derp Posted April 3, 2014 Share Posted April 3, 2014 make your wagon look like a boss and buy my wheels http://legacygt.com/forums/showthread.php/mn-work-vs-xx-wheels-18x8-48-5x100-w-pzero-223377.html I could suck start a snow blower. Link to comment Share on other sites More sharing options...
itsme Posted April 5, 2014 Share Posted April 5, 2014 Have you thought about a e85 tune? You can gain about 30+whp and it's always about $.50 to $1 cheaper then 91 Cali gas and it's around 105 octane. Look up a company called "Propel" they are opening up e85 and bio-diesel stations all over. I live in Carson ,Ca and I have 4 ( the 5th will open in a month) within 10 minutes from me. http://i59.tinypic.com/ngr311.jpg 2008 outback XT stroker build Hello after many years I am joining the Outback community and am please to introduce my pride and joy. This car is still a work in progress but here's were she sits now. Enjoy! Engine and exhaust Cobb V3 access port Manley 83 mm billet stroker crank Crower I beam rods JE pistons Cosworth 278-274 cams Super tech 70lb valve train ARP head studs Cosworth head gasket Moroso oil pan/ motul oil 15/50 summer and 5/40 winter Crawford AOS MSI fuel rails with upgraded fuel lines AVO fuel pump Tomi fuel pressure regulator PE 800cc injectors currently being swapped to ID 1000 cc because of issues 3 port boost control Blouch 20g XT turbo AVO top mount Perrin equal length headers Up pipe Cobb cat less down pipe Spt dual exhaust SPT cold air intake Koyo radiator Grim speed light weight pulley Optima red top Breaks Stage two slotted rotors Hawk pads Good-ridge steal Bradded lines Motul break fluid Once these burn out I will be upgrading to a big break kit front and rear most likely either Brembo or Stop tech Suspension- a work in progress White line front and rear sways with end links Avo under body brace kit front and rear Avo steering rack bushings Avo control arm bushings Sti tops hats front and rear New but stock springs and KYB gr2 I am considering dropping it soon but still need to figure out what will be best for me. Being at stock ride height I have the distinct advantage of being able to mash anywhere and every were with no regard. This includes being able to run over zombies. Exterior Rally tech full skid plate Rally innovations light bar PIAA lights Wheels Stock 17" powder coated with Sumitomo HRT A/S P01 235-50-17 winter Tenzo r sport 18" with Michelin pilot super sport 245-45-18 summer Drivetrain Kart boy short thro shifter with bushings Act hd clutch with fly wheel Stock 5 speed. I know it's crazy Once the tranny blows I will either do a full six speed swap with 180 diff and DDC or helical PPG set. I'm sure I left a few things out but this is the bulk of it When originally tuned the car put down 350whp and 355lbs on crap 91 Octane at 19 psi. I swear I would tell 91 octane to got to **** but I don't think satan could make much power with it either. With my current injector issue it is suffering and so I am swapping in ID 1000 cc injectors and doing a retune in a couple of days. Thanks for all of your posts and knowledge to the Outback community. Any feed back or comments are appreciated as I have lots more to learn and still have a ways to go on my build particularly on breaks, drive train and suspension. I will update this post pictures after the new tune. Peace my brothers! Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
itsme Posted April 5, 2014 Share Posted April 5, 2014 My old girl is still around after 9 years and I still haven't hit 66k yet. Still my favorite picture http://i167.photobucket.com/albums/u156/itsmebryan/005920-2.jpg Here are my new Falken 19x7.5" wheels that were only $300 shipped on amazon for all 4. It was cheaper than fixing my old wheels. http://i167.photobucket.com/albums/u156/itsmebryan/20130819_135932_zps730ab649.jpg http://i167.photobucket.com/albums/u156/itsmebryan/20130819_1355481_zps901ec7aa.jpg Then sometime I throw on the Tommy Kaira JDM front end. Then, I swap back to stock when I get sick of going up driveways sideways because it's about 2-3" lower then stock with the lip.http://i167.photobucket.com/albums/u156/itsmebryan/2012-01-22081915.jpg[/url] Don't forget if you guys need any parts let me know. Bryan Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
discojon Posted April 5, 2014 Share Posted April 5, 2014 My 06 Limited stage 3.5 daily driver. 5EAT, F1 Valvebody, forged CP pistons, BNR18g, Borla UEL tublar header, Greddy catless uppipe, invidia catless downpipe,stock CBE, FMS TMIC, DW 740, DW65, BIKSTEIN HDs with sti wagon pinks and 3/8 rear spacer. Completely stock exterior. Link to comment Share on other sites More sharing options...
