Throttlejockey Posted August 19, 2004 Share Posted August 19, 2004 [quote] Okay, so out of curiosity, I followed the above directions verbatim, TWICE and I can't seem to turn off the chimes. Here's what I'm doing: 1)Turn key to "on" 2)Immediately start the seatbelt buckle/unbuckling 20x 3)Turn key to off, remove 4)Repeat one more time and then start engine What am I doing wrong? Ken[/quote] I started my procedure after the first 5 chimes. I don't recall taking the key out before I repeated the procedure, but before I started the car I did take the key out. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 19, 2004 Share Posted August 19, 2004 Didn't work for me- might be an OB issue ;) Actually, it probably all comes down to the nut behind the wheel ;) Link to comment Share on other sites More sharing options...
Nick Posted August 19, 2004 Share Posted August 19, 2004 [quote name='Ken S'] Okay, so out of curiosity, I followed the above directions verbatim, TWICE and I can't seem to turn off the chimes. Here's what I'm doing: 1)Turn key to "on" 2)Immediately start the seatbelt buckle/unbuckling 20x 3)Turn key to off, remove 4)Repeat one more time and then start engine What am I doing wrong? Ken[/quote] I did the exact process also, and it didn't work for me either. Strange. -Nick Link to comment Share on other sites More sharing options...
kenzo Posted August 19, 2004 Share Posted August 19, 2004 Me either Link to comment Share on other sites More sharing options...
frontrangeSubie Posted August 19, 2004 Share Posted August 19, 2004 remember, it will chime 5 times when you turn the car back on...then stop....so make sure you wait to see if it stops chiming....I didnt wait the first couple of times I programmed, so I thought it didnt work. Mark Link to comment Share on other sites More sharing options...
brad21 Posted August 19, 2004 Author Share Posted August 19, 2004 Stay focused. Breathe... Okay, try it again. I swear once you finally do it you'll feel like you just came from 12th place to win a Gold medal. :) Link to comment Share on other sites More sharing options...
ssaldana Posted August 19, 2004 Share Posted August 19, 2004 All I do is buckle/unbuckle 3 times and the beeping turns off... (as said in the owners manual) Link to comment Share on other sites More sharing options...
brad21 Posted August 19, 2004 Author Share Posted August 19, 2004 [quote name='ssaldana']All I do is buckle/unbuckle 3 times and the beeping turns off... (as said in the owners manual)[/quote] We're talking about a permanent or semi-permanent solution. The 3x thing is just a temporary fix. Link to comment Share on other sites More sharing options...
ssaldana Posted August 19, 2004 Share Posted August 19, 2004 gotttcha Link to comment Share on other sites More sharing options...
Ken S Posted August 19, 2004 Share Posted August 19, 2004 [quote name='brad21']"Repeat process, remove key from ignition again." Then reinsert the key and start the engine. This is after the second buckle/unbuckle process. Worked for me... maybe I missed some odd thing I did in between? Try rubbing your tummy and patting the top of your head? :) Don't give up, the effort is worth the silence.[/quote] A few clarifying questions: Do you wait until the inital chimes end for the buckle/unbuckle or start ASAP? Do you remove the key at the end of each 20x buckle/unbuckle process? Oh, and I did wait after the first set of chimes after completeing the process to see if it worked. About 20 seconds later "ding, ding, ding...". :( Ken Link to comment Share on other sites More sharing options...
frontrangeSubie Posted August 19, 2004 Share Posted August 19, 2004 as my post above.....Start clicking IMMEDIATELY when you first turn the key to "ON" (during the first chimes)....you physically hear that you are interrupting the chimming.... Key out Repeat above Key out key in to on to check to see if it works! Worked for me If you wait till the first set of chimes is over before you start clicking...you've waited TOO LONG. Key Mark Link to comment Share on other sites More sharing options...
frontrangeSubie Posted August 19, 2004 Share Posted August 19, 2004 Oh I forgot to add....my wife gave me "extra" sex due to me getting rid of that annoying chime..... Mark Link to comment Share on other sites More sharing options...
