jcsny18 Posted November 29, 2011 Share Posted November 29, 2011 I live in a similar environment and was looking for the very same thing from my lowering springs. After much research I elected to purchase the Eibach pro kit. It offers a 1" drop in the front, and a .8" in the rear. I only had them installed on monday of this week, but so far they are exactly what I was looking for. I own a 2.5 se and have been looking everywhere for Eibachs for my car. According to their website they have no products compatible with legacy's unless its the 2010 and up models where and how did you get yours? Link to comment Share on other sites More sharing options...
soloz2 Posted November 29, 2011 Share Posted November 29, 2011 They are discontinued I believe... I haven't seen them in stock anywhere for a fee months. You'll probably have to get some Epics. They are the same spring Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
Catalyst Posted November 30, 2011 Share Posted November 30, 2011 +1 on the Epics. Incredible stance, looks like sporty OEM and not "hey look I slammed my ride" and you can still go over speed bumps and drive in the snow. Handling is improved drastically. "This is an adventure." Link to comment Share on other sites More sharing options...
Zac88 Posted December 4, 2011 Share Posted December 4, 2011 So I have decided on swifts for my wagon. Which struts should I go with? Link to comment Share on other sites More sharing options...
bmx045 Posted December 6, 2011 Share Posted December 6, 2011 So I have decided on swifts for my wagon. Which struts should I go with? koni Link to comment Share on other sites More sharing options...
peteyjr Posted December 7, 2011 Share Posted December 7, 2011 +2 (once again) Link to comment Share on other sites More sharing options...
05whitelegacy Posted December 7, 2011 Share Posted December 7, 2011 tein h techs .99 drop Link to comment Share on other sites More sharing options...
sactojesse Posted December 7, 2011 Share Posted December 7, 2011 So I have decided on swifts for my wagon. Which struts should I go with? Pick your spring depending on your intended strut, not the other way around. Bilstein HDs for Swifts. Swifts are designed to work w/ the Spec B top hat and thus should be used with Bilsteins and the Spec B top hat to get their advertised drop in front. If you go with a Koni and the stock KYB-style top hat, the fronts will be dumped approximately 5/8" lower than w/ Bilsteins and the Spec B top hats. Link to comment Share on other sites More sharing options...
peteyjr Posted December 8, 2011 Share Posted December 8, 2011 Well that explains why the front was slammed when I had swifts on. So are you talking about spec B specific springs by Swift. I thought they also made wagon /sedan specific springs Link to comment Share on other sites More sharing options...
sactojesse Posted December 8, 2011 Share Posted December 8, 2011 (edited) Well that explains why the front was slammed when I had swifts on. So are you talking about spec B specific springs by Swift. I thought they also made wagon /sedan specific springs There are no Spec-B specific Swift springs, only wagon and sedan, the difference being the length of the rear springs. All Swift springs for the BL/BP generation Legacy are designed to work with Bilstein-style (i.e., USDM Spec B) struts and top hats. Thus, the advertised drop in front assumes the use of those top hats. Same is true of pinks. That's why people who put pinks on their stock LGT KYB-style front struts/top hats ended up with about twice the advertised 15 mm (.6") drop in front. Edited December 8, 2011 by sactojesse Link to comment Share on other sites More sharing options...
N.sane Posted December 8, 2011 Share Posted December 8, 2011 In other words, JDM springs were intended for the JDM OEM suspension. Link to comment Share on other sites More sharing options...
Zac88 Posted December 9, 2011 Share Posted December 9, 2011 ok thanks bilstein HD's it is! Link to comment Share on other sites More sharing options...
jackfortune Posted December 9, 2011 Share Posted December 9, 2011 Bilstein HD's and pinks....a match made in heaven....lol... .....but true Link to comment Share on other sites More sharing options...
iamdkonz Posted December 11, 2011 Share Posted December 11, 2011 I can't find anywhere that still sells Rallitek or Cobb springs, but I would be happy to go with a comparable set up from another manufacturer. What would be a good match that is similar to those springs and paired with Bilstein HDs? Bilstein HD + USDM pinks or JDM pinks or swift? Spec B Top hats required for front and rear with my 06EAT wagon? Thanks Link to comment Share on other sites More sharing options...
scoobydoobie Posted December 11, 2011 Share Posted December 11, 2011 I can't find anywhere that still sells Rallitek or Cobb springs, but I would be happy to go with a comparable set up from another manufacturer. What would be a good match that is similar to those springs and paired with Bilstein HDs? Bilstein HD + USDM pinks or JDM pinks or swift? Spec B Top hats required for front and rear with my 06EAT wagon? Thanks Pinks are a JDM spring, no such thing as a USDM legacy pink spring. Spec.B top hats only required for the front. Can re-use your stock tophats with the rear struts. Welcome to the forum. Link to comment Share on other sites More sharing options...
