never made it on. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2009 Share Posted August 6, 2009 The lgt brake line should be rotated 90 degrees counter clockwise where it mounts to the caliper banjo bolt. Then its just a straight shot back to the hard line. Why have the ridiculous right angle bend in the line? So just like how the green wire is shaped but have the hard line do that part. Yup. This weekend I finally will have chance to mock up the actual line - I'll have an old stock line cut & taped to proper length (atc5 - ) good work. I would have done this but i hit a divider avoiding a deer and think my car is totaled. The rears just never made it on. :eek: What? Sorry to hear that man, but good you're alright Link to comment Share on other sites More sharing options...
BAC5.2 Posted August 6, 2009 Share Posted August 6, 2009 Good info to know. I was going to have a local shop simply make me a custom set of lines. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