brad21 Posted August 19, 2004 Author Share Posted August 19, 2004 [quote name='Ken S'][quote name='brad21']"Repeat process, remove key from ignition again." Then reinsert the key and start the engine. This is after the second buckle/unbuckle process. Worked for me... maybe I missed some odd thing I did in between? Try rubbing your tummy and patting the top of your head? :) Don't give up, the effort is worth the silence.[/quote] A few clarifying questions: Do you wait until the inital chimes end for the buckle/unbuckle or start ASAP? Do you remove the key at the end of each 20x buckle/unbuckle process? Oh, and I did wait after the first set of chimes after completeing the process to see if it worked. About 20 seconds later "ding, ding, ding...". :( Ken[/quote] I started right after the initial chime, the key in ignition chime, not the seatbelt chime. Remove the key after both 20x b/ub process. Go go go go! Link to comment Share on other sites More sharing options...
frontrangeSubie Posted August 19, 2004 Share Posted August 19, 2004 I agree....START CLICKING DURING THE INITIAL CHIME....whatever chime that is Mark Link to comment Share on other sites More sharing options...
NewGTGuy Posted August 19, 2004 Share Posted August 19, 2004 That's what I did. Don't forget to remove the key both times. NGG Link to comment Share on other sites More sharing options...
Ken S Posted August 19, 2004 Share Posted August 19, 2004 [quote name='frontrangeSubie']as my post above.....Start clicking IMMEDIATELY when you first turn the key to "ON" (during the first chimes)....you physically hear that you are interrupting the chimming.... Key out Repeat above Key out key in to on to check to see if it works! Worked for me If you wait till the first set of chimes is over before you start clicking...you've waited TOO LONG. Key Mark[/quote] I started the process immediately after turning the key to "ON" pretty much after only one chime of the first set of chimes went off. As I get to the 3rd buckle/unbuckle, the first set of chimes stop. I just keep going until I hit 20x and key out. But nothing. I wonder if it only works with sedans?? PS. LOL on the extra sex. :D Ken Link to comment Share on other sites More sharing options...
brad21 Posted August 19, 2004 Author Share Posted August 19, 2004 [quote name='Ken S'][quote name='frontrangeSubie']as my post above.....Start clicking IMMEDIATELY when you first turn the key to "ON" (during the first chimes)....you physically hear that you are interrupting the chimming.... Key out Repeat above Key out key in to on to check to see if it works! Worked for me If you wait till the first set of chimes is over before you start clicking...you've waited TOO LONG. Key Mark[/quote] I started the process immediately after turning the key to "ON" pretty much after only one chime of the first set of chimes went off. As I get to the 3rd buckle/unbuckle, the first set of chimes stop. I just keep going until I hit 20x and key out. But nothing. I wonder if it only works with sedans?? PS. LOL on the extra sex. :D Ken[/quote] I'm a wagon man. No extra sex though as of yet. :cry: Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 19, 2004 Share Posted August 19, 2004 I'm down for the sex. Does anyone know what would happen if you just took the dinger out? Link to comment Share on other sites More sharing options...
Nick Posted August 19, 2004 Share Posted August 19, 2004 Ok, I finally got it to work. (whew!) I did NOT remove the key in between each time. -Nick Link to comment Share on other sites More sharing options...
Throttlejockey Posted August 19, 2004 Share Posted August 19, 2004 [quote name='Nick']Ok, I finally got it to work. (whew!) I did NOT remove the key in between each time. -Nick[/quote] Me either. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 20, 2004 Share Posted August 20, 2004 [quote name='jedimaster']I'm down for the sex. Does anyone know what would happen if you just took the dinger out?[/quote] Link to comment Share on other sites More sharing options...
Drift Monkey Posted August 20, 2004 Share Posted August 20, 2004 [quote name='jedimaster']I'm down for the sex. Does anyone know what would happen if you just took the dinger out?[/quote] Link to comment Share on other sites More sharing options...
ssaldana Posted August 20, 2004 Share Posted August 20, 2004 Got it on the first try! Man that beeping was annoying. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 20, 2004 Share Posted August 20, 2004 [quote name='Drift Monkey'][quote name='jedimaster']I'm down for the sex. Does anyone know what would happen if you just took the dinger out?[/quote][/quote] Link to comment Share on other sites More sharing options...
ssaldana Posted August 20, 2004 Share Posted August 20, 2004 I took the dinger out of my '91 bmw, not sure how it would play out on a legacy though. Link to comment Share on other sites More sharing options...
