Max Capacity Posted January 20 Share Posted January 20 This T 1 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LegacyLGT05 Posted February 18 Author Share Posted February 18 (edited) pops at idle runs super rich and afr spikes from 14.3 to 13.5. Thinking I got a bad injector on cyl 4 as the plug is black new plug and coil, as my oil level has risen and is thinned so amybe one is leaking / oring are new . only thing i am stumped about is when I unplug the Ovcs or the Tvgs I get no DTC ? Can someone confirm the voltage at harness for the ocvs an tgvs thanks { and no I was not just unplugging things, I changed out the ovcs for new ones and started the car and forgot to plug them in ran rough but never got a code. And the Tgvs well I was just testing them to see if the flapper wasnt stuck by powering it directly with a power supply Edited February 18 by LegacyLGT05 Link to comment Share on other sites More sharing options...
