gtspec84 Posted September 8, 2008 Share Posted September 8, 2008 hey guys, i just tried to do this process only to find there is no where in MY07 GT liberty to open up.. i have put a pic below to help you understand what i mean.. any idea oh what i need to do http://img352.imageshack.us/img352/8653/image002gg9.th.jpg Link to comment Share on other sites More sharing options...
Mark34 Posted September 8, 2008 Share Posted September 8, 2008 Looks like you're trying to get into the passanger side one. You should be able to take those small flat screw drivers and insert into the seam where the two parts of the cover join. I think I did mine at the bottom first and worked my way up. Link to comment Share on other sites More sharing options...
gtspec84 Posted September 8, 2008 Share Posted September 8, 2008 Looks like you're trying to get into the passanger side one. You should be able to take those small flat screw drivers and insert into the seam where the two parts of the cover join. I think I did mine at the bottom first and worked my way up. nah this is the drivers side.. im down in australia so things are backwards compared to you guys could be a reason why these instructions dont work for my car Link to comment Share on other sites More sharing options...
bdickey058 Posted September 13, 2008 Share Posted September 13, 2008 Turn the car to on, and put your seatbelt on and off just keep on clicking it in the thingy for like 30 seconds. do it as fast as you can then turn the car all the way on and it will disable your chime! Link to comment Share on other sites More sharing options...
gtspec84 Posted September 15, 2008 Share Posted September 15, 2008 Turn the car to on, and put your seatbelt on and off just keep on clicking it in the thingy for like 30 seconds. do it as fast as you can then turn the car all the way on and it will disable your chime! is this something that will need to be done everytime i go for a drive? or do it once and will never come back? Link to comment Share on other sites More sharing options...
Mark34 Posted September 15, 2008 Share Posted September 15, 2008 From reading around on here, a lot of people have mixed reviews on the click method. It seems like sometimes it randomly comes back on, and then it seems like it always comes back on if you have the battery disconnected for any period of time. It seriously takes like 3 minutes to do the quick switch mod that is permanent. Were you able to get into the housing? Link to comment Share on other sites More sharing options...
gtspec84 Posted September 16, 2008 Share Posted September 16, 2008 From reading around on here, a lot of people have mixed reviews on the click method. It seems like sometimes it randomly comes back on, and then it seems like it always comes back on if you have the battery disconnected for any period of time. It seriously takes like 3 minutes to do the quick switch mod that is permanent. Were you able to get into the housing? yeh i want to implement the permanent fix but still can`t see any clear way to remove the housing... i dont want to damage or break anything of course.. i have attached a pic in my previous post to try and assist but at this stage, no idea.. maybe my only option is to use the 30 clicks option.. Link to comment Share on other sites More sharing options...
Mark34 Posted September 16, 2008 Share Posted September 16, 2008 That's wierd. Your buckle looks different from our driver's side one. It looks more like our passanger buckle. Still, there should be a seam where the two sides of each housing join. You should be able to wedge a small jewely size flat screw driver into the seam and begin prying it apart. If it slips out you risk scratching the housing some, but you shouldn't be able to break it. Link to comment Share on other sites More sharing options...
gtspec84 Posted September 18, 2008 Share Posted September 18, 2008 hmm i was thinking since my drivers side is the USA passengers side, i might need to go to the my passenger side (USA drivers side) to make the change.. im not at my car now but will be soon enough and will check.. fingers crossed Link to comment Share on other sites More sharing options...
RustyShackleford Posted September 18, 2008 Share Posted September 18, 2008 Just want to put in a pointer to the "nuclear option" where you remove or silence the actual chime bell itself: http://www.legacygt.com/forums/showthread.php?t=83382 Quite a bit more work, but it gets rid of ALL chimes. That's important to me, because I'm a lot more annoyed by the inability to sit in the car and listen to the radio (with the key in the ignition and the engine off) without the annoying chime. IF you go this way, read to the end of the thread, where I added some pretty helpful (IMHO) explanations. Link to comment Share on other sites More sharing options...
machgirl Posted September 19, 2008 Share Posted September 19, 2008 Ok, so what about disabling the stupid seatbelt blinking light??!! Mine won't shut off, and do not know why. Link to comment Share on other sites More sharing options...
RustyShackleford Posted September 19, 2008 Share Posted September 19, 2008 Ok, so what about disabling the stupid seatbelt blinking light??!! Mine won't shut off, and do not know why. I wouldn't expect the chime-removal method to address this, and I've never tried the clicking-the-seat-belt-20-times or (whatever it is) method. So I'm no help, sorry. Link to comment Share on other sites More sharing options...
Mark34 Posted September 19, 2008 Share Posted September 19, 2008 My way does because it makes the car think the buckle is buckled. Link to comment Share on other sites More sharing options...
machgirl Posted September 20, 2008 Share Posted September 20, 2008 What is 'your' way? lol. I'd really like to just take out the light bulb.... Link to comment Share on other sites More sharing options...
BigInALegacy Posted September 20, 2008 Share Posted September 20, 2008 I did the 20 in and out method... I don't think my light comes on anymore... not 100% though. only time it resets is when you disconnect the battery, iirc. Link to comment Share on other sites More sharing options...
Mark34 Posted September 20, 2008 Share Posted September 20, 2008 What is 'your' way? lol. I'd really like to just take out the light bulb.... Reference my post # 119 on page 8. This is only for the driver's light though, it does nothing for the passenger one. Link to comment Share on other sites More sharing options...
machgirl Posted September 21, 2008 Share Posted September 21, 2008 How did you take that clip out? I have looked at the latch on the door, and tried to see if there was a way to open it to check it out.... Link to comment Share on other sites More sharing options...
Mark34 Posted September 21, 2008 Share Posted September 21, 2008 Pic from post 1. Link to comment Share on other sites More sharing options...
machgirl Posted September 22, 2008 Share Posted September 22, 2008 OH so that is from the seatbelt latch beside the seat, NOT the latch on the door correct? I am not so sure I wanna take things apart...I'd prolly mess it up. I think I'm going to just take some electrical tape and put it over the light.. Link to comment Share on other sites More sharing options...
Mark34 Posted September 22, 2008 Share Posted September 22, 2008 Yes, that is buckle between the center console and the seat. I'm not sure what you're talking about by the door. It's pretty hard to mess it up, you can do it! The only thing you might do is scratch the housing a little bit. Link to comment Share on other sites More sharing options...
bluebird Posted October 13, 2008 Share Posted October 13, 2008 just did it - that chime was driving me nuts !! Nice and quiet now !! Thanks ! Link to comment Share on other sites More sharing options...
Xterior Posted November 12, 2008 Share Posted November 12, 2008 So I did this today and now what is the solution for the passenger seat? The buckle inside is not the same as the drivers Link to comment Share on other sites More sharing options...
robertsm99 Posted November 13, 2008 Author Share Posted November 13, 2008 If you look through this thread, maybe around page 6 or so, I added picts and what not about doing the mod on the passenger side. Link to comment Share on other sites More sharing options...
BigInALegacy Posted November 13, 2008 Share Posted November 13, 2008 I did the 20-clicks and it's been fine for over a year. Link to comment Share on other sites More sharing options...
exarus Posted December 30, 2008 Share Posted December 30, 2008 My experience: The buckle is a pain in the ass to pry open, and is near impossible to open without scuffing the edges. Method works though. Link to comment Share on other sites More sharing options...
