GrayT Posted March 14, 2008 Share Posted March 14, 2008 Hey guys im new here. i actually just bought a 2008 subaru legacy 2.5se and want to put HID headlights in. Is it possible to put them in and just not touch the DRL. i still want the daytime running lights, and my highbeams. i just want to make the projector bulb be HID. is that possible? i am clueless about headlights so please help!!! You will be fine. The DRLs are essentially the high-beams, just dimmed out a lot. The low beam is seperate from the DRL/high-beams. No need to disable anything. Just put the HIDs in, and you'll be fine. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 14, 2008 Share Posted March 14, 2008 I can only speak for myself by saying this but my DRL in my 2005 legacy don't have enough constant voltage to stay ignited so it wont work for me. I'm not sure what kind of voltage the 2008's run though. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted March 14, 2008 Share Posted March 14, 2008 so the projector bulb and the drl/high beam are on 2 seperate harnesses? there will be enough power to have both hooked up? im not gunna lose the blue light on the cluster that says the high beams are on or anything cuz i read a few forums that mentioned something like that but that was for the drl mod? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 14, 2008 Share Posted March 14, 2008 1 harness on the back of the headlamps connects to the main engine harness for the lights. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
whobaru Posted March 14, 2008 Author Share Posted March 14, 2008 Just remember the primary reason many of us disable the DRLs is so the HID bulbs last longer. Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted March 14, 2008 Share Posted March 14, 2008 1 harness on the back of the headlamps connects to the main engine harness for the lights. so there is just 1 harness? or there is 1 harness on the low beams and then 1 on the high beams? and if there is only 1 harness that connects to the engine harness how would the high beams still be connected because i thought the ballast would just output the HID? im sorry ima dumby at this stuff... please try and clearify for me!! Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted March 14, 2008 Share Posted March 14, 2008 Just remember the primary reason many of us disable the DRLs is so the HID bulbs last longer. but if my DRL/high beam is a seperate bulb from my low beam then how would HID bulb burn out quick.. if its not the same bulb and the DRL is my high beam dimmed down then whats the connection to the HID burnout? Link to comment Share on other sites More sharing options...
whobaru Posted March 14, 2008 Author Share Posted March 14, 2008 Oh, nm, didn't realize you were '08. Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted March 14, 2008 Share Posted March 14, 2008 so with an 08 ill be arite without burning out the DRL/HB? if i just replace the projector bulb ill be ok with the other bulb and neither will burn out.? Link to comment Share on other sites More sharing options...
whobaru Posted March 14, 2008 Author Share Posted March 14, 2008 affirmative. Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted March 14, 2008 Share Posted March 14, 2008 thanks man!! ur DIY was alot of help!! ne suggestions for colors.. itll be h7 bulbs as well... i dont want a super white bulb i want some blue tint but not like too ricey you know? ne ideas? Link to comment Share on other sites More sharing options...
whobaru Posted March 14, 2008 Author Share Posted March 14, 2008 That's exactly what I wanted, so I got the 35W 5,000K. Link to comment Share on other sites More sharing options...
GrayT Posted March 14, 2008 Share Posted March 14, 2008 thanks man!! ur DIY was alot of help!! ne suggestions for colors.. itll be h7 bulbs as well... i dont want a super white bulb i want some blue tint but not like too ricey you know? ne ideas? 4300K is pure white. 5000K has a hint of blue. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 14, 2008 Share Posted March 14, 2008 Here's a pic I just took of an 08 headlamp. as you can see its one harness on the headlights themselves which connects to the engine harness. http://i30.tinypic.com/nvb1mu.jpg OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 14, 2008 Share Posted March 14, 2008 the 2008's drl is the highbeam bulb so by changing low beams you wont have any problems. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
GrayT Posted March 14, 2008 Share Posted March 14, 2008 Echo... echo... Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted March 14, 2008 Share Posted March 14, 2008 thanks everyone... this helped alot... wish me luck Link to comment Share on other sites More sharing options...
whobaru Posted March 14, 2008 Author Share Posted March 14, 2008 Echo... echo... Link to comment Share on other sites More sharing options...
CTATV Posted April 3, 2008 Share Posted April 3, 2008 subscribe Link to comment Share on other sites More sharing options...
TheRival Posted May 25, 2008 Share Posted May 25, 2008 alright HID guru's... I Just Installed the Apexecone kit from xenon depot. I finished the install with the battery harness and gave the lights a test try, to my dismay, the driverside ignited and the passenger side ignited for 1 second and then turns off. If i turn the headlights off and back on, it will flicker 3 or 4 times and then turn off. What is going on?!?!?! anyideas on where to start? i can haz a siginaturz now? Link to comment Share on other sites More sharing options...
whobaru Posted May 25, 2008 Author Share Posted May 25, 2008 If it isn't a bad ballast, I would start by looking for differences between the driver and passenger sides. Same ground? If not, make it the same. Same quality connections? If not, ... If all else fails, prolly a bad ballast. My guess though. Link to comment Share on other sites More sharing options...
TheRival Posted May 25, 2008 Share Posted May 25, 2008 If it isn't a bad ballast, I would start by looking for differences between the driver and passenger sides. Same ground? If not, make it the same. Same quality connections? If not, ... If all else fails, prolly a bad ballast. My guess though. I have the battery harness that was supplied with my HID kit, therefore it shares the same ground and the same power lead, there is a fusable link that is in good shape. Could the relay be blown? i can haz a siginaturz now? Link to comment Share on other sites More sharing options...
whobaru Posted May 25, 2008 Author Share Posted May 25, 2008 Possible. Do you know how to read/test the outputs from a relay? That's a good place to start. Have someone click the light switch while you test where the voltage is dropping out. Before or after the relay. This is one of those things I kinda have to check out in person. Link to comment Share on other sites More sharing options...
johndas Posted May 25, 2008 Share Posted May 25, 2008 DRL's all diconnected properly? Seems to happen sometimes! J Link to comment Share on other sites More sharing options...
whobaru Posted July 11, 2008 Author Share Posted July 11, 2008 bump Link to comment Share on other sites More sharing options...
