cfaber Posted August 15, 2009 Share Posted August 15, 2009 A little bit of polish and he won't be able to tell the difference. That's how it works right? Winning the internet Link to comment Share on other sites More sharing options...
ndmx52 Posted August 17, 2009 Share Posted August 17, 2009 Is there typically enough metal to work with on the 05-07 keys to work them down to fitting the flip key? Don't really feel like getting a blank made since I had to sacrifice a key anyways to get the transponder Here is my set up:-- 06 Key -- 08 Remote/fob-- Honda flip Link to comment Share on other sites More sharing options...
trademark Posted August 17, 2009 Share Posted August 17, 2009 nope. it isnt a long enough key to work Link to comment Share on other sites More sharing options...
ndmx52 Posted August 26, 2009 Share Posted August 26, 2009 finally got my flip case (Ordered the 7th, arrived the 26th), long shipping is no joke. Anyone else feel like the flip action is slow compaired to an audi or acura key? Anyways, hopefully I can finish this up in the next day or two. Just need to get a long blank cut to fit into this flip case and put all the parts together. Link to comment Share on other sites More sharing options...
leggtnut Posted August 26, 2009 Share Posted August 26, 2009 I would say both of mine are the same speed as my mom's audi and dad's former vw flip keys. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
Vbelisle Posted August 26, 2009 Share Posted August 26, 2009 finally got my flip case (Ordered the 7th, arrived the 26th), long shipping is no joke. Anyone else feel like the flip action is slow compaired to an audi or acura key? Anyways, hopefully I can finish this up in the next day or two. Just need to get a long blank cut to fit into this flip case and put all the parts together. what case did you get? Link to comment Share on other sites More sharing options...
leggtnut Posted August 26, 2009 Share Posted August 26, 2009 I got one of the origonal ones the DocHoliday did and it broke (cheep plastic). I just ordered a replacement that the pictures had the exclusive on the back, but the one I got didn't. It is just a little longer. I think I can make it work just fine. I have to take some time and fiddle with it more. One thing you might try is wind the spring one more turn. That should make it flip a lot faster and harder. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
Vbelisle Posted August 26, 2009 Share Posted August 26, 2009 I just ordered this one: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270446506283#ht_822wt_1167 Link to comment Share on other sites More sharing options...
leggtnut Posted August 26, 2009 Share Posted August 26, 2009 ok. I can't comment on that one. I have an 06 with 06 keys/fobs. That is one that works with the 08/09. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
Vbelisle Posted August 26, 2009 Share Posted August 26, 2009 ok. I can't comment on that one. I have an 06 with 06 keys/fobs. That is one that works with the 08/09. yeah well i have an 09, but where do i get a key long enough to hack up for this project? Link to comment Share on other sites More sharing options...
leggtnut Posted August 26, 2009 Share Posted August 26, 2009 I went to my local Ace hardware and they cut me a key on a all metal key. it cost me about $2 to get it cut. I then took out the dremel and cut the key to fit into the flip fob. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
Vbelisle Posted August 26, 2009 Share Posted August 26, 2009 I went to my local Ace hardware and they cut me a key on a all metal key. it cost me about $2 to get it cut. I then took out the dremel and cut the key to fit into the flip fob. thanks for the help. Link to comment Share on other sites More sharing options...
ndmx52 Posted August 27, 2009 Share Posted August 27, 2009 what case did you get? I have the 08 case for the honda key. How do you put this thing back together to make it work correctly? I took it all apart to test fit everything, but I'm afraid I won't be able to get it back correctly so it will flip. Link to comment Share on other sites More sharing options...
ndmx52 Posted August 27, 2009 Share Posted August 27, 2009 somehow managed to break the retaining pin Link to comment Share on other sites More sharing options...
Vbelisle Posted August 27, 2009 Share Posted August 27, 2009 I have the 08 case for the honda key. How do you put this thing back together to make it work correctly? I took it all apart to test fit everything, but I'm afraid I won't be able to get it back correctly so it will flip. I did. Not get mine yet but I will do a write up on how to do it Link to comment Share on other sites More sharing options...
firepyro515 Posted August 28, 2009 Share Posted August 28, 2009 its pretty easy to do. Make sure the remote part and immobilizer are in the bottom part of the case. Assemble the swivel mechanism (button, arm&holder, and the spring) then just put it all in place, and grab the whole arm and turn counter clockwise twice. then quickly use the top half to seal. Hold on tight while screwing in, Link to comment Share on other sites More sharing options...
ndmx52 Posted August 28, 2009 Share Posted August 28, 2009 what should I use for a replacement pin? Anything I can jam in there? Link to comment Share on other sites More sharing options...
firepyro515 Posted August 29, 2009 Share Posted August 29, 2009 replacement pin for retaining the key inside? anything that will fit and that you can cut down to size, i can't really think of anything, maybe a nail that you can dremel down might work? Link to comment Share on other sites More sharing options...
ndmx52 Posted August 29, 2009 Share Posted August 29, 2009 If anyone else has the same problem as me and breaks the pin here is a solution. Go to Home Depot and near the drawers of bolts, nuts, automotive fasteners, ect; there is a drawer for "Tension Pins". Grab yourself the 1/16" x 1/2" pins. Come 2 to a bag and are like .49 cents or something like that. They are a little long so once you put them in you will need to trim it once you put it in. Worked perfectly. Link to comment Share on other sites More sharing options...
Vbelisle Posted August 29, 2009 Share Posted August 29, 2009 If anyone else has the same problem as me and breaks the pin here is a solution. Go to Home Depot and near the drawers of bolts, nuts, automotive fasteners, ect; there is a drawer for "Tension Pins". Grab yourself the 1/16" x 1/2" pins. Come 2 to a bag and are like .49 cents or something like that. They are a little long so once you put them in you will need to trim it once you put it in. Work perfectly. Good to know thanks! Link to comment Share on other sites More sharing options...
blakout Posted September 2, 2009 Share Posted September 2, 2009 So I read the first 16 pages searching for this answer and gave up (probably was there and never even noticed) Which model did Doc use, GiES 600 H/HE/HS...etc??? I think I want to try this out but just want to make sure Im starting with the right stuff. Link to comment Share on other sites More sharing options...
schwartzki Posted September 2, 2009 Share Posted September 2, 2009 Just thought I would let you all know that the 09 all in one subaru key part number 57497AG48A works in 2005+ I just had it cut and programmed for my 05 outback xt(which has a immobilizer) Link to comment Share on other sites More sharing options...
DocHolladay23 Posted September 3, 2009 Author Share Posted September 3, 2009 ^^I think it was the GiES 600H, just PM the person selling it and ask them if it says "Exclusive" on the back [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
trademark Posted September 3, 2009 Share Posted September 3, 2009 Just thought I would let you all know that the 09 all in one subaru key part number 57497AG48A works in 2005+ I just had it cut and programmed for my 05 outback xt(which has a immobilizer) yikes how much did that cost you? 100? Link to comment Share on other sites More sharing options...
Vbelisle Posted September 3, 2009 Share Posted September 3, 2009 just a quick question, what would be the best drill bit to use on the dremel when cutting the key? Link to comment Share on other sites More sharing options...