N.sane Posted December 12, 2011 Share Posted December 12, 2011 COBB and RalliTEK are both discontinued, and they're quite different from each other in terms of their lowering amount and spring rates, so which equivalent are you looking for? COBB: 1.75" front, 1" rear. Exact spring rates are unknown, but they say it's progressive rates that are "close to stock". Stock rates are 3.5 kg/mm front, 5.5 kg/mm rear. RalliTEK: 1.3" front and rear. Front rate 5.5-6.1 kg/mm, rear rate 4.3-6.5 kg/mm. Link to comment Share on other sites More sharing options...
iamdkonz Posted December 12, 2011 Share Posted December 12, 2011 COBB and RalliTEK are both discontinued, and they're quite different from each other in terms of their lowering amount and spring rates, so which equivalent are you looking for? COBB: 1.75" front, 1" rear. Exact spring rates are unknown, but they say it's progressive rates that are "close to stock". Stock rates are 3.5 kg/mm front, 5.5 kg/mm rear. RalliTEK: 1.3" front and rear. Front rate 5.5-6.1 kg/mm, rear rate 4.3-6.5 kg/mm. Rallitek were my original choice. Suggestions? Thanks Link to comment Share on other sites More sharing options...
N.sane Posted December 12, 2011 Share Posted December 12, 2011 Rallitek were my original choice. Suggestions? Thanks Hmm, hard to find something similar to RalliTEK since they are the only springs I know of that have a stiffer front rate compared to the rear. ION springs are probably the most similar in terms of spring rates (front: 4.0-5.2 kg/mm, rear: 6.7 kg/mm), but they're also discontinued. If you just want the drop of the RalliTEK, H&R (1.25" front & rear) or Vogtland (1.2" front & rear) would be most similar. Link to comment Share on other sites More sharing options...
Blue Posted December 12, 2011 Share Posted December 12, 2011 ION Springs are not discontinued - at least not as of a few months ago. They're just really expensive. Link to comment Share on other sites More sharing options...
torinalth Posted December 12, 2011 Share Posted December 12, 2011 vogtland is the closest to rallitek in both drop and spring rate. mine just came in today, just need my tophats and i'll install... probably this weekend. Link to comment Share on other sites More sharing options...
N.sane Posted December 13, 2011 Share Posted December 13, 2011 The Vogtland's are quite a bit softer up front according to the Vogtland tech. When I e-mailed them they said it's 3.4-4.5 kg/mm front, 3.1-6.5 kg/mm rear, so it's quite similar to the Eibach/Epic Engineering/MSI springs. Did they give you the same rates? Link to comment Share on other sites More sharing options...
LRegvall Posted December 13, 2011 Share Posted December 13, 2011 Rallitek were my original choice. Suggestions? Thanks Eibach Link to comment Share on other sites More sharing options...
torinalth Posted December 13, 2011 Share Posted December 13, 2011 had thought the front was a bit higher.... I have my notes stashed somewhere... I'll see if I can dig them out, but the rear is right. Link to comment Share on other sites More sharing options...
ChemicalWaste Posted December 18, 2011 Share Posted December 18, 2011 Which Eibach springs are people running? On tirerack they don't list them and the Eibach website is about as useful as a poop-flavored lollipop. Link to comment Share on other sites More sharing options...
cypher0117 Posted December 19, 2011 Share Posted December 19, 2011 I run the eibach pro kit (1" front and .8" rear) They are getting harder and harder to find as I don't think they are in production anymore. found some here: http://lsdmotorsports.com/prod/804436002422.html Link to comment Share on other sites More sharing options...