LegGTwagon Posted April 8, 2014 Share Posted April 8, 2014 Hey all, I have an '06 LGT wagon with tints all around. I want to upgrade my reverse lights. Have any of you installed brighter bulbs or aftermarket lights to enhance your backup experience? Thanks Link to comment Share on other sites More sharing options...
theFranchise Posted April 9, 2014 Share Posted April 9, 2014 My wagon after a recent moab excursion Link to comment Share on other sites More sharing options...
magnusonsubie Posted April 10, 2014 Share Posted April 10, 2014 My wagon after a recent moab excursion Looks fun. I have a Moab excursion coming up at the end of this month. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
ripstik Posted April 10, 2014 Share Posted April 10, 2014 so sad I can't join the wagon mafia. but I'm in it in spirit. if they still had a wagon in '12 I would have been all over it. im looking into converting hahahahaha Link to comment Share on other sites More sharing options...
Blights Posted April 21, 2014 Share Posted April 21, 2014 Just picked up my 1st wagon. 05 n/a auto. Ordered a bunch of stuff already. It's going to be a fun summer. Are this wagon mafia stickers still floating around? Link to comment Share on other sites More sharing options...
Blights Posted April 21, 2014 Share Posted April 21, 2014 Side shot Link to comment Share on other sites More sharing options...
itsme Posted April 21, 2014 Share Posted April 21, 2014 Side shot Welcome to the family. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
goneskiian Posted April 22, 2014 Share Posted April 22, 2014 Welcome indeed. Nice color! Link to comment Share on other sites More sharing options...
SleeperScoob Posted April 24, 2014 Share Posted April 24, 2014 Glad to finally be a part of the family. Just picked her up this week, already Stage 2 + Suspension. Absolutely in love with the car, many plans for the future. http://i1202.photobucket.com/albums/bb368/SleeperWagon5/1BA6BC57-8101-4BCC-B2CF-3D793620C4DD-7984-000005BEF99AC831_zps0ef09509.jpg http://i1202.photobucket.com/albums/bb368/SleeperWagon5/6AD8374A-46B1-4B6F-A75F-C3E43BECB74C-7984-000005BEE46B8A90_zps8ef725ad.jpg http://i1202.photobucket.com/albums/bb368/SleeperWagon5/67B98343-EE1C-4DDD-9488-0BAC9281E530-7984-000005BEEE24170E_zps9147a5e1.jpg Link to comment Share on other sites More sharing options...
Blights Posted April 24, 2014 Share Posted April 24, 2014 Nice man. Welcome to the silver family. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
Fizzix Posted April 24, 2014 Share Posted April 24, 2014 2005 Legacy GT Limited 5MT Wagon http://farm8.staticflickr.com/7029/13989790924_06e0df9b4f_b.jpg http://farm8.staticflickr.com/7442/13986191061_174e4c843c_b.jpg Link to comment Share on other sites More sharing options...
SleeperScoob Posted April 24, 2014 Share Posted April 24, 2014 http://farm8.staticflickr.com/7029/13989790924_06e0df9b4f_b.jpg @Fizzix: Wanna trade? Link to comment Share on other sites More sharing options...
ripstik Posted April 24, 2014 Share Posted April 24, 2014 http://farm8.staticflickr.com/7442/13986191061_174e4c843c_b.jpg hot damn if that ain't sexy. with a 5 speed toooo???? DAAAMMNNN you just get her? Link to comment Share on other sites More sharing options...
goneskiian Posted April 24, 2014 Share Posted April 24, 2014 Great to see some super clean wagons still out there! Welcome all! Link to comment Share on other sites More sharing options...
Blights Posted April 24, 2014 Share Posted April 24, 2014 How does one go about getting a wagon mafia sticker? Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
Gex Posted April 24, 2014 Share Posted April 24, 2014 How does one go about getting a wagon mafia sticker? Sent from my SM-G900V using Tapatalk http://www.wagonmafia.com Link to comment Share on other sites More sharing options...
Blights Posted April 24, 2014 Share Posted April 24, 2014 Greatly appreciated Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
NYtoVT Posted April 25, 2014 Share Posted April 25, 2014 Damn, I miss my GT wagon! Link to comment Share on other sites More sharing options...
Fizzix Posted April 25, 2014 Share Posted April 25, 2014 hot damn if that ain't sexy. with a 5 speed toooo???? DAAAMMNNN you just get her? Yeah picked her up about 2 weeks ago. Runs great, only 71K on her. Carfax was pristine! Just showed regular maintenance. Zero warrantee claims. Link to comment Share on other sites More sharing options...
SnowBound BP5 Posted April 25, 2014 Share Posted April 25, 2014 Lucky you! That was the color I originally wanted. Wow, only 71K miles?! Looks like it's super clean too...where did you find it? 2005 Legacy GT Limited 5MT Wagon http://farm8.staticflickr.com/7442/13986191061_174e4c843c_b.jpg Link to comment Share on other sites More sharing options...
ripstik Posted April 25, 2014 Share Posted April 25, 2014 Yeah picked her up about 2 weeks ago. Runs great, only 71K on her. Carfax was pristine! Just showed regular maintenance. Zero warrantee claims. WOW DUDE. lucky you. I looked for a while for a nice clean LGT wagon with a 5 speed and only found crap so I bit the bullet and went with a 12 sedan. not that I regret it but I'm a serious wagon head. I love my self a nice sleeper power wagon. Link to comment Share on other sites More sharing options...
